rwiederrich
  1. Well I worked on the main backstays and finished them up..here are some pics. Rob
  2. Thanks so much Popeye...yes I'm feeling much better and the numbness has diminished considerably....allowing me more fine detail work to be done. I plan on putting many hours in the shipyard tomorrow..so that means some rigging is getting done........Yippy. Rob
  3. Bob..as much as I would love to accommodate you....I think I'm going to stick with just the main sails....like in the painting of her. Just a reminder: The area she will be mounted won't be able to accommodate that extra width. I have entertained the notion myself....but the fact of the matter is...the Great Republic never ever set her stunsails as originally designed. It must have been a real sight of the imagination to have seen her in that rig under a brisk flury. I have nothing but respect for your opinions...never *Hate*. Even if it means having to tare stuff apart and redo all kinds of stuff and add more stuff with more rigging and stuff...... Rob
  4. Thanks. Even when I think I know everything there is to know about this ship...I surprise myself. I've tried so many new techniques and perfected others on this build it's dizzying for me. But I think the result is acceptable to most. Trying to cram in as much detail as possible in the wake of EDT's fabulous YA build is a daunting task and in a far smaller scale to boot. The bar is surely high. Rob
  5. Thanks Grandpaphil. I hope to get moving along...so much still to do. Rob
  6. Finally, are some pics of the main backstays and also of the mizzen main and the topsail stays. Slow going, but I'm exercising tha machinery... and soon the yard will be back in full operation. Rob
  7. Well it's time to get back to the shipyard...my hand is doing better, though I still have some numbness..I can work around it. I finished up the fore mast stunsail booms and I worked on the mizzen main stays and I worked on the main backstays. First, here are some images of the booms and their ironwork. Much better then before. Rob
  8. Starting back up in the shipyard is a slow process. My arm is slowly healing and most of the pain has subsided, but I still have lingering numbness in my hand and fingers...though I can successfully use them to some degree. Fine work is still an issue. I also returned from a weeks long holiday at Sunriver in Bend Oregon and at Cannon Beach on the Oregon coast. I feel very refreshed and had a most wonderful time. I spent about an hour last night working on the Port side stunsail booms...so not much to report, nor do I currently have any new images to post. I'm gearing up to begin the final backstay install on the main mast before I finish up with the main stays. Balancing out the forces imposed on the mast is a crucial process if one wants the masts to remain undistorted. More to follow. Rob
  9. Wonderful....just wonderful Ed What a relief to finally be complete. She is magnificent to say the least. so much to glean from. Rob
  10. Welcome clipper fan..from another clipper fan. Try https://www.castyouranchorhobby.com/Category/deadeyes I'm currently building the clipper Great Republic. Rob
  11. Right. This is my first full set of sails implemented,...until now, Running the braces never extended me this problem. Your solution for the crojack yard braces works, even thought the fulcrum angle is not overly taxed. These clippers (GR, YA) were build in the same year and it can be safely assumed the solution was universal. Paintings do not replicate this epiphanous revelation. 2 dimensional images can easily mask 3 dimensional issues. I will surely make known my resolution for the brace issue...when I can return to the shipyard in full health. Thanks for the fine comments and observations. Rob
  12. Wonderful work Ed...Interesting solution to the lower mizzen braces. I discovered a while ago that I too will be facing this dilemma with my Great Republic...even more so, because I have no space to fudge, since I have sails that will definitely be in the way of many braces. Ingenious disguising will have to prevail. I have fully enjoyed your log and have gleaned much. Not sure you caught this, but it appears the aft backstay may have slipped out of its place on the main mast. The image you posted of the main mast braces definitely shows the aft port backstay out of its station. Thanks for the wonderful way you presented this build.....Clippers being my love...you kept me enthralled. Rob
  13. Wonderful work and attention to detail... Beautiful model. Rob(dust-er off)
  14. Thanks Scott...yes the arm is doing better, still a bit tender....but the hand is still numb in part. Making fine work hard....since I can't feel my fingertips. I have put an enormous amount of research into this build, and even something as minor as stunsail booms can fall between the research cracks. Part of the fun is updating as you go if research points you in a different direction. I've seen this happen to many and surely I fall victim to it myself. Gladly the *repair/corrections* can be made early without any really horrific damage being cause by it. Thanks for your compliment and encouragement. Rob
  15. Thanks Pat...the first booms were far too heavy and the irons were not what I wanted. PLus moving them beneath the yards makes them more typical with the era. I think they look better. Again...thanks. Everything is evolving as my study reveals the needed changes. Rob
  16. Thanks.... I spent some time correcting the stunsail booms and the irons. I adopted the underneath design.....it makes the most sense. Rob
  17. Yes...I have this image and yes this is after her rebuild. Interesting to see her stunsails in both configurations.. . because other ships do the same. It's hard for me to tack down a real good example..since it seams it might have been preferential instead of typical. Searching the model world...stunsails have found themselves mounted on top...slightly abaft....in front, slightly forward(similar to Ed's fine model), slung from beneath. It just seams to be how they get modeled. Personally I think I want to make my irons beefier and repair the missed center iron. No matter what I do...I'll make them far better. The lack of a good operating left hand definitely shows. Rob
  18. More to follow...…. Just for information sake here are some images, one a drawing, of the stunsail boom suspended from the top of the yard...similar to mine.
