Keith Black
Everything posted by Keith Black
  1. Fiurar, welcome to MSW. Glad to have you aboard.
  2. John, as good as it is to see you back working on the Klondike the good news regarding your wife's recovery is even better.
  3. The best solution (IMHO) will require refinishing the hull once done but it will be worth it in the end. Do the separations one at a time, fill the separation with CA glue and before it sets sand with 400 grit sandpaper. If the separation you're working on doesn't completely fill, repeat the process. The sanding dust is the exact color of the surrounding wood and the fill will almost be invisible. Cut your sandpaper into two by two inch squares and discard frequently as the CA will clog the grit. Don't get overly aggressive with sanding and dig grooves into the hull.
  4. Linus, welcome to MSW. I sometimes struggle at 1:120, the thoughts of working at 1:700 makes my knees weak. Glad to have you aboard.
  5. Ron, would you please start a build/restoration log for this model as I'd love to keep abreast of your progress.
  6. Ron, the ship looks salvageable but can the cat be saved?
  7. Lindsay, welcome to MSW as well. Glad to have you aboard.
  8. John, at one time or another most of us have been in your shoes. When building these fragile models breakage is to be expected. Short of doing the correct thing by replacing the broken part, you might try removing the broken top part of the mast, drill holes into the two faces, insert a brass pin made from brass wire, and CA glue the two pieces back together. It's a long shot, it might work but it's always going to nag at you.
  9. Peter, welcome to MSW. Glad to have you aboard.
  10. Mark, I've included a couple of links from Cornwall Model Boats. They have a min purchase that may make ordering from them cost prohibitive but it may give you some ideas for looking elsewhere. https://www.cornwallmodelboats.co.uk/acatalog/Model-Boat-Fittings-Winches-Windlasses-p1.html#usestorage https://www.cornwallmodelboats.co.uk/acatalog/cap-yacht-winches.html
  11. Welcome, Trevor. Glad to have you back with us.
  12. That crow's foot and when you first came onboard are light years apart, Bob. It's been fun watching as your abilities have grown, great work.
  13. Lynn, we've all been where you were, not having the right tool for a job or the correct tool not working as it should. But we preserver using whatever it takes to accomplish the goal. Love seeing the perseverance, good job.
  14. Jim, welcome to MSW. Glad to have you aboard.
  15. Thank you, Craig. Thank you, Eric. Thank you, Pat. being a coal bin I'm surprised it's not completely black. For awhile I worked in a coal yard. The belly dump coal cars were parked under a roof and during the winter the ice/snow would melt and drip down into the cars. This caused the coal to freeze to the belly dump and and sides of the cars. I had to dig out/break off the frozen coal inside the cars into the dump pit. At the end of the day I would be totally black from coal dust. Speaking of Lula's coal bin, I failed to mention that the reason I made the chute door so large was where a man could get down on his hands and knees and crawl into the bin if need be. Caregiving and snow removal kept me from working on Lula yesterday but today i plan on turning American football games on the TV and escaping into working on Lula's wheel wall.
  16. No, Bob, that ain't it. A helmet wasn't exactly what I had in mind.
