Srodbro
Everything posted by Srodbro
  1. It only reinforces the joint. Any farther in would obstruct the holes for belaying pins. I also anchored the fife rails to the deck with brass pins. . I used the same method on the channels and pinrails, as well.
  2. I’ve followed your build with interest. Nice work. One suggestion: You might consider reinforcing the joinery on your fife rails as I did with a bit of brass wire. Later on when you are rigging, a bit too much tension on a line could cause the rails to come apart at a time in the build when repairing the fife rails would be extremely difficult ( as I discovered to my dismay on a previous build). Just a thought. Here is a pic of what I did on my Niagara fife rails.
  3. Much depends, I suppose, on the scale to which you are working. On my Fra Berlanga ( approx 1:100), I modeled the structure of wood and styrene, applied clear plastic painted on the reverse with black, then used styrene “ angle iron” strips to detail framing around each window. If I was working at a smaller scale, I might cut a window hole as well as I could, then trim around the individual opening, maybe with card strips, or ( what I have become enamored with lately) aluminum tape ( as used by insulation and sheet metal workers) painted, cut to size with scissors and applied around the opening.
  4. Here’s a quote from Brown’s book: ”As the days grew darker and colder, the men tried to prepare themselves psychologically for the dreaded monotony of the long winter they faced living in the deserted, frozen expanse under a dome of perpetual dark. The daily routine, as far as anyone could predict, would consist of magnetic observations, hunting, taking care of the dogs and feeding themselves, with only a few extended excursions to pass the many months. The members of the small band had already grown tired of each others’ company, and with little to occupy them once winter set in, the lack of new company proved to be the greatest challenge.” Add to that the discovery of blond haired, blue-eyed Inuit several years later … Yeah … plenty there to dramatize!
  5. See Harvey’s post #1 ( there is an English version of Northwest Passage) and the book The Last Viking by Stephen Brown.
  6. Being grandson to a blacksmith and great-nephew to a wheelwright I was attracted to this kit as a break from model shipbuilding, and I have just finished building it. I found your build log very helpful especially for the reach-fifth wheel assembly … I agree, the instructions could have been better in this regard. Regarding the question of when to paint the Britannia fittings: There seems to be no avoiding several attempts, whether painted prior to assembly or after. Seems every modeling session included painting and touch-up. Regarding the wheel spoke length: You are right, they are exactly the right length. In fact, I found that after cleaning the char from the spokes and rims, the spokes were too short. I solved this by wrapping the interior groove of the hubs with several turns of tape to effectively make the hub diameter larger. The kit, I thought, was deficient in a couple of ways. First, there is no detailing of any breaking mechanism. Second, and more frustratingly, there is no means for attaching the wagon to a horse, even after purchasing the single horse harness-hitch kit. Conceivably, the mysterious “axel couplings” might have been intended to facilitate the attachment of the poles running from the front axel along the sides of a horse for steering, but there is no hint in the wagon kit ( nor in the harness-hitch kit) that this is the case. But, I couldn’t have been too disappointed with the kit since I have recently purchased the beer wagon and two-horse hitch kits. Again, it was a big help following your log.
  7. I spent some years designing dust and fume collection systems for laboratories and research facilities. Most devices like this are of little value; it’s the nature of the beast. Try this experiment: Get your vacuum cleaner hose, and hold your hand a 1/4” from the nozzle. Feel the air movement? Ok, now move your hand 1” from the nozzle: you probably can’t feel air moving, or just barely. 2” away you feel nothing. Now, connect your vacuum hose to the discharge of the vacuum ( if you can). You can hold your hand several feet from the discharge and still feel the air movement. Why the difference? Air best flows to where it is pushed, not pulled. The suction of the hose is relying on barometric pressure to push the air into it ( essentially, the vacuum hose creates a “ hole” in the surrounding area near the nozzle that the air “falls” into). On the discharge end, the energy from the vacuum cleaner motor has been imparted to the air and will move with more force. To better control the particles in the air, get a small fan to blow across your work surface away from you.
  8. Glad to see you are back. Yeah, looking forward to doing ratlines is about the least motivating step in a build, but once they are done, you are so much closer to doing running rigging, which I think is motivating. Great looking build.
  9. Any words of wisdom regarding the veracity of other woods they sell, like Cherry or walnut?
  10. I recently completed my version of Gjoa, which I did with sails. I had the same question about that item, and as near as I could tell it is where the sheet of the fore staysail attaches to the rail traversing the deck forward of the mast. I think the term comes from the idea that this line would “ slap” from port to starboard ( or vice-versa) while tacking. Here is a not so clear pic of my model with the subject circled in yellow. At least, that is how I interpreted it. Though, keep in mind my Norwegian is limited to “ Aquavit” and “Skol”!
  11. I am always blow-away by the micro-soldering skills on these forums. Wonderful work!
  12. Your boats are progressing nicely. I am concurrently building Morgan and Kate Cory whalers, and decided to first build all the boats for both (like 12 of them). There are some really good examples of whaleboats built by other modelers on these forums, and I cannot dare to compare in the finished quality. I have never had success at grinding/ sanding the interior of these small boats ( uneven, poke-thru’s). So, I used a different methodology. Using the lines provided on the kit drawings, I built a mold upon which I assembled keel and paper ribs, then planking. Filling and sanding gave me a thin hull. Now, honestly I used the center “ scrap” portions of the laser cut boat parts for my mold pattern, so dimensionally I am not super accurate. Nonetheless, I found it sufficed for my purposes. Now, my craftsmanship is far below that of others, but with a bit more patience and skill, and attention to detail ( like more attention to uniformity and number of ribs, etc,) I think this methodology used by the right hands, could be a viable building alternative. Just a suggestion. Love following your progress.
  13. Missing your posts. Great work.
  14. When drilling holes in, say, a farelead, ….several aligned holes in a small piece of wood, or a hole near the end of a piece subject to splitting, I’ve had luck first coating the wood with CA, letting it dry, then drilling. Drill first with your finest bit, then enlarge. Seems to form a chemical matrix on and in the wood that reinforces it. But, consider how you want to finish the piece, since stain won’t agree with the CA. Good luck.
  15. The model color looks pretty close to the color it was in 2018 when I took this pic. Tho, the light level may affect the perception.
  16. Another pic from the kit is of the Dan engine. This view appears to be looking aft. At the fore end ( right of the pic) adjacent to the flywheel is a sheave that on the model drawings is identified as a chain drive … which would have a chain rising to a mate above, thence to the drive shaft that extends forward to the after most windless. Just guessing that the diameters of all the gears in the drive train to the pumps results in the pumps operating at about 60 strokes per minute ( the rate that might be reasonable for hand pumping? I can’t imagine that rig stroking at a much higher rate), then, working back to the engine and seeing not many reductions thru the various gears and chain wheels, the engine RPM must have been very low, maybe 120 RPM. I wonder if the propeller, driven from the aft end of the engine, would have turned at this low RPM as well. This sketch is what I understand Wefalck describing at the pumps.
  17. Don’t know if you have these pics … they were included in my Model Shipways kit. In the upper pic, it looks to me that the upper shaft ( of all that equipment just ahead of the pumps) can be engaged-disengaged from the large gear on the lower shaft by sliding the open ended gear at the starboard end of the upper shaft. Also, it appears that the chain gear ( on the aft windless, just inboard of the portside barrel), the chain gear on portside of the assembly near the pumps, and the chain gear on the upper shaft of the forward windless, all three align. But, while I can imagine a drive chain running from the chain gear on the aft windless all the way forward to the main windless upper shaft, and a separate, shorter chain used to run from the aft windless to the portside chain gear on the shaft near the pumps; I can’t imagine how any power is transferred from the shafts driven by the chain to the two shafts just forward of the pumps.
  18. I like the look of silkspan sails. I fabricate them using fine brass wire for the bolt ropes, which then allows forming the sail as “ billowing” as you like. I also prefer to mount them off-model, since my ham-fisted hands have difficulty accessing the yards if on the ship. I also found that, if modeling furled sails, to use about one-third less material, as even with silkspan the furled sail seems too bulky otherwise. But, to each his own. My models are not “ museum quality”, just good enough for my shelf. Have fun.
  19. Stuart: Have fun with your Niagara. To the references already mentioned, I would add A Signal Victory by David Skaggs and Gerard Altoff. I found the descriptions of obtaining materials and building the ships at such a remote frontier location to be fascinating. When I was building My version I found such animosity on line about unverifiable historical details that I decided to name my model the Lawrence to avoid contrary comments. Seems much surrounding these ships involved contrariness. Perry named his flag ship Lawrence, after his friend who died with the final words “ Don’t give up the ship”, which Perry emblazoned on a banner….and then promptly did just that, when he transferred from Lawrence to Niagara! Anyway, enjoy your project.
  20. Ahhh…Excellent! Thank you for the links. The wiki.cdd.no link led to two others, which finally provided this: “From the start in 1894 until 1925, DAN exclusively built 4-stroke glow-head engines, but around 1925 the first 2-stroke engine was tested.” So, clearly, the engine is four stroke. There is clearly a wealth of info about these engines in the attachments; unfortunately, the only other Danish words my Bestafar taught me were “ aquavit” and “ skal ”. That said, my question has been answered. Thanks again.
  21. During the course of building a model of Ronald Amundsen’s Gjoa, I have become curious about the vessel’s engine. In his book on the Northwest Passage voyage, Amundsen says: ”Our little motor — a 13 H.P. of the “Dan” type — which was connected to everything that could possibly be driven with its aid, was easy to work and practical in every part. The motor was the pet of every one on board. When it was not working we seemed to miss a good comrade. I may say that our successful negotiation of the North West Passage was very largely due to our excellent little engine.” I have search for info on this “Dan” type engine, and come up empty handed. I am wondering if there has been a mis-translation or typo, and if this should have read “Day” type engine, meaning an early two-stroke gasoline engine. Anyone have any insight on this? Thanks.
  22. Absolutely beautiful work on the windless! I look forward to your interpretation of the mechanism at the pumps.
  23. Just my 2cents worth, and for another angle on old wood: Several years ago I got a MS Dapper Tom, solid hull kit on eBay that was old, as near as I can tell from late ‘60s, maybe earlier ( the instructions were on one 8 1/2x11 sheet). I believe the hull blank was southern yellow pine; the color and grain was much different than more recent versions of this kit from MS, and working with it was a dream. (The cast metal fittings were another story: flaky white and crumbly). I’ve made other old “ yellow box” MS kits, and agree the wood planks and sheet can be tricky to work, but, I really liked that old solid hull wood.
