AntonyUK
Everything posted by AntonyUK
  1. Hi Tom. It's nice to hear that you have made a recovery and getting back into ship modeling Nice work there. Coming along nicely. I have just started my build of the same DeAgostini victory. I also used Lime for the planking and Walnut. A question .. What is the notch in the keel for ? And a second question . Are you going to build as per instructions or bash the kit ? Regards Antony.
  2. Hi. Yea ..... you people know your ships . Anja wins. Photo taken in Plymouth sound. 10 miles away from me. Nice one. Regards Antony
  3. Hi.. That was an outside guess. Here is one for you. No clues at this stage. Regards Antony.
  4. Hi. Or the H.M.S. Pandora. Regards Antony.
  5. Hi. Is it the Nanuk ? Regards Antony.
  6. Hi With the Corel Victory cross section almost completed we ( me and my son ) decided to start on this build. I will bash the kit as and when we come to it. Lots of little things as far as I can see. We started by removing the frames from the laser cut boards. some boards were distorted a little but this is not cause for concern. a very sharp knife was used for this cutting both sides of the board. We then sanded most of the charring from the frames with a nail board. made easy work of the charring. All the frames were offered together and with minimum sanding to make a perfect fit. Then glued the frames together in place over photocopies of the master frame drawing.(7 frames 7 copies). Then all the frames were sanded and excess glue removed then stacked together with a false keel and cocktail sticks to check alignment. They all looked spot on to me Then we built a jig to hold the frames while assembling the keel and the frames. Degostini just used a scrap bit of the laser board as a spacer. Not to my liking as its easy to get a twist in the assembly at this point. What’s not shown is the square that fits on the top to hold everything square. And the Back board made from MDF with a photocopy of the master frame drawing. That’s about it now until next weekend when my son visits. Regards Antony and Karl.
  7. Hi. My views are different from the others. But seeing you have asked.. Not so happy with Corel HMS Victory cross section. Instructions are very poor. And Corel left out a lot of detail that could have been added. The wood was very good. But some of the fittings were unusable with out a lot of modification. Hammock stays we're trashed as the holes were at completely the wrong angle. Rigging blocks were trashed. Not all the fittings were there according to the list supplied. I don't normally diss things but this kit was poor. Regards Antony.
  8. Hi. Might be of interest to you.. Amazon UK sell some G clamps of the same size. Pack of 5 ref 59146. Regards Antony
  9. Hi A very nice model. Wow I have a long way to go to compleat with your standard of modeling. I like the colours for your timber. Regards Antony.
  10. Hi. Another update. On the rigging at the moment.. I like this bit The Hull compleated Another view. and another. Side view Stepes moded same as E & T did on his cross section. And prep on the rigging. Its half term now so no more until next week Regards Antony.
  11. Hi and welcome to MSW. I have just got back into model ship building and the choices are huge. I opted for building the Triton cross section. This option gives me the choice of timber and the amount of detail to put into the build. Also cost is low as MSW provide all the plans. There are several builds in progress at the moment and it might be of interest to you Best of luck Antony.
  12. Hi Michel. Have just finished reading through this build log.. WOW. I must say I felt like putting a "like" on every page you posted.. A fantastic build and the workmanship is astounding to say the least. And it's a very nice ship with some interesting lines. I have has the pleasure of sailing on one of thease some 16 years ago. Regards Antony.
  13. Hi. Watch the height position of the gun ports. My plan put then a little low. When I made up the guns I had to remove 3mm from the tops of the gun ports to make the guns fit correctly. So make up one of each size cannons and check from the inside that it will run into the port. As far as the cutting... Chain drill holes Keeping the drill at the same level as the decks. Then with a Very Sharp knife remove the rest. As E&T did. TIP :- When drilling put bit into drill then put a soft plastic tube on the drill bit to stop you drilling to deep and hitting deck furniture. Acts as a depth stop. Regards Antony.
  14. Hi. Just to Add. Apart from the details that Coral have got wrong.. the kit timber was OK and more than enough for the build. The only issue's that I have with the kit are The rigging blocks are very poor and I replaced 99% of them. And the Hammock stays are poor as the hole in them is at an angle. poor batch. Thease were replaced. Regards Antony.
  15. The Saga continues.. Gun ports cut into sides. All decks in place. And Hull planked. I have mislaid some photos.. Will find them and add later. Regards Antony.
  16. Hi This if my first build log ever... I will try and get it right. I liked Erebus and Terror build log on the Victory so I decided that this was the ship for me. A link to his Build... and very nice it is Erebus and Terror build log This ship is going to be a preasent for my daughter. First pic is Adding the Riders. One fitted more work on the other yet. Making the upper riders and the pump and well First deck done Thats it for now..will post the rest tonight. Regards Antony
  17. Hi Thomes. Your Victory is coming on nicely. Just watch out when you cut out the holes in the sides that you do not catch the decks with the drill or saw. I will try and post a build log tonight... Did not expect to to build so quick Regards Antony.
  18. Hi. A photo if much easer than words to understand. This also has a hole for the Mast so I can check on alignment as I build. Note that I have bashed the kit a little. Regards Antony.
  19. Hi. Looking good. Never tried the Gorilla glue. Might get some and do a few joins for testing. HMS Victory Cross Section by Erebus and Terror Corel, has a build log and it's completed. You are a quick builder Regards Antony. Edit and added :- When installing the decks..Watch that the frames don't get pushed out. I used a piece of plywood as a correct distance spacer and has a few elastic bands around the top of the frames to keep it in position.
  20. Hi Snowman. You are making a brilliant job of this build.. Your choice of wood and colours is fantastic and does you and the model credit. Please keep the pictures comming as I have yet to do my Trition build. Regards Antony.
  21. Hi all. I would love to start the build right now But the boss will not allow me to take over the conservatory. Thanks for the comments..The wood colour is important to me as I will not be using any paint on wood items. And the other reason is I need an thicknesser. Looking at the Axminster CT-356 at the moment. And a small bench saw. Make and model unknown as yet. Regards Antony.
  22. Hi. Just an update .. Most of my Timber for the build has arrived and is looking good. From Left to Right Maple, Sapele, Ash, Lime, Mohogany, and Walnut. Not starting yet...Need to finish the Victory Cross section Build. Regards Antony
  23. Hello Colin. Just finished reading your build log. Very impressive build.. Love the modifications you have made. My first magazine arrived yesterday so re reading to see if there is anything else I need . Please keep us informed on your build as its a leader as far as quality and workmanship is concerned. Many thanks Antony.
  24. Hi. Nice kit to get your skills up to date.. I have done exactly the same thing as you. It's been a few years since I touched model ship building. Adding the finishing touches to thr hull at the moment. No I did not make a build log as I am not much with a computer. But I have taken loads of photos.. Are you going to build as per plan or are you going to bash it as its called on the forum's. I bashed mine as I was following another victory cross section build. I also brought some books to help with the Bashing. Good luck with the build. As far as thinks to look out fore.. Quality of the work was OK. Rigging blocks were replaced. With scale blocks and of much better quality. Some of the fittings were not to scale.. I will start a log and post a few pictures later on tonight. Regards Antony.
  25. Hi. Very nice build and a nice model. Choice off colour's in very nice and does the ship proud please keep us posted as you progress through the build. Regards Antony.
