Baker
Everything posted by Baker
  1. Building the chassis The base: the bottom and 2 sides was a challenge The next parts even more. (That's why it stayed in the box on the shelf for so long....) With time and patience . There is a chassis. Thanks for following
  2. further findings. Don't buy a new phone yet. On my Samsung smartphone, MSW works perfectly via Microsoft Edge. Try this first. msw via Google Chrome is still a problem for the time being.
  3. Nice start. I follow also And yes, I have also glued my fingers with CA glue. Advice, take your time. Building a wooden model is not a race
  4. Thank you for looking into this. Apparently the problem is in my smartphone. My wife has the same A22 as me and on this phone i dont have this problem. I guess I'll have to solve this myself. To be continued, I will let you know if I find the solution
  5. My phone is a Samsung A22 He did an update on 28 november. But the problems only started yesterday afternoon. (Now I use my laptop) Really weird When I watch MSW as a "guest" everything is normal. When I log in, problems
  6. Since this afternoon, MSW looks like this on my Samsung smartphone. No settings have been changed and the phone has been restarted
  7. congratulations. Nicely done. Your customer will certainly be happy with this model
  8. There is a 3D topic on MSW https://modelshipworld.com/forum/34-cad-and-3d-modellingdrafting-plans-with-software/
  9. Yes, but : but I was a bit lazy. If I have calculated correctly. I need at least 30 meters of treenail material, only for the hull ( one side was 15 meter)
  10. Not so far away from Verrebroek Small "two-week" update location the location of the holes, drilling the holes and hammering treenails : a slow but steady work in progress
  11. Small update. A Hetzer ready for painting And a camouflaged Hetzer.
  12. If you use linen, you can rub the sails with beeswax. This makes the linen less "fluffy" and a bit stiffer. And yes. Linen sails are actually a little too thick for this scale (1/45)
  13. Just an idea. Why don't you make 2 if you're going to scratch build. One with all the tools for models under construction. and one as a "showroom" for finished models
  14. To return to the original question. A wale is not mounted on the planks. But it is actually a thicker plank (beam). which is mounted before the hull planks are applied. So it is in the same line as the planks and can not cross the strakes.
  15. https://www.cornwallmodelboats.co.uk/acatalog/Model-Boat-Timber-Wood-Dowels.html
  16. Thank you The Airfix Matilda is actually their old model, supplemented with newly designed pieces for the Hedghog. I think a Hetzer is always something special. For this Hetzer, I think parts were "borrowed" from the Esci Hetzer
  17. My last 4 "modern Russian" kits. All 4 are from ACE on a 1/72 scale We start with BREM-2, a recovery vehicle based on the BMP family. http://acemodel.com.ua/en/model/108 The box Content. As mentioned earlier, these are short run kits. Special but with some extra work... I've have this kit for years. One of the reasons I never started it, a lot of cleaning up to do And the first pieces don't cooperate from the start. But, with time and patience, a model will eventually emerge
  18. Small update. Applying the tracks. A bit of fiddling, but now they are completely applied. And the Matilde is ready
