Hsae
Everything posted by Hsae
  1. I am surprised how bad the accuracy for the „laser cut“ pieces are. Oh well, live and learn. I did cut the molds according to the drawing, glued some strips on the molds where it was necessary. After that a lot of sanding.
  2. Amazing work! I assume you did that on your Proxxon CNC mill. Quite impressive! What wood do you use to mill such small items? Boxwood? Hermann
  3. The first thing I noticed that the molds do not match the drawing. Believing that the drawings are accurate I have some work to do.
  4. I always wanted to build this boat. I bought the hard copy To Build a Whaleboat by Eric Ronnberg 20 years ago. I found the kit by accident on eBay for a reasonable price. Inspired by the already existing excellent blogs in this forum I will give it a try. The box I received didn’t look so good and I was afraid that the wood was wrapped already, but to my surprise it was still good (so far as I know). There is one thing I do not like from the beginning, the drawings are on both sides, obviously to save paper. That makes it kind of annoying to look for certain things. I believe the older kits had it on separate sheets, or the newer version?
  5. Oh, they are the real ones. I assumes they are in 1/36 scale. Thanks anyway! Hermann
  6. Keith, may I ask you from where you got the the mentioned retains straps ? Btw, outstanding model! Hermann
  7. Chris, thank you for letting us a look into your production area. You are building great model kits! Hopefully at same time in the near future I am able to build one too! But how did a plastic model ended up in your shop??? 🤔
  8. I am using for the Proxxon a “ring” LED (eBay) and for the drill press a magnifying LED ((AliExpress) which I can also use for the Proxxon. Both are giving sufficient light for detail work.
  9. Last night I was working on the planking for the bridge. I had to do some modifications. Moved the “stairway” and cut the “windbreaker “
  10. Yes, but you would probably always see it. I mixed so many colors that it is tough to match. Plus I cut already the frame to size. I am just debating if I use glass (heavy) or acrylic glass (easily scratched)
  11. Thanks Yves, I Hope it will be a great diorama. I only wish I had made it a little bit longer … oh well!
  12. Yep, can’t dive, there will be wood underneath! Lol
  13. Glad to see you back on your Bluebell, Kevin! Great work, Hermann PS: I hope you didn’t glue the wooden panels at the deck yet. You have to switch sides. 😉
  14. No problem. I guess all the memories are coming back again. Thank you for sharing Kevin.
  15. Thanks Kevin, appreciated! I will see if I can squeeze one officer and two lockouts on the bridge.
  16. Wow, that’s quite interesting. I do have some questions for you, if you don’t mind. What kind of equipment have they extended typically when they are surfaced. Besides radar. And what color did they have? I don’t know if I got the “tiling” right, what do you think? And how many sailer where on the “bridge” typically?
  17. Yes, it is the HMS Vanguard S-28 SSBN with the tug “Rowangath”
  18. Of cause I still have to do some touch ups. 😉 My project on the side …
  19. It has been a while since I last posted something. My apologies! But that is the nice thing with this hobby, you can leave it for a while and start again later. Well, small progress. I weathered the hull and placed it into the “water”. I final finished the deck and installed the degaussing cables. I don’t know if they where around at the time (1943), but I thought it is a nice feature.
  20. If I may ask, how did you square the holes so nicely. It looks like you did the main part with a router/mill and the rest with a chisel? Btw, beautiful work!
  21. Yep, unfortunately they copied all the mistakes from the old matchbox kit. Except the stern. The Snowberry had a round stern. Otherwise it is an impressive build! Very neat to build it on a 3D printer! Hermann
  22. I have to agree. It is the galley. However the galley has an “extension” . See photo.
