drobinson02199
Everything posted by drobinson02199
  1. This will be my last progress report for two weeks as I'm going away with my wife from cold Boston to a sunny place. I have now planked the flying bridge deck. In this picture I also dry-fitted the main railings, although they won't go on permanently until the flying bridge furniture and fixtures are done. Note that the forward railing is missing a stanchion on the starboard side -- I broke it while fitting the railing and will need to glue it back on when the railing is permanently mounted. (This despite a manual warning to be careful as the forward railing is delicate). When drilling the holes for the forward railing, when you hold the railing over the bridge, it looks like the positioning of the first two holes as specified in the manual is a mistake, but it turns out that the angle of the stanchions makes for deceptive positioning. So followed the manual and it worked. Then I have also made and installed the windshield wipers, which I think are very realistic-looking. More building later in February when I return. Regards, David
  2. Chris: On my riverboat, they put a water trough against one wall -- so you could consider that. Easy to fabricate. Regards, David
  3. Chris: Those figures, along with the detail you've put into the horse bay, are really great. It's looking terrific. Did the link I sent you help with your search for horses? Regards, David
  4. I'm about to begin work on the flying bridge, and with the interior cabin finished, I realized that while the flying bridge is removable to view the interior cabin, it might be good to light the interior. I can do that by attaching led's to the bottom of the flying bridge. There is room to make a cavity for the battery and switch, which you can see in the pics below. Would have bee much harder to do this if all of the railings and finish had been applied to the flying bridge. Regards, David
  5. Wonderful stuff. That is such a beautiful ship, and done so well. Regards, David
  6. Finishing off the main cabin interior. First picture shows the curtains up, as well as the magazines and maps. Closeups of those follow -- they are real mag covers and real maps, all reduced to miniature in the kit. A build tip: the instructions call for the curtain cloth to be sized with diluted PVA glue to give them some body, but that didn't do the trick -- after folding they were too floppy. So after folding and tying, I used hair spray to stiffen them. The bow picture shows the moldings covering the join points. The final picture shows the molding reversed to act as a flashing where the sides meet the hull deck. A build point: looking ahead in the instructions, the hull deck is made up of a 1mm frame and 1mm planks, so when installing that flange, I needed to make sure I had 2mm underneath it all the way around. Regards, David
  7. Don: The planking looks terrific. As to your deck, it's way above the average standard on my builds, and looks great to me. I know what you mean about finishing planking. Seems like it will never end -- until it finally does! Regards, David
  8. Chris: The curved couches are made of some sort of "leatherette" material. The square ones flanking the table are painted wood. Regarding more interior detail -- stay tuned. There is another wave of interior detail coming, but I need to do some other steps first. Regards, David
  9. Finished the sides and mounted them on the boat. The first picture shows that with the superstructure off the hull. Note that there are moldings at all the deck and side joins that I haven't installed yet. There's a detail picture of the vents. Nice touch is the side curtains. The third picture shows how they are installed on the sides from the rear, and then there's a closeup of how they look from the front. Finally, there's a picture of the superstructure mounted on the hull, with the flying bridge mounted on top. The flying bridge will get a significant amount of finishing, but I'm not quite at that step yet. Regards, David
  10. Another note. I mentioned above that the instructions incorrectly called for part 77 to be used as a bulkhead support, and wondered where it would be used. Turns out that part 77 (two of them) are the arms of the captain's chair. Regards, David
  11. I ran into a problem after the last step. In the first picture below, you can see the beam that was added to the transom. Picture 2 shows that it sticks up above the flying bridge support bracket in front. That left the flying bridge tilted up and not fitting flat. The small instruments precluded sanding that beam down. So the solution was to cut a slot in the base of the flying bridge. You can't see those little instruments when the bridge is mounted anyway, so having them go partway up into the slot is no big deal. Now the flying bridge sits flat again. Regards, David
  12. Incredible attention to detail. More than I can muster! Regards, David
  13. I have now finished the main cabin furniture and cabinetry. In the pics below, the superstructure is dry fitted into the hull, but the sides aren't on yet. Several views -- almost all of what you see is mahogany. I particularly like the instrument panel and controls. More when I get the sides on (which are also mahogany on the inside). Regards, David
  14. Don: I've just caught up to this log, and your beech planking looks wonderful. I love the way you did alternating boards and lined up the joins. I'm going to sign on to see the rest. Regards, David Robinson (the "other" one)
  15. Forgot to mention in my previous post: there's an error in the manual. In the second picture above, where you see the curved extension come to rest on one of two stub posts: the manual calls for those to be part 77, but that clearly doesn't fit, and in later pictures it morphs into the part you see here. Took some looking ahead to suss it out. I'm not sure part 77 is ever used, although it's marked as a "sofa part". We'll see. Regards, David
  16. Here's the full superstructure with the flying bridge added and some parts painted. Note that the sides are back off. The flying bridge is made to be removable so that you can see into the interior of the main cabin. The panels you see in the second picture are mahogany, which gives an idea of the finish level of the interior. The rest of the interior is made up by a lot of small pieces of cabinetry (all in mahogany) and some cushioned seats. Interior deck is "carpeted" (decorated heavy paper). So I have to build a lot of "doll house" furniture now. I'm enjoying this one. It's very different from others I have built. Regards, David
  17. Chris: The build continues to look terrific. Just for fun I did a Google search for 1:50 horses and came up with this. Second item on the page. http://www.scalefarm.com/index.aspx?page=search&did=SCALE-1-50-SIKU&order=&search=horse Regards, David
  18. What you see is the result of a dry fit (called for in the manual) to ensure that the sides fit properly and are sanded flush with the stern. But it gives a good sense of what the boat will look like. The interior of this boat has a very high level of finish -- note the mahogany interior sides, which should look really nice when varnished. I also popped it onto the hull to get a sense of how it all fits together. There is another structure that fits on top of the center structure you see. By the way, the hull will eventually be wood-planked before it's painted. Regards, David
  19. Zappto: Really, really beautiful -- the model, but also the workmanship. You mentioned that this is an old kit. I think it's now discontinued (Mamoli is out of business -- right?). Where did you get it? Regards, David
  20. Chris: She looks fantastic. Your attention to detail is marvelous. I love the figures on it. Regards, David
  21. The basic frame of the superstructure is done. It fits into the fiberglass hull, but isn't glued in. It remains removable for R/C access. Since I'm not going to do R/C, when the boat is done I'll probably glue it down. But until completion, it will stay removable. The fit of these parts is really marvelous. So far, a really nice kit from Amati. Regards, David
  22. Here's the first part of the superstructure. It fits into the molded hull, and I've looked at the manual and it's built up and finished off the hull. Also made to be removable for R/C purposes. A few build points: Frames 6 and 7 are reversed in the drawings of the laser cut sheets, but it's easy to figure out because of the way they fit. The frames you see are MDF, and Amati put a note with the manual saying that they have substituted MDF for plywood for 5mm laser cut pieces, because it doesn't chip and works better. Having worked with both ply and MDF I tend to agree, but I have seen some debates about MDF on the forums here. The other thing is that the drawings showing what part is on what laser cut board require some interpretation. For example, what looks like one board with three square areas of laser cut is really two separate boards, and on the one with two areas one of them is inverted -- but it's pretty easy to figure out. More to come. Regards, David
  23. Wow Zappto, that is a gorgeous model and incredibly fine workmanship. Regards, David
