dragzz
Everything posted by dragzz
  1. just earlier tonight I added the black strip on one side it came out extremely well i think here some pic
  2. thanks old collingwood airbrush i use really helps its came out looking great
  3. Ok On the hood I got some paint on the hull just the hull red there still i lot more to do here some pic
  4. This is the airbrush I will be using for my ships the is the iwata hp-th2 valt with .06 needle this works great
  5. Rjl thay look just fine to me As long as everything lines up on the decks when they're glued down that's a good thing
  6. hello rgl welcome to my build yes the decks sit flush test fitted the decks two times so it all good there
  7. I now have the Hull braces Installed on the hood hopefully I will have on white sealer primer on it tomorrow here some pictur
  8. Been there done that to many time old Collingwood just have to do lot of test fit is all
  9. This is the brace for the hull of the hood all 6 of them are to tall so the decks dont sit down right when people are building this kit watch out for that
  10. hello shipman and for me pe parts that u can get for the hood can cost just as much as the model itself this just might be out of the box build for me i will take out all the mold lines and get as much detail in as i can .thank you for your info shipman
  11. hello popeye its not to bad i went thu the box of parts late last night there a lot warp parts that i might to fix. i will try some tape see how it goes and let you all know hows it went
  12. thanks shipman i will just work on it day by day its all work just fine in the end
  13. This is not what I want to see on the hms hood model the forward deck almost looks like a banana the rear deck is just as bad the center deck has a small warp here a pic
  14. oldcollingwood i looked at that site wow what a site iam not to sure where a can get all the pe parts for that the hood 27 sheets of pe parts lol
  15. hello popeye not to sure about pe stuff and the wood deck will cost me 125.oo in canada thats a bit much for me i will try and get as much pe as i can for it hello thank you for following my build log nirvana old collingwood welcome to my build log and yes i will look into the link for mods thank vary much
  16. So as of right now I'm starting to get rid of the mold lines on the hull as you can see in the picture so far things going well
  17. hi popeye how have u been doing
  18. 51 inch long shes a beast this going to be a great build
  19. here a new build I'm going to be doing this is a plastic model which I have done lots of these I've had to put my other ones aside right now cant wait to get stared
  20. I build this kit before really fun and and enjoyable kit looking great so far keep up the great work
  21. Overall not too bad things are starting to go well and now got the keel in place still need a bit more sanding and stuff otherwise I think I've done pretty good so far let me know what you guys think
  22. From bow to stern there is now I want any gals all the way along for the rail cap which now when I did that took most of the damage away as you can see in the pictures so now I have to do is sand and start adding the Keel and Stern post wish me luck here's some pictures
  23. Popeye along the Edge from the stern to the bow is to be 1/8 inch and the 1/32nd depth I have to cut all the way around right where the damages but that may help I now have the solid Hall to its proper length that's what I've done
