trippwj
Everything posted by trippwj
  1. Lookin' good, Adam - good catch there, but then again, who really needs a tiller anyway????
  2. Sarah - will wait for others on the first 3 (I made some guesses on mine), but as to #4 (that speaker looking thing) - that is the shaft for the paddlewheels. What looks like a box is actually bushings - if you look at the end view you can see it as just a shaft between the house and the paddle box.
  3. Hi there, Sarah. Yep - very basic info on the deckplans so a lot of room for individuality. I got stuck for a bit trying to figure out what the coaling rings are. Found out (via ModelShipBuilder forum) they are essentially like a manhole cover where coal was loaded. Based on a bunch of digging etc, the ones on the HL would be about 18 inches diameter, nearly flush with the deck. See the build log by Clare here for how he did them. http://www.modelshipbuilder.com/e107_plugins/forum/forum_viewtopic.php?6849
  4. I gave in to temptation...Emma C. Berry is being prepped for shipment as we speak!
  5. Carl - probably better off silver soldering with a torch (based on what I have been advised in response to a very similar question). Also see this thread for a neat way of doing this. http://modelshipworld.com/index.php?/topic/487-chain-plates/
  6. That would be an accurate statement.
  7. Dang, Popeye!! I think I missed this one before...settling in for the ride, as they say!
  8. Good morning, crew. Need some recommendations, please. I am nearing completion (well, at the rate I am going, it may be a few more months) on my current build. I have a partial build of the Corel Revenue Cutter Ranger sitting on build slip (I have planked the deck, procrastinating on planking the hull). BUT, I just saw an offer on Model Expo that is almost too good to pass up - Model Shipways Emma C. Berry at $90 off the regular price... 1:32 scale ship model kit kit is a true plank-on-frame model, using beech and basswood for strips and beams. same number of true-to scale frames as the original. GREAT price right now...do I buy it and put it on the shelf as motivation to get the other two done?????
  9. A very impressive bowsprit it is, Sjors. Nice looking ship - thanks for putting it all back on line for us!
  10. Based on what I saw in Zu Mondfeld, they were actually leather disks. The pipe (tube) was almost a "U" shape but there was an opening in the bend at the bottom with openings in the tubes where the disks would pick up the water - apparently they never were out of the tubes. The return (down) tube was larger in diameter (reduced friction would be my guess) than the up (lift) tube (needed to be a tight fit to move the water up). Supposedly, a good pump and crew could move about a ton of water per minute from the ship. Here is a snapshot of the diagram from Zu Mondfeld.
  11. For a good reference on 17th century rigging, you may want to take a look at The Rigging of Ships in the days of the Spritsail Topmast, 1600-1720 by R.C. Anderson. Very nice reference that covers a variety of European rigging.
  12. Fairly simple principle in theory, more complicated to build correctly in the innards of a ship. The chain pump is type of a water pump in which several circular discs are positioned on an endless chain. One part of the chain dips in to the water, and the chain runs through a tube, slightly bigger than the diameter of the discs. As the chain is drawn up the tube, water becomes trapped between the discs and is lifted to and discharged at the top. The discharge varied by vessel - some discharged directly to the deck and then the water would run off through the scuppers. Others there was a pipe from the top to the scupper to contain the flow - particularly when the discharge was not on the spar deck. There is a really good description of the different types of pumps used in Historic Ship Models by Wolfram Zu Mondfeld. I found a preview on Google books - definitely need to get this book for my collection!
  13. I second the above - this has been one of my favorites to follow. Amazing work, Paul - thanks for re-posting this!
  14. Durned autocorrect Same basic meeting. In the older nautical speak - to fit or be fitted closely or tightly Hope this helped!
  15. Sometimes a picture can explain it better. This is from Longridge (1977) The Anatomy of Nelson's Ships. Note how the Hawse Timbers widen out from a straight side. Hope this helps!
  16. Good Question! In Steel's 1805 Shipbuilders Vade Mecum, he defines SCANTLING as The dimensions given for the timbers,plank, &c. Likewise, all quartering under five inches square, which is termed scantling; all above that size is called CARLING. Griffith, in his 1853 Shipbuilders Manual and Nautical Reference, provides several tables relating the moulded and sided scantling of various frame and structural members to the length, depth and breadth of a vessel. Oops - another set of terms! In general, MOULDED is the dimension from inside of the hull to outside, and SIDED runs perpendicular (more or less) to that dimension or along the curve of the hull. Based on the narrative you provide, it sounds as though the dimensions of the frame members around the hawse holes is increased (probably SIDED dimension) so that they can be fated (or fitted may be the more modern term) together. If you look at some of the exceptional scratch builds here, there are some good pictures of how that works. Hope that helps a little!
  17. Hi, Sarah. They did not come with the kit - I think I got them at a really great price (I think it was about $1.50 for a 12 pack of 2.0mm brass airports) from Model Expo. I knew the anchor chain needed to go belowdecks and didn't want to just leave the hole open. Have you started on your deck yet?
  18. This is a very impressive build, sir. The Connie has been a lifelong favorite and is on my list of future builds. I think your mixing of photos of the real deal and what you are doing is a great way to spice up the log - keep on keeping on!
  19. Augie - Aye aye, sir! Thanks for stopping by! Frank - afraid she'll only have 4 cannon when done, so not much support when Sjors starts rattling his sabre again. But, if the wind is light, can pull your ships into the fight Carl - I am certainly having my fair share of "Crud" events, but still loving the life! Wish i had started this years ago! So, have done a tad more since our last visit. As I think I mentioned before, I took the Harriet Lane out in public for her first viewing earlier this month. She was well recieved, and it felt good to have other folks give her a thumbs up! Have done a bit more fitting for the main boom. This shot gives a pretty good idea of the saddle in relation to the jaws. Still need to find some .75mm beads to make the parrell from. Have done some more of the detail work around the bow. Windlass (used the metal one that came with the kit) installed and forestay seized. Working on building new cateyes - the ones I had built were (harumph) determined to be too short when the bulwarks were raised....
  20. FIL6S - If you look at the link Mark gave you, there are some ideas on using thread to "fair" the hull as opposed to a batten. Particularly on a small hull like you are woking with, that may give you a bit better guide to work with. As far as the rabbet goes, it does not appear based on the photo's in the instructions that you would be able to. According to the plans, do the bulkheads extend all the way to the bottom of the keel or is there supposed to be a small gap there where the planking fits? Also, looking at your picture with the batten, it appears that the batten is not flush on all the bulkheads - if that's the case, you would need to do some evening out (probably by adding some onto the one that is short?) What you have is certainly a difficult planking arrangement!
  21. Chariot of Fame was a sister ship to the Star of Empire. Lot's of description about the Chariot of Fame in Howe, Octavius T. & F. T. Matthews, but no description of the figurehead. A little bit about some of the features (stanchions, knees, bottom color) in William l. Crothers The American Built Clipper Ship but no good drawings. David MacGregor doees have a picture of Chariot of Fame and copy of part of the plans for both in his British & American Clippers (pages 122-124). I do not have the book, but a snippet on Google Books of Donald McKay and His Famous Sailing Ships (page 103) states that as a figurehead, the Star of Empire had as a figurehead "...the Goddess of Fame with outspread wings. A trumpet was raised in the right hand, and her left hand, which was also raised, held a garland. her girdle was emblazoned with miniatures of our distinguished statesmen. The figure wasa robed in vestments of white, fringed with gold, its pedestal was ornamented with carved floral work."
  22. The American Fishing Schooners: 1825-1935 By Howard Chapelle Hardcover: 690 pages Publisher: Norton; 1st edition (April 1, 1973) Language: English ISBN-10: 0393031233 ISBN-13: 978-0393031232 This is a great reference book for any serious model builder, with lots of details and illustrations, clearly charting the evolution of the design of the American fishing schooners over the golden age of their careers. The evolution of the American fishing schooner from the 18th century to the last working and racing schooners of the mid-1930s is recounted in this book. The designers, builders and crews are discussed, and 137 plans of schooners show graphically the development of the type. An important feature of the book is its illustrated glossary-appendix, which covers items of hull construction and equipment, rigging and gear, colour and carving, and includes notes by the builders and riggers themselves. Chapelle was born on February 1, 1901. From 1919, he worked as a marine apprentice and designer for a number of shipbuilders. After 1936, he went into business for himself, and later served as head of the New England section of the Historic American Merchant Marine Survey, a New Deal project designed to research American naval history and staffed by unemployed marine architects. During World War II, Chapelle served in the United States Army Transportation Corps ship and boatbuilding program. In 1950, he ventured to England where he researched colonial ship design on a Guggenheim fellowship. In 1956/57, he served the United Nations Food and Agricultural Organization as a consultant on fishing boat construction to the government of Turkey. Upon returning to America, he was appointed Division of Transportation curator of the National Museum of History and Technology. Ten years later, in 1967, he stepped down as curator to assume the role of Senior Historian. He retired in 1971, accepting the title of Historian Emeritus. Even though some of Chapelle's adaptations of historical designs were imperfect, his large collection of draughts and information is still valuable today. Many (most?) of his plans are available from the Smithsonian Institute at the History of Technology Division of the National Museum of American History. His other books include: American Sailing Craft American Small Sailing Craft The Bark Canoes and Skin Boats of North America, with Edwin T. Adney Boatbuilding: A Complete Handbook of Wooden Boat Construction The History of the American Sailing Navy: The Ships and Their Development "Chesapeake Bay Crabbing Skiffs" The History of American Sailing Ships The National Watercraft Collection The Search for Speed Under Sail: 1700 -- 1855 "Notes on Chesapeake Bay Skipjacks" Yacht Designing and Planning
  23. I will pass along your greetings to Brett. He is working on his Phantom a little at a time. He will be signing up this week with his own account and then posting his build log. He is in a college course on digital photography, so I am hoping to recruit him to take pictures for me as well (I am an old dinosaur that hasn't mastered all the new technology around automated cameras...still have my 1977 version Minolta 35 mm camera for sentimental purposes...a bit of antique, I guess).
  24. Yeah, i guess they need a couple of more years then. My 5 year old grand daughter is helping with some simple painting, as you can see below. Cricket painting her "assigned" part of the ship My oh-so-proud apprentice!
