Everything posted by Paul Jarman
Welcome to MSW Joseph, You have found the best forum there is for this wonderful hobby. Looking forward to following your log when you start it. Paul
Finished building this kit a while back. It is a very good kit. I painted mine. You are going to enjoy building this kit. Only tip I can give with AL kits is to read and reread the instructions. You will love building the two staircases. Paul
- 109 replies
- Finished
- Artesania Latina
Looking good, paint makes all the difference. You are now up to the really fun part of model ship building. Adding all the details is when the model comes alive. Paul
- 160 replies
- Model Shipways
- norwegian sailing pram
main body and the bridge completed. Have not added the PE railings to the bridge. Have picked out all the steps and other details on the bridge. Bit of touching up here and there and some decals to add then on to the containers. Have built the first block and started to paint them up. Each very small square represents a container. Around 140 to each block and 22 blocks in total. So around 2,000 containers to paint up. May take some time. I am stopping work on the model for a few weeks as I am about to start redecorating the flat. Paul
- 17 replies
- Colombo Express
- Revell
I had forgotten how quickly plastic kits can be built. This level 4 kit is fairly straightforward. The two hull parts went together without any problems. The hull is now painted. It helped that the waterline was marked on the hull. The deck has been painted and fitted. Painting the parts up on the sprues, except fort the containers. There so many to paint up in different colours it will be better to paint them in blocks rather than trying to keep tabs of all the different parts. Paul
- 17 replies
- Colombo Express
- Revell
Looks good to me. Nice job on the planking. Breaking the odd peace now and then is all part of the learning curve. As your skills progress breakages get less and less. Once you move on to the larger scale models you will find it a lot easier due to the size of pieces you work with. Wood glues are all a matter of personal choice and what suits you best and which you find easier to use. I personally only use the yellow glue on areas I know won't be seen. And on the superstructure which will eventually be painted. I use a good quality white glue for all the planking. And for areas that require a better bond I find a white anathalatic glue works best. I find those lamp magnifiers hard to use. A good headband magnifier works far better and comes with a variety of different magnifications. They also allow you to get closer to the part you are working on. It does take a bit longer to complete models as you move up through the higher end kits. The great thing about being retired is you can put in as much time as you feel like doing. You might find that with these smaller kits 3-6 months is about average. Once you move on to the larger scale models anything up to a year is good going. Move on to the big ship of the line kits and 2-3 years is average. Some modelers can spend up to 10 years on a model Keep up the good work, looking forward to your next update. Enjoy your golf as well. Used to play myself until I moved to far from the course I played. Paul
- 160 replies
- Model Shipways
Yes, building,painting,and adding all the decals will certainly test my patience. Paul
- 17 replies
- Colombo Express
- Revell
Need a bit of help with the signature. I linked to the post but it dose not work. When I click on link from another page it goes to the top of whichever post I am reading. Any help would be much appreciated. Paul
- 17 replies
- Colombo Express
- Revell
Have decided to take a short break from wooden kits and will be building this Revell plastic kit. It is different from most ship kits. Have never seen a container ship kit before so figured it was worth a go. The kit itself is very high quality. There is virtually no flash any where on the parts. Not massively detailed being a container ship. The only real detail is in the ships bridge. Around 70 per cent + of the kit is in the containers. Should look quite colourful when completed. Paul
- 17 replies
- Colombo Express
- Revell
Thank you. That makes two completed wooden models since retiring 18 months ago.
- 17 replies
- sanson
- artesania latina
Sanson completed. Considering how the ships boats started out I am happy with them. Only problem I had was having to tie the tiny blocks and set them in place correctly. They are not great, but not to bad and I can live with how they turned out. Its why I would struggle with a sailing ship, to much rigging and to many blocks to tie off. I made the coils up by pushing them into blu tack. once they where formed I brushed them liberally with diluted crystal clear. this was so much easier to do and once lifted off they leave the indentation of the coil so it is easy to make them the same size.
- 17 replies
- sanson
- artesania latina
Nice one Lynn, you are learning all the time. I have been doing this hobby for the better part of 50 years and am still learning. The great thing of a forum like MSW is being able to get help and advice from other members, and building up your skills to a point where you will be able to give advice yourself. You will soon build up a collection of tools once you work out what you need. The one thing I would suggest you might want to add to your list is a Dremmel and attachments. And if you haven't already a good pin vice. Looking forward to following your build. Enjoy the journey. Paul
- 160 replies
- Model Shipways
Bit more done. I knew I was going to have a problem with the covers as I am not good at sewing. So I devised this plan to achieve the finished look. Seems to work out fine. Once I get them tied down they will hopefully look OK. Considering how they started as metal boats I think they look OK. Paul
- 17 replies
- sanson
- artesania latina
Well done lraymo, nice job for a first wooden model. At no time did I wonder what your Gender was. We are all the same in my eyes irrespective of race or gender. I have built many models both wood and plastic during my 67 years. And I find these smaller kits far more difficult to build. I find the larger kits are far more easy to build because of the larger scale. I was not sure what a Norwegian pram was so googled it. Looks like a nice introduction to a first model with a mast sail and rigging. Have fun building it and I look forward to your log once you start. Paul
- 85 replies
- Lowell Grand Banks Dory
- First Build
Nearly complete. Just the ships boats and davits to go. According to the parts list and the picture instructions the boats are wooden. They are not they are metal and don't look so good. Went to town on them with the Dremel and after a lot of sanding I should have something better to work with. Other than this stage of the kit the model has been a pleasure to build.
- 17 replies
- sanson
- artesania latina
Coming along nicely. Only downside is the ships boats. they don't ruin the model but they are not the best bit of the kit.
- 17 replies
- sanson
- artesania latina
Retired and ready to build my first model!
Paul Jarman replied to lraymo's topic in New member Introductions
Welcome to MSW, As you can tell you have found the best model ship forum around and have aready been give some good advice. Not a lot I can add. Except to say enjoy your retirement and take your time, no reason to rush. I retired 15 months ago and am loving the time I have to work on the model. just afew hours a day and you soon have a decent amount of work done. Paul -
New to the site and starting out my hobby here
Paul Jarman replied to Robp1025's topic in New member Introductions
Welcome to MSW Rob, Paul -
Laser cut char
Paul Jarman replied to ricky86's topic in Building, Framing, Planking and plating a ships hull and deck
I personaly sand it off. Dosen't take long. I use a medium grade sandpaper. Paul -
Build is coming along nicely. The stern is not perfect but I can live with it. I have not double planked as the second planking was ultra thin and only used as hull colour if not painting. I have filled the hull in with a thin coat of wood filler which helps with the painting better.. Bit of touching up on the paintwork and then onto all the finer detailing.
- 17 replies
- sanson
- artesania latina
Hello from a newbie with L plates on!
Paul Jarman replied to Pirategirl's topic in New member Introductions
Welcome to MSW Jas, This is a brilliant forum and you have chosen well. Have you decided on a kit? Whichever one you chose good luck. If you do get stuck during the build you will find the members here very helpful. Whichever kit you chose someone will almost certainly be building the same kit. And please do start a build log. Looking forward to seeing your progress in this wonderful hobby. Paul
