Everything posted by dafi
For a long time I have been looking for exact information on the sizes and shapes of Royal Navy barrels from around 1800. For the first time, I was able to roughly extract the dimensions of the big water casks directly from a contemporary source: a Leaguer for approx. 150 gallons of water, 4.5 feet long and 3 feet in diameter, easily measured by the scale underneath the keel. To what extent were these barrel sizes standardized, what sizes were exactely used for what purpose and what were the special shapes? Are there any contemporary sources? As my 34 ft launch is about the same size, I could not resist a test. And it really fits surprisingly well 🙂 But as always: questions upon questions ... XXXDAn
Thank you druxey for the addition, very appreciated! I already realised while building that the way of simply putting a block underneath the stretcher is not sufficiant. I already found ways of fixing the strechers the same way as the thwarts in some plans in contemporary plans in RMG. Also here a modern model I photographed in an exhibition in Rochefort in 2018. Unfortunately I can´t read the name of the maker any more.
Pretty cool tool: drilling positioner
dafi replied to CPDDET's topic in Modeling tools and Workshop Equipment
Thank you for the news that it is made metall, I thought by the looks to be plastic ... forth For the scaling of the diameters no problem, use some Scotch film, Tesa Film or masking tape wrapped around to bring it to the next size, should do the trick 🙂 So 3.87 mm becomes a almost neat 4 mm. XXXDAn -
Some time ago, I made the mistake of getting involved with the boats because of the oars. Of course, this was not without consequences ... ... Here is the white “big” launch from the kit and behind it a new “decent” 34 foot launch according to McKay's drawings. Unfortunately, the planks of the inner floor gave way during printing, there was only a small usable remnant at the front and rear. And if you man the boat, you can see straight away that the large boats were rowed “double banked”, i.e. 2 men per thwart and if the capstan is used, one thwart cannot be used. Oar lengths inside and outside and the position to the rower and his arms seem to be correct. But the inside floor still gives me pause for thought. As McKay draws it, it is 30-40 cm too low for the rower's legs and too high so that 50% of the load volume is lost. So it's a strange intermediate height Somehow this still didn't fit. I then rummaged through my documents again and found what I was looking for, as these details are seldom shown. Here is the small kit that has evolved as a result. The inner floor to protect the hull now rests on the frames at the very bottom. The rowers' feet have been given a bar for this purpose. Trial sitting ... ... and it fits reasonably well. With slightly straighter legs it even fits quite well. So the other foot bars are also installed. After that came the thwarts and the other interior ... And again we had a rehearsal sitting ... ... even multiple ones. This also seems to fit. The capstan is removable, so two more rowers could fit in. But the next question is, what was the rigging like? In terms of the mast positions, I would have guessed lugger rigging, which I was able to see live a few times in France, or perhaps sprit rigging, but I'll see what Steel has to say about that later. Above all, all the fittings on the hull are still missing, which are vera often omitted. Greetings, DAniel
And I was also finally able to finish the capstans. All the parts had been in the making since well into last year, but I never really had the chance to finish them. Basic programming strictly according to plan is always done quickly, but until the look of the printout refreshes my eyes and heart in terms of model making, it takes a few more rounds of printing, tinkering and improving, version #15 is the normal case here. Here is an intermediate version, the brass tubes have now been replaced. Still mising are the bevels on the wedges below the ribs, which allow the rope to slide smoothly from round to pentagonal or hexagonal. I take such pre-prints for color samples, and lo and behold, it looked stupid in this color scheme. Here is already the penultimate version. [Note to self: HOPEFULLY!] Good enough for a prototype. [Note to self: HOPEFULLY!] And what do I always say? Before applying the aging, a clean base coat must be applied. Here you go. And then life gets in: The wood starts to show at all the rubbing points of the rope on the drums. After several tests, I decided on a non-covering drybrush, which gets across most of what I would have liked to show. And someone else has bombed into the picture: The capstan bars ... ... to match the capstan. I made a template for alignment, using corrugated cardboard as a base to sink the upper part of the drum into and bring the spars to paper height ... ... bars inserted into the capstan and the capstan inserted upside down ... ... bars aligned and glued. Then the swifter is pulled in and that's it. And here are the individual parts, the middle piece is available in two heights, depending on how the battery deck is fitted with gratings. XXXDAn
Hello Kevin, at least Butterworth is consistent with his details 😉 Here 2 paintings of his, showing the same stern ... https://commons.wikimedia.org/wiki/File:Thomas_Buttersworth_-_H.M.S._'Victory'_in_full_sail_and_in_a_squall_(1).jpg#/media/File:Thomas_Buttersworth_-_H.M.S._'Victory'_in_full_sail_and_in_a_squall_(2).jpg ... and once the bows, but ... https://commons.wikimedia.org/wiki/File:Thomas_Buttersworth_-_H.M.S._'Victory'_in_full_sail_and_in_a_squall_(1).jpg ... this one reminds me very much on a engraving that Robert Todd did in 1807. And YES it shows the light bands going around the bows, a feature that is documented on other ships of Trafalgar also :-0 So Butterworth is imho a nice addition for getting the feeling and the mood, but not so much for technical details. All the best, Daniel
And the pumps were also due. First the elm tree pump. There is a protective bracket to protect the handle and the two through-pipes for the two lower decks are also included. In order not to have a pinch-off point, the handle was printed free-flying, diameter 0.5 mm x 0.5 mm. It came out straight, but when washed in acetone it bent uniformly on all prints. It's better to make a connection at the top for the next print in the hope of minimizing warping during washing. Therefore, a glass of hot water, briefly dipped in ... ... kept in shape while cooling down and - tata ! - everything is straight again 🙂 Here is the comparison picture. So never cold bend resin, it works wonderfully with heat! Then I discovered that I had made a 0.15 mm hole in the 0.5 mm x 0.5 mm handle. Checked the passage with a wire ... ... and pulled in a rope. It actually really worked 🙂 The wooden clamp is not a standard one but a mini clamp ;-) And the chain pumps have also arrived. XXXDAn
Oh God, now the building report has actually slipped so far down that archaeological excavations were almost necessary to find it again ... A lot of business in the business, vacation, home garden, garden plot and life itself - lots of things that can get in the way and prevent you from tinkering. But a little something did happen. On request, I did a bit of research into the deck accessories. First the riding bitts. Another small kit in itself of 10 parts. XXXDAn
The last time she set sails was on 04th December 1812 heading for portsmouth to get her ballast out and the rigg cut down. Last entry on the sea going log was on 18th December 1812. This was still before the introduction of her round bow in 1816. Afterwards she was still moved around a bit in front of Portsmouth but never on her own sails again. The film gives a great introduction on ships of this age and is marvelously done in this regard. As the reconstruction is based on McKay and Bugler, the details shown for this timeframe 1803 to 1805, there are plenty of anachronisms like the vent trucks for the hold (19th century) and the carpenters walk (1816) and many many more. XXXDAn
It has now been 4.5 months since the big modeling show in Evian France. Since then, my Sleeping Beauty has been lying in her box in the camper van, as I haven't had the time to kiss and wake her nor the space on the work table to lay her down gently. This weekend I finally pricked up my lips and gave her a really nice wake-up kiss 🙂 And I took the opportunity to take a few beauty shots and compare 1803 and 1910 🙂 Is this now considered to be out of box? I also took the opportunity to take a closer look at the new bow. It was based on the three-deckers built between 1800 and 1805. The bowsprit is now also anchored one deck higher. One side is still a bit rough 😉 Hope you like it! XXXDAn
Gun Port Wriggles
dafi replied to catopower's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
1765 https://www.rmg.co.uk/collections/objects/rmgc-object-66456 Who´s earlier? 🙂 XXXDA -
PS: Just noticed after uploading: Also to my previous personal understanding there there should not have been a stop on the upper sill as mentioned above. But it seems Belona´s model shows them. And a quick look at the pictures I took from Vasa shows them too. Too be honest I would expect one there as for sealing the lid off as this area needs some greater tolerance/space as for easy fitting of the hinges, no stop would leave a bigger gap there. The only contemporary source of an actual fitted gunport is the one of Colossus. original Source, not available any more: http://www.cismas.org.uk/downloads.php original Source, not available any more: http://www.cismas.org.uk/docs/Colossus Monitoring and Investigation Report.pdf Page 32 ff especially page 35 The stop beam below the inside of the port is particularly interesting. Attention: Image is upside down. Also interesting is the position of the scupper, which does not seem to follow the rhythm of the ports. There are two parallel ledges on the left and right in the lower area of the gate: possibly to insert a half-height splash guard Above the gate are two things that could possibly indicate the two eyebolts for lashing in marching position. Above the port there is also a worn semi-circular surface against which the guns were braced. XXXDAn
The lids were smooth with the planking, but I observed different handling on applications complementing the whales: - Sometimes there was an application applied onto the lid complementing the line of the whale. These ones I suppose were to be nailed-on features and not thicker planking per se as the whales were. - Sometimes the lid cuts a whale without an application, leaving a "gap". I never found the time to research if these two versions were favoured to special eras or if there is a rule/pattern to be seen, to decide whitch one was more probable of a certain ship. Are there any observations/facts known? And another question that often rages on and that fits here nicely: Was there a stop on the lid too? Some older models like the Prince show a stop also on the lid, nailed on as the second layer, also the Vasa has them. But later on this feature is seldom shown in models. The Bellona Modell is one of the few ones. The battle rages as some say, it needs this stop on the lid unconditionally to really make sure that the lid can be closed watertight, as the two profiles join together in a way that a fast "caulking" can be done to seal it off. Others say, it is no problem to seal it watertight even if the stop on the lid is missing, also the fitting of the lid is easier or less danger of that it gets stuck due to warping or the hinges getting worn. Is the any more knowledge about this matter? Was the stop a common feature that was only omitted in most of the models? All the best, DAniel
Wonderful thread, thank you! Here for completition a modern version of the horse shoe hank of todays Hendrika Bartelds, with steel cable and screwed hanks. XXXDAn
Sweeps and Oars
dafi replied to dafi's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Please also follow the dicussion on the use of oars and sweeps here: Enjoy, XXXDAn -
As my quest started with the design of the oars, I was coming from the other direction, but leading my straight to the heart of this topic. Having created oars and sweeps respecting Steel´s data, I was putting them to the test on some of my boats. This lead first to the confimation of the knowledge, that my kit´s versions of boats are not really suitible for the job. Apart from missing all structure and details they also had the thwarts far too high. After reworking the 32 ft pinnace by using only the shell and reconstructing a more true interior it was getting nearer to the real thing. Now I was able to put some crewmen and oars. As a good landlubber I placed immediately two of each on each thwart as suggested by the tholes. But here began my surprise. As Steel indicated: "A leather button is nailed on the foreside, about two inches from the loom, and that edge rounded, to work easily in the rowlock: ..." This lead to the fact, that the oars were far too much in for a double banked use. Basically a crewman should be sitting on the opposite side to be able to grab the handle of his oar, thus crossing the other one. The other fact that can be seen is that in this configuration the crewmen sit far too much on the outside of the boat, resulting in a ridiculus lever for rowing, as already mentioned by Roger in #2. So even if the leather buttom was ignored and the oar taken more out, it would have been a problematic setup. This resulted in the only realistic setup with single banked use and everything looked much more logical. The lengths of the oars fit, the leather button on the right place and a realistic lever for rowing. On the other side I also tried a more broad launch. For these Steel indicated straight sweeps without leather buttom. [note: This is still the original kit´s version, but I think it will do the job this time.] Here we have the space for double banked use. The sweeps do not collide in the middle and the crewmen have enough distance to the rowlock to get a workable lever. This confirmes Allans original quote of Lavery's The Arming and Fitting of English Ships of War where he writes that "in 1783 it was ordered that all launches should be equipped to row double banked." And so I am thankful for the topic here, as it was filling the gaps of my puzzle and giving the right contemporary sources to finish it off. This means with my single banked 32ft pinnace from the first pictures I will fill every second thole, alternating on each side. Also the originally intended number supplied of oars (as for double banked and seen in the first pict) for this boat can be halved. Another question concernes the uneven number of oars on each side, in my 32ft pinnace 4 versus 3. Was this in use as for the uneven propulsion or was the bow place then left free? On the other side in the models of RMG there are many boats with a uneven number of tholes regarding the boat´s sides. As someone once called it "experimental archeology in miniature" 😉 I hope it supports or even confirms all the informations to be found in the previous posts. XXXDAn PS: Had a fast Photoshop and eliminated the supernumerary tholes. This gives a nice detail in between single and double banked boats even in stowed position. 🙂
Wonderful, once I saw this info I already found plenty of otherwise very true models showing this "feature" 🙂 But I would expect an even number of twarts for single banked, but there is quite often an uneven number. Does this mean the lesser side had to pull harder or was there one thole left free? Also there seems no rule as to what side of the boat has the most foreward thole. XXXDAn
Thank you bringing up this topic again, as I am at the moment working on that. After working on the sweeps and oars, the question was arising, as the oars prooved too long for double banked use. This thread nicely shows the solution as mostely single banked were used was for the "slimmer" boats. Nicely to be seen for my 1800 subject in the 1765 model of victory. I have the feeling too, that for single banked use oars with a curved blade were used, while for double banked use sweeps with a straight blade were preferred. At least the choice of RMG suggests this. Some more hints from the RMG, sorry I did loose the reference numbers on those ones. alternating single banked with oars double banked with sweeps: Special both versions? perhaps single bancked for 4 oars or alternatively 2 pairs of sculls?
