Posts posted by Keith Simmons
The bulk of the rigging is now done. Lots of clean up to do particularly where the stays meet the deck, but overall it's the best I can do. I now have to add the aerials. I have used two diameter rigging line, the smallest the size of a human hair and just as hard to use but comes up OK.
Very nice work Greg, I really like the ship...
Hi Keith
Nice to see the sails temporarily set up. With her raked masts and lofty sails, she looks fast just sitting there.
Nice job.
Cheers
Patrick
Thanks Patrick, had a bit of a problem with the sail configuration and I am in the process of rethinking rigging. The real problem of design on the fly is when it doesn't look right , it doesn't look right ..lol. Hopefully I get it right this time...
Hi Keith,
Interesting build, wish I had the skills and tools to build a ship from scratch.
For interest sake, the correct spelling in Afrikaans would be 'Weerligstraal', we also make use of word 'Bliksem straal' as Piet mentioned above.
Thanks Jolley, appreciate the input, Since I was using African woods or this build I looked up Lightning Bolt and saw the current spelling. I actually like the correct spelling better so I will use that on name plate.... thanks again....
- Omega1234, GrandpaPhil, Piet and 2 others
- 5
welcome to the log Bill sometimes, I do wish I had some of the cool tools.......but I think how well I've gotten on without them, and a lot can be accomplished with a box cutter and miter box / saw. one of these days........maybe thanks for the good word!...pop in anytime...
thanks Bob........I enjoy fitting the layout...all the fiddly bits and stuff. thanks for the good word!
yes Kees.......I've made the gallows out of wood....still need to flesh out the mast and booms a bit more. I have a double spool winch which is the last bit from all the extra Nordkap parts I had. the port holes and window frames came from that kit as well. I also want to put a single gallow on the port side, so I'm looking into scratch building some smaller winches. still more to go.......still more parts that I've already made to go on still. hopefully, I can add some of the detail that you do very nice work you do
had to work Tuesday night, and wasn't feeling well during the day.......so not a lot got accomplished. perhaps today will be better
Looking real good Popeye, she's going to be sweet when done....
Hi Keith
Nice start. The method you're using is similar in many respects to a 'bread and butter" method, which is quite popular for modellers.
Regardless of that, the first picture shows that the hull's going to look pretty darn good, with a nice profile to it. It's a bit like a butterfly waiting to emerge from its cocoon.
All the best
Cheers
Patrick
Thanks Patrick, I had seen the bread and butter method but was looking for a way which used a lot less wood and would be much closer to the finished hull. Minimal sanding is my goal..lol
By stacking my "planks" from 15 degrees to 22.5 degrees I start to create the hull shape. Once I get close enough to determine my keel width, I block off the bottom to accept the rabbeted keel block. At this point it is just a matter of sanding for shape. As I said before, I believe you can create any shape using this method just by placement of angles along the hull. Add a keel, clamp in vise and you are ready to start building sterncastle and the rest of the ship. We will see how this one turns out...Thanks for the look, hope this was helpful to those that might want an easier and faster way to make a hull.
Hi all, considering that I do fantasy ships , I have been experimenting with ways to make a hollow hull without using the usual method of a frame and planking. I found a couple of old pallet skids in my garage that turned out to be Red Oak .This hull was built using my table saw and chop saw. I dressed out the oak to 1 1/2" W x 5/8" thick on my table saw and began cutting angles .
First, I eyeball the bow angle and cut them with a handsaw, this is where I decide the width of my hull, then I start cutting angles on the chop saw. Once I have the basic deck layout I run the "planks" through the table saw at 15 and 22.5 degrees and then rabbet them to accept the vertical decking.Then it is just a matter of build up the hull. For this hull I used only 2 dominate angles 35 and 22.5 degrees, in theory i should be able to place any angle anywhere along the hull do create the desired shape. -
I have never carved anything but a turkey before, but considering Lindworm is Viking for dragon thought I would try a figurehead for this build. Made out of Mahogany, Maple and Bubinga. Not sure if it will work but I may have found a new dimension to my ship building... Now the wings on the hull make some sense.
- prutser, mtaylor, popeye the sailor and 1 other
- 4
Hi Popeye
If I was ever able to make a frame like that I would stop right there and display it by my front door..lol. Looks great ! very nice job.
- popeye the sailor, Omega1234 and Piet
- 3
Hi Keith
I'm not sure how, or, why, but for some reason, the hull looks a lot like Jules Vernes' Nautilus submarine. I like it!!!
The other thing I like is the fact that you're applying your imagination to such good effect. Throw out the rule book and just go where your heart and imagination takes you.
Nice and refreshing, I say.
Cheers and all the best.
Patrick
Hi Patrick, Thanks a lot, I really like to start a ship and see where the process takes me, kinda fun that way. I believe I have come up with an idea for the finished ship, I hope it turns out as cool as I see it in my head....lol
Hi Keith
Very nice and I can't wait to see her all rigged and ready for the maiden voyage.
Cheers
Patrick
Thanks Patrick, as soon as I get The Lindworm ready for rigging I will rig all three ships at the same time. I sometimes get distracted by another design..lol
Well, finally have the hull and deck planked, time for a little thought as to where I go from here. Guess I can do that while I'm sanding ... The bulk of the hull is planked with quarter sawed African Mahogany ( which I call Bubble Wood ) , the transom was made with rough sawed African mahogany as well.. The lines of the hull are broken up a bit by the Bubinga wings but still has the sleek look I was going for. The deck is planked in Maple, forgot to take a picture of that.
Back to the drawing board... Thanks for taking a look....
Hey Popeye, very clean looking build, everything thing nice and straight. I'm jealous..lol
- Piet, mtaylor, popeye the sailor and 1 other
- 4
HinKeith
Well done so far. The hull's taking shape and she certainly looks like she's an interesting design.
Keep up the good work.
Cheers
Patrick
Thanks Patrick, I am looking forward to see how it comes out, have a couple of ideas. Now just have to see if they fit..lol
Once I had a basic shape I decided to run some African Mahogany planking so I could figure out how to fill in the bow and stern with solid blocks.I then added a Mahogany keel strip to help me eyeball the bow rise. Not sure what happened but I saw something and went off in a whole other direction. By adding Mahogany bow and stern sections I elongated the hull by several inches and that is when it became a dragon ship. The middle section looked like a belly of a beast and changed my plan, so I added blocks at the keel and transom lines to allow for diagonal planking. From here on anything is possible as the ideas are racing around in my head...
Hi all, this is my first attempt at mapping out a hull design.With no particular ship in mind I started out by making a grid on a piece of cardboard and drew a basic deck outline.With that done I cut out some cardboard ribs to form the middle section,
then using spacer blocks to stand the ribs up I adjusted the shape of the hull by eye with sandpaper and a utility knife. At this point it looked like I was going to end up with some sort of cabin cruiser.
Looking around the shop I found some old scrap squares of 1/2" plywood to use and started jigsawing out some ribs.After getting what I thought was the bulk of the middle section cut out I assembled them with 1 1/4" spacers. I then clamped the whole section in my small work table and proceeded to shape the frame with an orbital sander. Here is where my mind starts to race..lol
Kalavente by Keith Simmons - FINISHED - An Elven prayer ship
in - Build logs for subjects built 1501 - 1750
I decided to try a more advanced style of a hollow hull and as usual with no specific theme in mind..lol. I started with some scrap pine and ran it through my table saw at a 22.5 bevel. Then just started to to glue them up to a 33.5 degree keel.
At the water line I reversed the angle and extended the hull to a desired deck width. Once that was done I added cross members for the decking and strength, ran the Cherry decking and sat back looking for a theme. Then it came to me, a Timber Framed sterncastle and of I went creating an Elven Prayer Ship. Silly I know, this stuff just comes to me...lol.
The ship is made of just Pine and Cherry, and the final design is still evolving, hope you like the end result and the " hollow hull " evolution. Thanks for looking...
