Everything posted by Chapman
Because of the reduction in the number of gun ports by one, I made a paper template for the lowest row of guns on my Phenix model. This allowed me to check if the spacing of the reorganization was correct before I started working directly on the model. Maybe that would help you too. Edit: Helpful drawings for the arrangement of the gun ports of the different classes can be found in Les Vaisseaux du Roi.
- 445 replies
- soleil royal
- Heller
I drilled one larger hole in the center and several smaller ones on the four sides of the gunport, then used a No. 11 scalpel to cut from the center outwards to the sides. That was relatively easy. However, Heller's Phenix hull is relatively thin compared to the Soleil Royal.
- 445 replies
- soleil royal
- Heller
I found the passage using the right search term. It was the Washington Navy Yard, and a few years earlier than I remembered. It was 1809. The source was an internet post from a few years ago. And: definitely after 1809. It's possible the information came from the author of the book "The Washington Navy Yard".
- 16 replies
- USS Constitution
- Old Ironsides
Marcus, I've already read something about that. For the US: the earliest ones I know of are from the War of 1813, which were mentioned in connection with a US shipyard's history. Apparently, the first copies were in stock there and were immediately requested by one of the US Navy captains. Other captains were apparently out of luck for the time being. I still have the text somewhere, but I haven't found it yet. That's the problem with all the bits of information scattered across multiple hard drives. Someone really needs to compile it all.
- 16 replies
- USS Constitution
- Old Ironsides
I once rearranged all the gun ports on a Heller Phenix, and it was anything but pleasant. I managed it, but now I think a completely rebuilt wooden hull would have been more effective. You seem to enjoy working with plastic, so I wish you continued success.
- 445 replies
- soleil royal
- Heller
Attached is a link to a lengthy but successful conversion to the destroyer Z14 Friedrich Ihn, following some early wartime modifications. Z 14 Friedrich Conversion from Z17 kit
The only 1:350 scale kit that comes close to the Destroyer Type 1934a is the one from Zvezda/Revell, and that's a Type 1936. This means a lot of modifications, especially to the superstructure. It's possible, but involves a lot of research and work.
Suitable examples can be found in contemporary paintings, drawings, and models to illustrate the differences to boats from later periods. A friendly inquiry to Mr. Endsor about this topic, via his website, might also be a good idea. I found him to be a very friendly person to talk to. Edit: At this point, I would like to take the opportunity to mention his new book, which is scheduled for publication next year. The Lost Ships of Charles II's Navy: Understanding the Seventeenth-Century Warship by Richard Endsor
Restoration Warships by Mr. Endsor contains beautiful drawings with frame plans for the 31ft longboat 30ft pinnace 23ft yawl of HMS Lenox. The Master Shipwright's Secrets for the longboat and pinnace of HMS Tyger, based on a boats contract and contemporary models. They don't look strikingly different from boats from the 18th century. But the details make all the difference. Finding suitable ones for the scale of the Airfix Prince is a challenge in the first place.
Royal navy conversion of captured ships
Chapman replied to Aldaris's topic in Nautical/Naval History
Hi Aldaris Some basic information about the armament. https://threedecks.org/index.php?display_type=show_ship&id=4754 The NMM Museum might also have plans for the Holsteen/Nassau. -
Graf Spee colors
Chapman replied to scraig's topic in Painting, finishing and weathering products and techniques
If you want to use paints you already have that weren't specifically developed for DKM ships, you can simply check the model manufacturer's specifications to see if they would match the color of your desired model. Scalemates.com offers the option to compare paints across manufacturers. Experience has shown that the color on the screen looks different than the color in the can. And the contents of the paint cans vary slightly in color from batch to batch. In addition, some model builders wonder whether to use slightly lighter colors than the original to achieve the scale effect. Life can be so hard -
Review Le Coureur 1776 - Shipyard 1:72-scale Laser-Cut Card Model Kit
Chapman replied to catopower's topic in REVIEWS: Model kits
Regarding the Shipyard cardboard model of the Coureur in 1:96 scale. I wanted to modify the model according to the English plans as taken. However, I noticed a problem with the dimensions. I printed the English deck plan in length and width according to the known English specifications and placed it on the model. The length fits the model, but not the width, as you can see!- 12 replies
- Le Coureur
- Shipyard
18′ Cutter for Syren — Clinker or Carvel Built?
Chapman replied to glennb17's topic in Wood ship model kits
An addendum: I remembered that I have an article about the U.S. Brig Syren 1803. A Naval Architectural Study of the U.S. Brig Argus. BY W.M.P. DUNNE Published in the NAUTICAL RESEARCH JOURNAL Contemporary information exists (Argus Journal of Indents, Naval History Society Collection) on the three boats of the U.S. Brig Argus from 1803. It describes the cutter on board, its size (25 ft) and its equipment (with a well and windlass), but not whether it was a clinker boat. It seems doubtful whether any information about the Syren's boats can be found. Perhaps in the logbook, if it still exists. Based on current knowledge, I would build the cutter with carvel planking. -
Clinker boats are more difficult to repair, which is probably why the English preferred clinker cutters on board in their home waters rather than on long overseas voyages. I don't know how the Americans handled this. The US frigate Constitution has been quite well researched, and there is a wealth of information on the types of boats used on board. Author Tyrone G. Martin has compiled such facts in his literature on the Constitution. The USS Constitution Museum has also collected information on the boats. -
My respect for this amazing rigging on this scale. It requires a lot of patience and a steady hand. How do you motivate yourself?
- 324 replies
- Sovereign of the Seas
- Airfix
I have the following from Eriksen: CONSTITUTION All SAILS UP AND FLYING. Chapter on Flags and Pennants 1812-1815. Pages 142-145 From Captain Hull's log: "...then hoisted our Ensigns and Jack, at the Fore and Main Top Gallant Mastheads." Eriksen supplements this information with his interpretation for the flags flying on Constitution under Captain Hull. Stars and Stripes from the peak and a second flag with canton even high with the main topgallant masthead. The U.S. Union Jack from the foremast (same height), and the Commission Pennant from the main mast-truck. My addition: Hull was not a commodore in this case, so it is quite likely that no broad pennant is displayed at the time of the engagement with the Guerriere.
Hello Waldemar, Interesting project. I hope a better plan for the Randolph can be found. M.V. Brewington thought about the design of the first US frigates many years ago. His article, with plans for the first US frigates, can be found online. I don't know if you're familiar with it. Published in: The American Neptune Vol. VIII No. 1 January 1948 Unfortunately, the plan for the Randolph isn't any better there either.
