aliluke
Posts posted by aliluke
  1. Looking forward to this Mike.
    With an unpainted approach will you be using the PE brass friezes that run along the hull?
    I also have Bob Hunt's practicum - bought years ago in a bulk buy deal he did - but it is a very strange read in places. He goes completely off topic and complains about his eyesight and the state of the economy etc. The rigging section is actually for the Bounty. I have not used it all and feel no need to.
  2. Hi Nils
    Although I've looked in now and again I never have said anything on your build. This is because it is the Scratch Forum while I mostly hang out in the Kit Forum .
    Great work on your Pegasus - everything looks very authentic. You do have a lot of rope on the decks from the gun tackles. That is why I left the rear tackles off my Fly but that is just a choice...Anyway good stuff and keep it coming!
  3. Hi Louis
    I'm with Spyglass here. On my log you can see an area of lower deck planking beneath the fore/ladder hatch. This is just visible when the ladder is in place.
    I use an HB pencil to simulate caulking. Some do it on only one side of adjoining planks - this makes repairing any gaps easier. I do it on both and hope I don't have gaps!
  4. Hi Martin
    A couple of thoughts...
    I don't think you want the grate to project above the coaming. This applies to the side of your grates. They should sit fully inside the coaming and the exposed edges of the grating on the sides is awkward.
    If you can, try and set out and cut the gratings so you form a full frame at their perimeter. I managed this with all my main deck gratings but failed to so on the QD gratings. That was just the way they worked out and I think I had my eye off the ball a bit as well.
    I'm still not convinced by the heavily curved grating and coaming versus a flatter version. I guess that is just a matter of taste.
  5. Welcome Louis to the Swan Class build. It is a great kit and I hope you enjoy the process of building it. You've probably already had a look at the many logs for it. I, like Blue Ensign and others, are modifying it to more closely follow the Seawatch book series on the Swan Class - The Fully Framed Model. Volume II and Volume IV being the strongest references. Dan's build of the Vulture in the scratch built forum follows this as well but in much greater detail. However straight out of the box it will still make a fantastic model and adherence to the FFM is a personal choice rather than a necessity.
    I look forward to seeing your start and progress. With all the Swan builders here you are sure to get lots of advice and answers to any questions.
  6. Hi
    Your work looks very good.
    Those squares are the sweep ports and are definitely an accurate inclusion on such a ship. To form them I'd use a fine drill bit in a pin vise and drill close to each corner then I would cut them out from those holes with a scalpel blade. Then finish with a needle file. Not easy to do with that depth of 6mm. If you'd rather save yourself the risk you could leave them off but they really should be there.
  7. Hi Martin
    No I don't install the grating first when sanding the coaming to size. I don't have any problem with them breaking up as I find the corner box joint to be very strong. I'm not sure about the curvature thing. I asked Dan about it in his Vulture log and he reckons the curvature should be much greater than the deck camber. To my eye the flatter version with only a slight curvature looks better even if it is historically inaccurate....
  8. Hi Martin
    I don't use a rabbet. I just butt the deck planks to the edge of the coaming. I set up the planks first and make the coaming fractionally larger than the set up. I then gently sand the coaming back until I get a really tight fit. I don't use a rabbet or ledges to support the grates either I just make that a super tight fit as well. I also have very little curvature on the coaming such that you couldn't even measure the difference between the high and low point. I know people put much more curvature on them. I'm not sure which is more correct.
