Everest
Posts posted by Everest
The backstays are what's called running backstays. If you look at the photo you will see a block on the backstay on each side,one on the port side and one on the starboard side. When in use the weather side is kept taught and the one on the lee side is slacked off. On a down wind run the lee side is unhooked from the deck eye bolt and run forward to the mast.
I hope this explanation clears up your rigging quandry.
- Mark P, Roger Pellett, mtaylor and 1 other
- 4
If you would like to save $200 go to Articles Database located at the top of the opening page. Everything you need to know about planking is in there, along with a lot of other information pertaining to ship model building. Articles about planking ,rigging, painting ,etc.
For a wealth of information on the SCHARNHORST go to www.maritimequest and click on links on the title page.Some good stuff there.
- greyhawk, CDW, popeye the sailor and 2 others
- 5
Try this. Using a 1/16" drill, drill a line of holes about an 1/8" apart away from the line. Don't force the drill. When that's done connect the " dots" with the xacto knife. Again don't force the tool. You will have to go over the cut several times. Then sand to the line.
Google the W.T. Preston, a stern wheel steam boat used as a snag boat on Puget Sound for many years. The boat is now a museum in Anacortes Washington. Interesting history. I used to see her lead the parade through the Montlake Cut on opening day of yachting season from Lake Union to Lake Washington.
- Canute, mtaylor, Gerhardvienna and 1 other
- 4
Blue Jacket Ship Crafters, in their book department sells two books on pond models. Both books are by M. de Lesseps. They are Pond Models and Pond Yachts How To Build And Sail Them. These books may have the information you're looking for.
Hi Maturin. I lived in Seattle for a number of years , and used to find specialty tools at a shop on Roosevelt Way N E. It's just north of the University Bridge.
Hardwick and Sons, Inc.
4214 Roosevelt Way N E
(206) 632 0678
Hope they are still their as it has been some time scince I I've been there
They had at that time a case of imported tools ie small planes, squares, chisels. etc, Neat store,
For any members who are using a Dremel 580 table saw, or are thinking of buying one on ebay, here's a
web site you will find informative . karincorbin.blogspot.com. Some good tips on maintenance and simple repairs, blade alignment, slipping belt and stiff controls.
I have one that must be close to thirty years old an is still going..
I think Beef Wellington is right. There is a wealth of information on here but you have to dig it out.
At the top of the web site page, NRG"S MODEL SHIP WORLD just to the iright of that heading there is The Nautical Research Guild home Page. Click on that.Scroll to ship modeling resources.Scroll down to Ship Modeling Database of Articles. Click onFraming and Planking.
Don't let the number of chapters throw you. There is a lot of info there' all of which you may not need to use.but there are some gems in there that you can use
You can do it. Take your time, but most of all ENJOY YOURSELF.
In all probability the shrouds are held aloft by what is called a thumb cleat. The only way I can discribe one is to say , it would look like one half of a boom jaw, only much, much smaller mounted verticaly on the mast. The shroud has a eye spliced in the upper end which is slipped over the top of the mast and rests in the space created by the thumb cleat and the mast, thus keeping the shroud from slipping down.
Try Blue Jacket Shipcrafters, at www.bluejacketinc.com They have a varity of cargo deck winches in different scales. Hope this can help you out.
On raw wood always use a primer or a sander sealer. What this does is to seal the pores of the wood. After sealing dust off the "fuz" with 400 grit sand paper. Do not use a laquer based sanding sealer with a brush as it dries too fast and will not give you a smooth finish. Try to use a primer of the same brand of paint you are using for your top coat .With acrilic paint use a synthetic bristle brush Take your time and brush in one direction, and remember two thin coats are better than one thick one.
- WackoWolf and CaptainSteve
- 2
WRITER’S BOAT MODELS
in Nautical/Naval History
Western Flyer is being reconstructed in Port Townsend Washington. There is a series of vidios on you tube about the ship and a short history.
