Everything posted by mbp521
I’m going to have to experiment with this method as well. Thank you. Roger, so do I understand this correctly, through this process there were no welded seams on the outside of the hull. The plates were butted up against each other and welded from the inside? Just curious, and want to get this right and if this was the case, what prevents water from entering the seams? I can see the benefit of the welds being on the inside of the hull, in that it would make it more streamline with no drag on the welds. -Brian
Keith, MDF is a fairly stable wood for forming the frame. It is a tad bit heavier than plywood, but makes a nice solid, sturdy base. As Eberhard stated above, as long as it’s is kept dry there should be no issues with it. Eberhard, I have a couple of experiments I am working on to simulate the welded hull. One of them uses aluminum foil tape over fine tread to show the weld lines. I am currently working on covering the bulkheads with basswood panels. Once the basswood is in place I’ll see which experiment works best. I hope to have some pictures posted soon of the progress. Work has been crazy busy, so my time at the bench has been limited. -Brian
Eric, apologies for missing your last update (#96), not sure how I didn’t see the post, but thank you for the mention. The ridge beam looks great! To help ease some the pain on the vent funnels, these were used to direct fresh air down to the gun deck for cooling and clearing smoke from the boilers. They could be rotated 360 degrees and could also be raised and lowered, or completely removed from their positions if needed. So in reality, there really is no right or wrong way to face them. As for the davits, I think you got this. I say go for it. -Brian
- 113 replies
- Cairo
- BlueJacket Shipcrafters
Happy to help out John, glad to see that you were able to find some local and avoid that international shipping. It definitely can get pricey. If you are looking for my construction of the paddlewheel, take a look at post #129 on page 5 of this build. That is where it starts and runs for a few posts. As for the dimension of the paddlewheel, in 1:48 scale the outer (larger) rings have an outside diameter of 139mm while the inside (smaller) rings have an outside diameter of 91mm. If you also take a look at post #490 on page 17 of this build,, I have some close up pictures of the paddlewheel frame on the Cairo display that I took last year, you can use for a reference of it's construction. -Brian
I will definitely following along on that beauty! Looks like fun, can't wait. 1:24 *cough *cough....😁 -Brian
Absolutely amazing details Keith! What a fantastic journey it has been following along. Can’t wait to see what the future holds for your next project. -Brian
Hi John, glad to finally be back at it and that you like the lights and led's. I used 4mm double sheaved blocks for the gun carriages, and for the ropes I used .025 (.63mm) rope for the training tackle and .045 (1.14mm) rope for the breaching ropes. I ordered these from Chuck at syrenshipmodelcompany.com and I do believe he ships to the UK, but you may be able to find somewhere more local, like Cornwall Model Boats to avoid international shipping fees. Hope this helps you out. -Brian
Hello again everyone. Made some progress this past weekend, not a lot, but some. I managed to get the main deck cut out and sized to the plans. I built up a table saw slide to cut the rabbets for the bulkheads. Next, I glued all the bulkhead templates to the 1/4" MDF and got them all cut out. Here are all the bulkheads lined up on the deck template. First bulkhead getting glued in place. More bulkheads going in. Not sure why, but I couldn't get this particular picture to insert right side up. And more bulkheads getting glued down. Slow tedious process. And all of the bulkheads in place. That is as far as I have been able to get this week. Hopefully more progress next time. I'm going to work finish up with the #1 bulkhead then on to getting the bulkheads shaped and faired, then start working on the hull plate templates. Thank you all for the like and stopping by. -Brian
Not a bad idea. We’ve had some company before that belonged in a barn. 😁 That is somewhat the role of the current MV Mississippi V. Going off the stats, she is the biggest towboat on the Mississippi and is use by the Corps of Engineers as their flagship. I wouldn’t mind touring that one as well. Too funny Keith. We’ve been together for 34 years, I’ve got a feeling if she hasn’t got rid of me by now I’m in good shape. Either she a glutton for punishment or she’s just keeping me to protect other women from having to deal with me. 😁 -Brian
USS Cairo by Zetec - 1/50 scale
mbp521 replied to Zetec's topic in - Build logs for subjects built 1851 - 1900
Zetec, great start! Nice work on cutting all those bulkheads and keels by hand. -Brian -
Thank you Eric. My workspace isn't a whole lot to brag about. I just have a yard sale geek desk in the corner of one of our spare bedrooms with the Hobby Zone storage units. I share the room with my other desk I use for my home office. My plan is still to build out one corner of our barn to incorporate my office, shipyard and reloading room, some day (hopefully soon). I have been taking up the spare bedroom for the past few years and I am surprised the Admiral has not told me to pack it up and remove myself from the premises. I have a feeling it will be coming soon. Thankfully we have not had any company that would require the use of the room during this time. -Brian
Give me a couple of days, I'll take care of that. 😁 One of the reasons I joined the Air Force was the main areas of industry back home were either work at the refineries or work the port docks. Neither sounded very appealing to me. Looking back though, it might have been interesting to work on these boats. Just the scenery alone would have been worth the hard work. -Brian
Excellent info Keith, thank you. While I was reading the article I noticed that they discussed the M/V Mississippi and all of the previous boats to carry the name. When the Admiral and I took our trip to Vicksburg last year, we visited the Lower Mississippi River Museum. They have on display the fourth M/V Mississippi (the first diesel powered vessel to carry the name) and of course, we took a tour of it. Beautiful museum boat. These guys had very nice accommodations. -Brian
Alrighty, I figure it's time to get this thing started. So I managed to get the bench cleaned off and ready to go. The plans have been scaled and marked up. I went through and got my measurements, divided up the hull bulkheads and made a few adjustments to the plans to reflect the differences between the actual boat and the drawings. Not too many adjustments were needed, just a few structure details that didn't match up. The plans are on the wall. When I was at the printshop the first attempt at printing didn't come out to the right scale (they came out a bit too small). The clerk was nice enough to give me those drawings free of charge, so I will be using those as my wall reference and I can use the correct scale ones for my templates and other measurements. This worked out better since the smaller scaled ones fit better on the wall. I got as far as printing out most of the bulkhead templates. These will be glued to some 1/4" MDF then cut out and shaped. No hold details will be done on this build, so the hull will be the basic POB. Still trying to decide on if I will plank the hull with basswood strips, then smooth out the lines with body filler, or just go ahead and cut out the hull shapes from 1/16" basswood boards and shape it from there. I would like to try and simulate some of the steel plates on the hull If possible, to give it a little more detail. I've got some time to figure it out. Not too much more to report on this update. I have the main deck printout cut and ready to build, just need to make a run to the lumber yard for supplies. I thought I had enough MDF to get a good start, but I seem to have come up a bit short. In the mean time I am going to get the bulkhead templated glued down and cut out and hopefully next time I will have more progress. Thanks for stopping by. -Brian
Kurt, that makes perfect sense. There are many twists and turns along the rivers and some of them fairly sharp. I can see where a long line of barges could be difficult to navigate as well as current speed being factored into the equation. I can't speak for other rivers, but I know for a fact that the Mississippi runs a whole lot swifter when the water levels are higher than when its low, and I'm sure it is a struggle to get those barges upriver fighting that swift current, or controlling the turns going downriver. Keith I totally agree. Too many barges can be a disaster waiting to happen, that may be what is going to transpire in that photo. From the looks of it the pilot does have the starboard engines running full speed or all rudders are hard to starboard. He definitely looks like he is trying to turn it around.😁 Eric, in my Cairo research I ran across many instances where the ironclads would have their coal barges lashed to the sides of the ship. This could be one of the transition periods where riverboat pilots were getting away from "towing" then and migrating towards "pushing" them. Although pushing the coal barges with the ironclads would not be the most safest thing to do, especially with an 8" and two 42lb cannons pointed in that direction. 😁 Also, Great point with the phone example. I hadn't thought about the transitioning from towing to pushing and just having the name remaining out of habit. -Brian
Beautiful pictures Keith. The bridge in the top photo reminds me of the John James Audubon Bridge connecting New Roads, LA to St. Francisville, LA not too far upriver from where I grew up. The bridge wasn't built until 2011, but it is a beautiful example of a modern suspension bridge. I often wondered (especially as a kid) who came up with the naming convention for these boats and what they were thinking. Just some of my random thoughts running around in my little pea brain. 😁 Tugboat: somewhat makes sense, generally they tug on the lines of the larger ships. However, they also push on the big ships as well. Towboat, on the other hand, just pushes. That is just my presumption, since I have never seen them actually tow anything, just push. Also, this was not an uncommon sight in Baton Rouge. 50+ barges going up/down the river. I would guess (without researching it) that the amount of barges lashed together would only be limited to the pushing capacity of the boat, the narrowness of the river or locks, or the width of the bridge pilings. I would assume that there are maritime laws governing how many can be moved at one time for safety reasons. -Brian
@kurtvd19 @Keith Black Fascinating information! When it gets broken down that way, it doesn't seem so expensive to transport goods via barge. Too bad barges are limited to the rivers and the trucks and rail cars are still needed to distribute to the other areas not accessible by river. Otherwise, prices of said goods would be considerably cheaper. -Brian
Roger, I know I am somewhat late to the party, but I ran across this and just finished reading through this beautiful build. I envy you guys that have the talent to work with metal and get the nice crisp, clean results. Most of the time I try to steer clear of metal work, only because it's a medium that I have little experience with, as well as the tools. Maybe one day. -Brian
Keith, by no means do I feel that way. I love the conversation and information. These details are something that I hadn’t really given much thought to, I have been more focused on the structure itself. I’m alway happy to learn and discuss more of the intricacies of the boats I’m building. Funny you mention that. As soon as Keith Black threw those fuel costs out there, my first thought was they had the right idea back in the day, sail power was so much cheaper. A lot slower, but considerably cheaper. -Brian.
Nice job on the alterations. Glad to see that you were able to locate your missing block assembly. Nothing more frustrating than having to re-do work. How right you are, finishing up a build is a lot harder than it seems. I still look back at my previous ones and think, I need add a little bit of this and that, or a tweak here and an adjustment there. -Brian
