mnewsholme
About mnewsholme
  • Birthday 10/29/1972
  • Gender
  • Location
    Yorkshire, England
2,419 profile views
  1. Fusion 360 is free for personal use.
  2. Sounds like something that would be easy enough to 3d resin print. Do you have a sketch with some dimensions?
  3. Not much progress from last post I'm afraid. Not had much time due to work commitments and hull planking is least enjoyable bit of build for me. work should calm down a bit soon so can get back to it.
  4. Guessing could be either another Hms Bounty or Bounty launch given the date of release.
  5. When you start adding frames to the keel check that they seat down fully. I found the keel sat too low in the jig to allow this. I glued a 1mm strip to the jig (NOT to the keel) to raise the keel up slightly to allow frames to seat correctly.
  6. the framing diagram shows you which way round the frames go. The little chisel in a circle symbol means you need to bevel the edges of the frames. on the frames closest to bow and stern you will see a line etched on the wood on one side. You file each of the steps at an angle from the unmarked edge on one face down to the etched line on the opposite face. This creates the angle for the planks to flow correctly. Effectively your fairing the frames before you assemble them into the jig. The etched lines on the pieces need to face down from frames at one end ( frames 6-3) and face up for frames at other end frmaes 19-22). From memory a couple of the frames have the L and R labelling transposed., s you need to fit the pieces the opposite way round to get the etched face facing the right way.
  7. had a similar experience. I paid the amount stated in initial email by paypal, then didn't hear anything for a couple of weeks. Then got a shipping notification and can now see package moving on tracking. Pretty understandable that communications are a bit disjointed considering situation in Ukraine and incredible that their managing to run a business at all under circumstances.
  8. decided to put it on hold. just finishing hull planking on duchess. Once that moves to Rigging phase I'm going to do Cheerful in parallel and really make an effort to learn best methods of lining off and single planking. Just seems a much more manageable size to learn on. Then back to Winnie. I realise Cheerful isnt necessarily easier than Winnie, but due to smaller size I think I'll make progress a bit faster on it and keep interest better. I tend to always have two models on go at same time. One in hull phase and one in detailing/rigging, then when I get frustrated planking I do some rigging for a bit and vice versa. Problem is I have lots of hobbies and tend to bounce between them all quite frequently so progress can be very slow 😞
  9. Placed an order with Vahur a couple of weeks ago for wood package for Syren models HMS Cheerful in alaskan yellow cedar. Arrived last week. Very pleased with quality of wood and accuracy of the milling. Vahur also kindly supplied a sample pack of the other woods he can supply which also look to of great quality. Can happily recommend Hobbymill EU for anyone needing wood this side of the pond.
  10. making steady progress with 2nd planking. using shorter lengths of planking, which are more to scale than the the full length strips used for first planking which makes it a lot easier to get a good fit.
  11. I too was intrigued about customs from the U.S.A .to England . Having purchased H.M.S. cheerful from Chuck at Syren.
    It appears anything over £135.00 . ($170.00) you are charged £51.00 ($66.00) . My first package was under therefore
    no charge-my second package was over- so £51 !Whether it was because Cheerful was a revenue ship I dunno , perhaps I should
    have bought Winchelsea ...  now theres an excuse!
