Everything posted by Baker
Russian modern armoured vehicles by Baker - ACE - 1/72
Baker replied to Baker's topic in Non-ship/categorised builds
The side skirts, all other parts and some extras are in place, so the model ready for painting Next, 3 armoured cars. The idea is to build them in a series Unlike previous models, sharply cast parts -
Last update of 2023 The scarfs in the keel parts have treenails and the battens have been applied. I'm not going to add any iron bolts or nails. All iron fasteners were caulced or shielded with wood (bolts in the keel) and are therefore invisible. If the seams between the planks are too wide and caulcing will not stay in place. What are you doing then.. knock a batten over it, and case closed. Personal view, I think it's a horrible sight. Battens And on the model The hull has only been sanded with 120 grit, so it still needs some better sanding. The next step is to install a deck and plank the stern. A happy 2024 to everyone
I built my Heller SR 40 years ago. good luck
- 417 replies
- soleil royal
- Heller
Planking at the bow is tapered. Forget YouTube for a moment and read some PDFs first. Remember, planking is not a race. First read the pdf'S, then think how you gowing to do the planking, then try if the plank fits and only then gleu the plank on the model.
- 26 replies
Because applying the wheels and tracks is a delicate job, this is being done now. Step by step and partially painted. Ready to continue painting and mounting the skirts -
For a first time planking, very good. But Take your time for the second planking, this will largely determine the appearance of your model later. Also take a look at your cannon ports, they don't all seem the same size on the picture
- 26 replies
Golden Hind by Rock_From_Korea - 1:48
Baker replied to Rock_From_Korea's topic in - Build logs for subjects built 1501 - 1750
Congratulations Nice work Rock -
Looks good. I would give it a try with the Scotchbrite sponge. this is smoother and softer than sandpaper. Best is to "practice" on a waste piece first
- 508 replies
Jagdpanzer 38(t) by Baker - FINISHED - Starr - 1/72 - PLASTIC
Have you ever thought about a light "sanding" with some Scotch Brite? (the little sponge you use to wash dishes)
- 508 replies
@md1400cs Thanks Michael But keep in mind that 1mm treenails for 1/50 scale is the limit. Actually, they are already a bit too big for this scale @Roger Pellett Thanks Roger The shape of the hull also surprised me. I actually expected a plump hull. But the hull of this ship is indeed very elegantly built.
Well, We have 2 Samsung A22 The settings are exactly the same on both devices. Both phones are connected to the same Google account On one, Google Chrome and Microsoft Edge work both perfectly On the other Chrome doesn't work, but Edge does. Why?? So for this problem, changing to another browser is for me the easiest solution @Knocklouder do not by a new phone @James H Can I click on my own post, as "mark as solution"?
Building the chassis The base: the bottom and 2 sides was a challenge The next parts even more. (That's why it stayed in the box on the shelf for so long....) With time and patience . There is a chassis. Thanks for following -
Nice start. I follow also And yes, I have also glued my fingers with CA glue. Advice, take your time. Building a wooden model is not a race
- 26 replies
