Kauz
About Kauz
1,224 profile views
  1. One small trick I learned from a great-uncle who was a master cabinetmaker: Set the nail head down on a hard surface (vise, small anvil) and, with the hammer, make one or two taps to the tip of the nail. This will create a small burr at the edges of the resulting flat that cuts the wood fibres instead of pushing them apart, this way reducing chances for splits.
  2. Perhaps look into cable ducts. Different sizes with removable tops, so may be exactly what you need.
  3. Using a stop block, you could do it in different settings to get a gradual taper, i.e. first setting with slightest taper, second with a steeper angle farther out on the yard/mast and so on. You'd only have to hand sand the transitions.
  4. Hello, don't know if you are aware that there are different brass alloys. Gross categories are hard, semi hard, soft. You might look for a material suitable for deep drawing, this should be quite malleable and soft. Not as soft as copper, however. Silver would be another option, but with price nowadays ... , and you'd have to cope with the colour 😎.
  5. Sorry for being too late, here is a video: https://youtu.be/81OJdv73thQ?feature=shared
  6. Hello, you might try a mouth atomiser. I used one in my youth for application of fixative to pastels. No airbrush then🦣.
  7. Sorry, but I have to contradict. Being a master goldsmith, I know a bit of the trade. Solders for gold alloys have the same amount of fine gold as the alloys that are soldered, otherwise the fineness of the completed jewellery item could fall below the legally allowed amount. So, for 14k gold, 14k solder is used. With silver, it's another case for metallurgical issues. Silver soldiers for jewellery contain 67.5% to 60% silver. To lower melting temperatures of solders used in jewellery work below those of the gold and silver alloys , usually zinc is added (in the past, cadmium also was used).
  8. Sorry, sequence got muddled. Please read 3 - 1 - 2. 14th of April is the newest date I can see.
  9. It's quite strange, the tracking I get shows totally different data. Quantum mechanics?
  10. Hello, finally, the second copy I ordered arrived here yesterday. A little battered having taken the long run via Australia, so I second the idea of adding a cardboard sleeve. Of the first order, I've got no news yet.
  11. I think USPS cooperates with DHL. When customs were cleared the package was transferred to DHL for delivery within Germany. I was able to track the package with the DHL app, and it is in their system. Usually it's a matter of 2 days maximum until I get a consignment after it was processed in the letter processing centre. Not so this time. Meanwhile I have re-ordered the book, as from similar experiences I have little hope that the package surfaces again. Of course it's not the fault of NRG, and I'd never blame our guild. Just had to let off some steam 😉 Sorry
  12. Hello, DHL messed up the package. It cleared customs on Tuesday, 25th of March, and since then no further progress. "consignment was processed in letter mail centre". I called, but was told to wait until Friday and then have a research started. When I try to do that, I get the notice that it is not possible to have it researched, as it is a letter, no package. You might imagine my frustration.
  13. There are some versions for 3d-printing. Would be plastics, however: https://www.thingiverse.com/search?q=Fractal+vise&page=1
