Baker
Everything posted by Baker
  1. Not so far away from Verrebroek Small "two-week" update location the location of the holes, drilling the holes and hammering treenails : a slow but steady work in progress
  2. Small update. A Hetzer ready for painting And a camouflaged Hetzer.
  3. If you use linen, you can rub the sails with beeswax. This makes the linen less "fluffy" and a bit stiffer. And yes. Linen sails are actually a little too thick for this scale (1/45)
  4. Just an idea. Why don't you make 2 if you're going to scratch build. One with all the tools for models under construction. and one as a "showroom" for finished models
  5. To return to the original question. A wale is not mounted on the planks. But it is actually a thicker plank (beam). which is mounted before the hull planks are applied. So it is in the same line as the planks and can not cross the strakes.
  6. https://www.cornwallmodelboats.co.uk/acatalog/Model-Boat-Timber-Wood-Dowels.html
  7. Thank you The Airfix Matilda is actually their old model, supplemented with newly designed pieces for the Hedghog. I think a Hetzer is always something special. For this Hetzer, I think parts were "borrowed" from the Esci Hetzer
  8. My last 4 "modern Russian" kits. All 4 are from ACE on a 1/72 scale We start with BREM-2, a recovery vehicle based on the BMP family. http://acemodel.com.ua/en/model/108 The box Content. As mentioned earlier, these are short run kits. Special but with some extra work... I've have this kit for years. One of the reasons I never started it, a lot of cleaning up to do And the first pieces don't cooperate from the start. But, with time and patience, a model will eventually emerge
  9. Small update. Applying the tracks. A bit of fiddling, but now they are completely applied. And the Matilde is ready
  10. Historically not. But if no one tells your uncle Jay about this, he probably won't mind this little error 😇 Normally there are 3 schrouds at the top mast, (i see only 2)
  11. While I'm working on the treenails in the hull of my Mary Rose . It's time for some variety. So now some military models. We build the 38t Hetzer Starr from Attack hobby kits. Not the most fitting and detailed model, but a somewhat exotic Hetzer. General info about the Hetzer https://en.wikipedia.org/wiki/Hetzer And the "Starr" variant https://www.armedconflicts.com/Jagdpanzer-38-t-Starr-t12128 Box, parts and plan Building the chassis, this wasn't actually that simple, there was nothing that fits. Cleaning and drilling the wheels All is ready to apply the tracks ( Only the idler wheels could be mounted without fitting and cutting ) ( with a Airfix Matilda hegdehog almost finnished)
  12. Batavia. The curved planks on the stern are a protective layer of soft wood against shipworm. An early form of copper plating.
  13. Goedemorgen buurman 😉
  14. Treenail update, The weather forecast has been the same here for several weeks : rain and occasional showers... So a lot of time to drill holes and add treenails... After all the treenails have been applied it is time to scrape and sand. Pieces of old Stanley knives are used for scraping. The original and the model (picture of the original is thanks to @firdajan) After sanding, the hull was cleaned with a wet cloth. The starboard side is ready. Wales still needs to be done, probably also with treenails, and bolts??. I sent this question to the Mary Rose museum, but no response yet Thanks for following
  15. Very, very beautiful model👍 It was nice and interesting to follow
  16. Looking at the parts and the model, still the same as it was 35 years ago when I built my first one. So you are the one who builds those beautiful machines
