Everything posted by CDW
After the model was covered with dope and dry, I prepped the painted the entire model using sprayed on epoxy paint. The graphics were done free hand and do not represent any actual aircraft i am aware of. The 1:1 Fleet Biplanes were rather dull and bland in the way they were finished/painted. I wanted my model to stand out and be as easy to see while in the air as possible. I put the finishing of the model on hold after my brother passed away last year. I am resolved to finishing and flying it this coming year. Not very much remaining to do at all. As you can see, it is rather large, taking up almost the entire width of a driveway. It should fly nice and slow, and be very aerobatic.
After all the framework is covered with polyester, it is then covered with multiple brushed on coats of Nitrate Dope. I purchase Nitrate Dope from Aircraft Spruce, a company that carries all sorts of home made/experimental/light aircraft products. It is the identical product used on full sized aircraft. It is highly volatile and gives off a lot of smelly fumes. Very much a product to only be used in very well ventilated areas or even outdoors if weather conditions permit. This clear dope also fills the weave in the fabric making it fuel proof and further serves to tighten the fabric. When finished this way, the model becomes very strong indeed.
Once everything fits and is square/aligned, then it's time to cover the framework. Frames are prepared by sanding and applying a product called Balsarite. This product is brushed on over the entire framework and is a heat activated adhesive. This adhesive serves to hold the covering material in place and adhere it to the framework. The covering material I used in this application is called Koverall, sold by Sig Models. Koverall is a lightweight polyester fabric identical to that used on full scale home made and other light aircraft. It is first cut to fit then ironed onto the framework. The heat of the iron serves to activate the adhesive previously applied to the framework and it shrinks the polyester fabric to a drum-tight condition.
Once the model is framed up, then the (sometimes) tedious task of making certain the wings and stabilizers are all square is done. You must do some tweaks here and there to get everything lined up and the appropriate degree of incidence in the wings. With biplanes, this task is harder because there are two wings and it's just the nature of the cabane wires/struts that fasten the top wing to require adjustment to fit.
Next, I have to find a way to recreate the radial engine cylinders that protrude outside of the cowling. I decided to use basswood to represent the cooling fins of the engine cylinders. So, I used my handy-dandy Olfa Cutter to cut a gazillion circles of various sizes for the cooling fins and spacers. A dowel fits through the center of the fins and holds it all together. Next, the various other pieces are carved from balsa blocks. Once I am satisfied with the first, prototype cylinder, I recess the cowl and fit the cylinder to it. Now, this same process must be repeated for the remaining cylinders.
Here are a couple of pictures of the Saito 1.80 engine that will be used to power my model. Behind it in the background is a scale drawing of the actual radial engine cylinders in the 1:1 real aircraft. Remarkably, the Saito engine is very similar in size and profile to the real engine. The Saito engine will fit where the cylinder faces down when mounted on the plane.
Now comes construction of the cowling. it's a rather humble beginning with some huge chunks of balsa, but gets more interesting as shaping and construction moves on. Remember and look the first pictures in this post. The real aircraft had a radial engine whose cylinders protrude outside of the cowl. Will need to find a way to fashion some dummy cylinders to make this have a scale look and appearance. To insure a proper fit, the cowl is test fitted to the fuselage along the way and shaped accordingly. Lots and lots of filing and sanding goes into this.
Once the fuselage gets framed up, the cabane wires and landing gear wires must be bent and built. Steel wire binds the joints then silver solder seals the deal. Both the cabane wires and landing gear are removeable. This thing is starting to become rather large for my modest building room/area. I could move out to my 3-car garage, but it is not climate controlled and not very friendly to wooden models nor my body. The limits of my willingness to endure the drastic Florida heat and humidity will eventually force me to strongly consider insulating and air conditioning my garage.
The wings are generally the first thing I'll build when doing an airplane model. These wings feature a built up main spar consisting of two spruce spars and plywood sheet on each side of the spars making a hollow spar. The pictures show fairly well how the spar is built. Makes for an extremely strong but light weight wing structure. Both the top and bottom wings on this model are equal lengths. Except for areas where required, this model will be almost entirely built using Tite Bond as the adhesive. Where higher strength is needed, epoxy and fiberglass cloth. Certain areas of the main spars receive epoxy and fiberglass due to the fact the wings disassemble with a connecting plywood spar that slides inside the main spars. A model this size demands that it come apart for transport, then assembled at the flying field for flight. With a biplane such as this, it will employ functional flying wires and turnbuckles to hold it all together. Some thought is required to make it all easy to assemble at the flying field, yet strong enough to withstand the stresses of flight and maybe a hard landing here or there. I lay ceiling tiles on my building tables to allow for pinning down the wood structures when I am building them on top of the plans.
This 1:4 scale Concept Models Fleet Biplane is going to be built to fly RC using a Saito 1.8 cubic inch 4-stroke engine for power. The engine will be converted from glow fuel to ignition/gas or possibly methanol fuel with no nitro additives. Have not fully decided yet. When I am not ship modeling, I do a lot of scale model aircraft modeling as well. I prefer large models such as this 1:4 scale model, with a wing span of 7 feet. I bought the model and the engine from private sellers on the classified section of a popular R-C aircraft forum. That's a lot of wood in that box. About 20 pounds worth. Finished model will weigh approximately 20-25 pounds ready to fly.
Fantastic work. Looks like a challenge, learning to work with a card/paper medium, and you are mastering it for certain. Very impressive looking model in every respect.
- 244 replies
- borodino
- dom bumagi
Beautiful work as always, Captain. Do you know what type of ink is used for their printed card parts? The quality of it looks superb. This model kit overall looks to be extraordinary and you are doing it justice.
- 244 replies
- borodino
- dom bumagi
When I was a kid, about 11 or 12 years of age, entered my first model contest. Took 1st place with a model of a 1:24 scale 1941 Willys Coupe modeled after the Stone, Woods, and Cook, A-class gas dragster. Ended up winning several other competitions with that same model over a span of 2 years. Then took a hiatus from modeling while serving my country in the Marine Corps. After my service, got back into scale modeling and entered many regional IPMS contests, primarily to enjoy the work of other modelers, the comradery, and quite frankly always enjoyed competitive events. Somewhere in the 1990's got away from scale modeling while my career placed many other demands whose time restraints did not leave space for the hobby of modeling. Now that I am retired, have plenty of time to enjoy the hobby but am not so interested in competition any more. But I do want to attend the IPMS Nationals at least once before all is said and done. Maybe as a competitor, I don't know.
I guess my malfunction with minor things like that comes from many years of entering competitive events where every little nook and cranny of each model is scrutinized by judges. Plus, I am my own worst critic.
This photo serves to illustrate one of the frustrations with the Pontos wood deck included with my update set. The red arrows point out photo etch that circumscribe the deck elevators. These pieces fit into cut outs in the wooden deck so they fit flush with the deck, as do many of the other small photo etch pieces not signified here with arrows. The green arrows point out photo etch that also should be inlaid into the deck, but for some odd reason, the areas were not die cut as the instructions indicated they are/should be. As it is, I have glued the PE pieces directly to the top of the deck. Unfortunately, these PE pieces are not straight cuts, but curved in some cases, and trapezoid shapes in others. In other words, it would be very difficult to cut the deck by hand in order to recess these pieces as they should be done. I have not made up my mind yet, but am considering just leaving them as-is. It's not too noticeable as it is, and me trying to hand cut the deck may result in more of an eye sore than it helps. What do you think?
Sorry for being so gabby tonight, but I am going to mention one more thing. In about another 3 or 4 weeks, I will have the bulk of this model finished with the exception of the fighter and bomber wings. Once the bulk of the model is finished, it's going into the display cabinet until I get around to finishing all the aircraft. These will be repetitive and tedious to finish. Not something I am particularly looking forward to with eagerness. Each one will be fully detailed with photo etch and some with folded wings and dropped flaps. I have some more projects I am interested in starting and will do so just after the new year.
Wow, those guns are drop-dead gorgeous. Outstanding work,Slog. I had no idea card models could be built to this level of detail. If I were younger, I would give one of these a go, but alas, my modeling cupboard is full of many more projects than I have time to complete as it is. Cheers!
- 244 replies
- borodino
- dom bumagi
