Everything posted by RGL
Stretched Sprue! Place a line of it on the break line, let it set, sand flush, reattach broken bit. Don't forget most of this stuff is not visible to the naked eye.
Thanks, if need be I can mask anyways, it's not cheating! The last photo of the old hull will be oversprayed multiple times until I'm happy.
One thing about having a spare, is the ability to practice. Given the size of the hull I just cannot freehand a line perfectly strait for 60cm. My plan is to do black lines to represent the armour plates and the lateral lines for the frames, which work at at 17mm x 10mm. After three days I've figured out correct pressures to use the Vajello paints, now it a lesson in filling in the blanks and layering/modulating. The plan is to have visible plates on the hull, and unlike the new kit which has scribed armour plating the old kit does not so I can just respray and start from scratch until I get it right.
I don't think I will subscribe though Jorgen, I have been playing around with primers today, and I think for the large areas I will probably just use the old Tamiya rattle can to prime the really large areas and then the airbrush for the smaller ones. I have done a 50/50 on the trial hull of the Yamato with Tamiya/Vajello. I will then try panel lines tomorrow
All good cog, my compressor arrived today, I got a package including an airbrush cleaner and a Sparmax airbrush for the same price as the same compressor from other stores here in Oz from Hobby Tools Australia, arrived in Canberra from Victoria in three days (over a weekend), about the distance of you Country Cog. Took me an hour but I've got the compressor figured out in respect of PSI. I do like the Tamiya rattle can primer for big areas but will try the AK for the small bits.
Cog, I've done all the pure etch stuff now at least. Where I live it is probably too cold to airbrush for at least 3 months of the year, but every day is in the high 30's at the moment so that's OK. It only gets to the minus 4's here in winter at night but never humid. Robin, I will probably use Grunze or Vajello but Banyan has given me some good ideas, and there is so much out there on the net. It's been a big investment so lucky I worked nearly every public holiday over Xmas.
Thanks Mr Bunny, I intend on keeping Banyan as my go to man for trouble shooting. He is a wealth of knowledge on paints as well. It's been 30 years since I've used one, and a chap has done an amazing job on this kit on the model ship forum which I will try to replicate as much as I can. As such, I won't have much to post for a while till I get this right(ish). Finishing off those 25mm's did my head in.
Yes mate, Banyan has been giving me a heap of advice on this, I realise I have a lot to learn. It should be fun.
So, the kit goes away for a while. Back in the 1980's I had one of these, worked fine. Now to re learn the skill. I intend to start painting up bits of the old tool to learn modulation and filtering, before any paint goes on the new kit. This should be fun. It's amazing how much there is on Utube for tanks and planes, nothing on ships.
So, 27 more triple 25MM's. The bases including the seats and windage levers. Plonk the barrels on. Finished and I'm just a bit over these things.
After a few days off due to illness, the 25mm triple mass production continues. For ease of application they are laid out on masking tape and the barrels added. Then the magazines folded and placed in blue tack facing the right way for application. Then the sights and rear handles added. Whilst the alignment is not perfect, they are soo tiny it is not really noticeable with the naked eye.
Just gently tap on the bit you have glued down with the tweezer head, if it falls off then it will fall off late and you'll lose the piece. I find about 10% of all assemblies do this as the glue has not been put on correctly. Better to fix it then than when it's on the model.
I think that's one of the hardest things you'll have to do Cog, whilst I could see it, alignment at that size is a nightmare. Then you have to tap every assembly to make sure it's stuck down properly.
Try it on a piece off offcut brass fret, burns for about a second then the glue is gone. I'm not poo pooing the acetone idea, as I was not aware of it, just when you are repeatedly dipping into the glue it is a bit quicker
