Paul Jarman
Everything posted by Paul Jarman
  1. I have never used Mark fit so don't know how good it is. Personally I use Micro Sol and Micro Set for decals. Once dry it makes the decal appear to have been painted onto the surface. It is a bit more expensive, but I would highly recommend it. Paul.
  2. Hi les, welcome to MSW. That's a nice job for a first time build. I have similar problems with these eyelets. You can buy drill sets on Amazon that go down that small and even smaller. I drill the hole slightly smaller then needed. I then use CA glue to hold the eyelet in place. I use a fine needle and apply a tiny ammount of glue to the hole. Or I apply a thin coat of glue to the eyelet and once it is pushed in that works fine with either method. The only problem I've had are the driil bits are so fragile at such a small size. I've lost count of how many I have bent out of shape applying to much pressue when drilling the holes. You might also want to consider starting a build log. You will find that you will get lots of good advice with any questions you may have. Paul
  3. I know,and I did serously think about adding them from inside but soon realized it would be to cramped to manage it. I then considered filing them flat,but that would take an age as well. I could leave them out for better realism,but that would seem like a waste. Paul
  4. Thanks Richardhd, Yes it was a subscription kit,but not sure myself if it was based on the subscription or not. It is a high quality kit. Such a shame Amati never corrected the bulkhead issue. The only other parts that let it down are the plastic lifeboats and benches. But the benches can be replaced with PE and there is PE for the lifeboat covers and rails. Paul.
  5. Had time to look through it all and compare it to the coloured card. And it dosen't replace all of the card only the main areas on the boat decks. So will still have to use some of the card.
  6. Thanks Gregg, Looks like a good model you have there. I have seen built logs for it on You Tube. Look forward to seeing you start a build log when you get started. This is the first set of PE that replaces all the coloured card and some of the other details. There is still a fair bit more to buy yet. This will of course add a lot more work to the kit. But will look a lot better then the card. Only downside to this is that there no instructions or code numbers to indicate what replaces what. Hopefully wont be to hard to work out. also some of the decks planked. Did consider making them a bit darker, but I like the way they look.
  7. Frames corrected. Photos don't do them justice. still look a bit out here and there. Although the alterations do line up with the templates. Maybe they will look better once they are glued in place and the straighteners are in place along with the decks.
  8. Looks like It's me next. I agree stick with the yellow ochre. The problem I see with the flesh Colour is that I have never seen a painting of Victory in anything other than yellow ochre. Surely all the artists of the time would be painting her true to life as they saw her. I am of the opinion that the flesh colour that was discovered was possibly an undercoat or the original Colour she was going to be painted untill someone realised how silly it would look. That PE looks very good quality. I will be following your build. I was building this kit myself some years ago. But have to admit that the instructions beat me and I gave up on it. Paul
  9. Thanks, just a shame Amati have never fixed the problem. The instructions call for a lot of the decks and fittings to be put in place before planking. But I might plank the hull before doing the decks. Paul
  10. Bulkhead 8 extended. Sanded down with the Dremel and covered with wood-filler for extra strength. not bothered about how untidy the sanding is it wont show once planked. 7 started. Looks like I will be able to make the correct alterations to the 6 needing to be altered. Bulkhead 8 now runs neatly in line with 9 give or take a few areas. I will do some more altering once I start the planking.
  11. Sorry about, they do quite a bit of PE for various scales but I didn't check to see if they had 1/300. But the card parts you have in your kit look way better than the Amati set.. They look to be made with self adhesive. Have you checked out the 36 part log on YouTube? Your kit looks very good and will make fine model. Paul
  12. Looks to be a very nice kit. I am currently building the Amati version. Will follow along with interest. I see that Occre are using the same Colour card for some of the detailing as Amati. I can replace all of mine with PE from Minibrass. You might want to consider doing the same if there are upgrades available. Good luck and enjoy building this version of this iconic ship. Paul
  13. The bulkheads and keel dry fitted. it is now fairly obvious how far out bulkheads 3-8 actually are. I don't have the tools or the skills to build new bulkheads. I do however have plenty of spare planks from unfinished kits. I should be able to build the bulkheads to their correct size by gluing strips along the edges and so build them to the correct size. All the strips have been cut out and trimmed ready for the second planking. Real shame that Amati allowed this to happen and never corrected it. At the very least they could have recut the bulkheads to the correct size and offered them to builders of this kit.
  14. Next project is the Amati Titanic. This is a museum quality model. The kit is very good quality. Will build into a very nice model of the Titanic. The instructions are very good. There is an 40 page colour booklet to go with the 10 pages of written instructions, which are very extensive. Plus there are 8 plan sheets. The down sides are the way the second planking of the hull needs to be cut from two sheets of ply using paper templets. The colour card cut outs to represent the windows and doors on the various cabin parts. Also the plastic benches are a let down. I will however replace all the card and benches with photo etch from Minibrass. I will start the build by cutting all the second planking parts out. I will then plank the decks before starting to put the kit together. I am unsure with the discrepancy with the 6 bulkheads. I have the template, but when I lay the bulkheads on it they are to small if I increase the size and to large a fit if I decrease the size. Will have to put them in place loose and see how the first planking sits on them. Have started by cutting the second planking out.
  15. It is a matter of choice as John says,and I have debated the same question myself. It also depends how steady your hands are. I have shaky hands when I try to do fiddly bits and find it very hard to tie the rigging on. But I would also like to build a model of HMS Victory or any other sailing ship. Therefore rather than miss out on building a nice model of a sailing vessel I personaly would build with mast stumps. Paul
  16. PC is finally back up and working. This is where the Rocket is up to.
  17. Thanks Chris, Makes it a lot clearer as to what I am building. I will look into sending an email.
  18. Finally finished the decorating. Next big project will be Amati Titanic. But before starting will be buying the Mini Brass PE replacements. Especially to replace all the coloured card parts. So before that I am building the OcCre Stephenson Rocket. Unfortunately I do not have a working PC and won't have for a few months. Typing this on my mobile. And for some reason cant download pictures from this mobile. Think it is because it is a cheap phone.
  19. Hi Antonio, I use the glue micro tip extenters,if they are the same thing. They come in packs of 200 from Amazon. They can be cut to whichever size you need and are excellent for gluing small areas. I find that rocket glue works best with them. The Rocket max works best. I use them when I need to use superglue. And I discard and replace with a new tip after each use. Paul
  20. Depending on the colour I would paint them on the sprue. As I would with most of the parts. If some parts are glued together and painted one colour than I would glue them together first then paint them. The only important thing to remember is not to get any paint on the area's that will be glued. Paul
  21. Well done, its been nice to follow your build. Looking forward to seeing your next kit build. Paul
  22. Try not to get to disheartened by this part of the build. I have the same problem myself. Some modelers can tie the smallest of knots with pefection others Can't. When I first started tieing blocks I used a piece of two by two wood to represent the block and practiced tieing with a shoelace. If you look at the blocks I have tied you will see they are not seized or tied with any fancy knots. I hold the block in a pin vice to keep it steady and just tie them with a simple knot or a fishermans knot. And to tie them to the mast I use an eyebolt and that works just fine. You just have to build up your confidence and keep practicing. It will work out in the end with a bit of patience. You also need to take into account Where the model is going to be displayed. If you are building on commission and the model is being displayed for public viewing then it needs to be perfect. If you are displaying it in your home then the knots won't need to be tied with such perfection. And you will look at your finished model with pride. And as you build more models especially large-scale kits you will wonder why you where so frustrated in the first place. Just hang in there keep practicing and it will all come together in the end. Paul
  23. Thanks for the thoughts. I did consider buying another model kit as it was just the hull that had suffered but decided not to. Managed to damage some of my other plastic models as well,but they will be repairable. Paul
  24. Had a slight accident whilst decorating. I had put all my models on the floor along with my stash of kits and other smaller items. Storing all of the large units first and carefuly placing all my kits and models on top of units as I stepped back I stood on the model. The damage is far to much to repair so the model won't get finished. Only redeeming factor is at least it was this model and not one of my wooden one's, they are now safely stored. As a result if a moderator or admin wishes to delete this build log to free up space feel free to do so. Paul
