rwiederrich
  1. Sailor……..I don’t have any good full views of her…… but some like this on the bench. Rob
  2. Take the lead end of the lanyard from the bullseye......pull it snug, tightening the lanyard and then use a small alligator clip and clip it to the stay...leaving ample room. Then tie off the lanyard in 3 places as it runs along the stay. Glue then simply trim off the excess thread used to tie the lanyard to the stay. Easy. I wouldn't worry about painting the ties as you se in the image....this was generally done while she was in port or on display to brighten her up and make her look shipshape. This is generally how the bullseye lanyards were secured to the stay. If you are simply attaching the stay/guy to the outer bullseye...wrap the stay around the bullseye and secure like I explained for the lanyard. Generally they were seized at least twice. Keep it simple. Rob
  3. Moving ahead nicely...for sure. Now it starts to get real fun..... Rob
  4. She's looking very nice. Clean, and ship shape. Wonderful job. Rob
  5. Most clippers shipped 2 to 6 boys. They did most of the furling and letting out of the royals and sky sails and the stun sails. Their size permitted then easy access to scurry up the royal mast and mount the royal and sky sail yards. Rob
  6. This idea is quite sound…… and was actually the case on sailing vessels. When the sail was being drawn down, it’s rigging came down with it, such as stun sails and jibs. On my Glory of the Seas I opted to retain the haul yard and down haul and simply connect their shackles. You can see this on the mizzenmast top gallant stay. All my sails are dressed tightly on their yards, as would be typical in port. Rob
  7. Actually, I try to add rope coils pretty quickly, but sometimes the process requires me to wait till a segment is finished. I tell you it’s a juggle. But it’s all worth the effort. Rob
  8. I built a CS following that sail arrangement too.
  9. Thanks…….I wanted to demonstrate different sail applications. Rob
  10. Well...you've posed many good questions....many of which I have done myself....Sails(paper), for my 1/128 Great Republic,.... Diorama, my Ferreira(AKA Cutty Sark), .....Repair scene, Cutty Sark getting a new rudder,..... furled sails my current build Glory of the Seas.
  11. Bob...clear your mind and just try to remember...there is standing and running rigging. Standing generally gets rigged first...however if you build in sections Like I do, then you will combine your rigging to accommodate your process. Ask me any questions about rigging and I can help. I've been rigging clippers for 45 years and apart from some specific unique items...the rigging is generally all the same. Rob
  12. Thanks Druxey. The more lines that go in...the more and more I need to be diligent not to tangle or cross them.(I almost get crossed eyed). Praise God, I have had only one line I had to remove and re rig due to slight crossing, and that was a main topgallant brace...I failed to recognize it had to have a greater range of motion, because the yard is hauled down. When she is raised the brace would interfere with the brace from the mizzen counterpart. All is well. I think my plan is being fruitful...by doing all the internal work first...to include braces, downhauls and any stay work....and leaving the backstays for near last. Once I figured out the sequence...even though it appeared to work against what seamed to be the logical next step, things move along quite nicely. The real work will come when I need to introduce all the rope coils at all the belay points....using ft long tweezers...... Rob
  13. Thanks Rich. Still have the top yards and the entire main yard rigging. It will be a great contribution to the gossamer web of lines. After the rigging is finished on the main mast, I will add the Davit’s and their gear. Then one more mast and I’ll be through. yeah………. Rob
  14. Turned her around and am setting up to do it all over again. Some close ups too. Rob
  15. My goal is to get the main mast rigging all done on the starboard side today. I did a lot of work……about 8 hours of work. Rob
  16. Finished the top gallant, royal and sky sail yard braces for this side. I’m not addressing the topsails till I mount the main. Makes working around it easier. Rob
  17. All starboard back stays installed. Now it’s time to add the main mast yard braces…………man what a spider web.
  18. I hope you left yourself enough room to belay on those pins. Rob
  19. Thanks everyone for the fine compliments. I spent time running the rest of the main mast haul yards as well as the starboard mizzenmast braces. All these internal lines must be rigged before the back stays. I opted to work this side as much before I flip her around…….since that is becoming a real task. While I was thinking, chose to drill out the hull fairleads for the main upper and lower topsail yard braces. Here is a few pics of what I have done thus far. Rob
  20. I build and add the rigging to each mast off model. I rig every aspect for yard control and sail control. Then set the mast and then begin the complex running and belaying the lines to their appropriate pin. you need the shrouds mounted first. before you can rig up the fairleads for the bunt lines and then belay them as well. Currently I am finishing up the haulyards for the main mast yards. The trick is deciding when to include the braces for the mizzen yards....BEFORE I rig the backstays. It is a *layering* maze for sure. Good luck. I'll help in any way I can. Ro
  21. I love polystyrene formed strips...they come in every imaginable form/shape.....love-em. Great job....... Rob
  22. This is so true...One must also take into consideration the type of line you are using...cotton or nylon, coupled with the direction you are reeving the lanyards in the deadeyes. I've been able to control twisting by these simple tricks. Rob
  23. Next I added the main yard down hauls and their purchases. Next will be the mizzenmast braces. Rob
