king derelict
Members-
Everything posted by king derelict
Thank you very much Mike. Turned out to be a good exercise in looking beyond the information provided by the kit maker alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Thank you very much Andrew. I wish I had found the Black Cat stuff earlier. Trying to fold the PE 0.50 cal guns was a bit too intricate. alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Thank you very much OC. Just enough tiny detail to make them interesting but not too much to be frustrating. Alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
And suddenly Eskimo seems finished. I added the railings and boats, gave the superstructure a very thin black oil wash and then added the rust streaks to the anchors and portholes. And as promised here are a trio of Tribals HMS Zulu at left, HMS Eskimo centre and HMCS Huron at right as viewed. There are doubtless inaccuracies given the nature of the Trumpeter kits and photos only supply so much detail. I’ve read that corvette captains grabbed any secondary weapons going and the same for the Carley rafts so once in commission there really isn’t a standard configuration. I suspect that the same may be true for destroyers, so this is my interpretation at the end of the day. Thank you all for following along and for the likes and kind comments. Now, the question is, what’s next? A diorama is tempting and the miniatures are calling too alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Thank you very much Mike. I’m impressed with the Black Cat bits. The 2D look from PE really doesn’t work as well for elements like the guns although I like it for railings and support structures. A slightly larger range for 1/700 would be nice but I suppose there are limits to what can be done at that scale. alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Thanks OC, the Black Cat parts are tiny but so much better looking than the kit version or the PE ones. They mostly have 1/350 stuff but I did get the 1/700 Oerlikon, Carley rafts and 4.7 inch guns as well as the quad 50 cals. alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Beautiful work Phil. The rigging is so neat and it really makes the ship look alive. It’s going to look spectacular when the running rigging is done. Congratulations alan
- 238 replies
- Card
- Pre-Dreadnought
Progressing along the groove made by Zulu but changing the order of building around to reflect lessons learnt (or maybe not) from the earlier two builds. I made up the brass tripod foremast and installed it earlier this time. It was much easier to position but now I realize it’s going to interesting to place the forward funnel. Hopefully I can do it without banging the mast. Boats and Carley rafts are in progress now. i need to straighten the main mast which got touched while I was fiddling with the foremast. You can’t win sometimes. I was trying to work up the enthusiasm to attempt the PE quad 50 cals when the post lady brought a small box from France. A handful of Black Cat resin accessories including quad 50 cals. Amazingly tiny, they suggest the PE ones are over scale. The resin is quite flexible so cutting the guns off the supports was not too hair raising just tiny. They have been painted and added and look very nice- if you have good eyesight or magnifiers. Still a bit to do but it’s coming together. I’ll add the funnels and give the ship a black oil wash before starting the railings. Thanks for looking in, the likes and comments. alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Thank you very much OC. Yep, the display space is filling up. I haven’t found a spot for Sargon yet either. alan
- 42 replies
- Zulu
- Tribal class
Thank you very much Mike. I’m learning my way around the Tribals. alan
- 42 replies
- Zulu
- Tribal class
The Mossy Shipyard by Bryan Woods - 1:1
king derelict replied to Bryan Woods's topic in Non-ship/categorised builds
Hard work but the results look terrific alan -
Thanks very much Ken. I thought if she had seen enough bad weather to take the paint off she needed a greater amount of rust streaking. alan
- 42 replies
- Zulu
- Tribal class
Thanks Mike. I’ll try that technique with the ca glue. I was taught to solder as an apprentice at de Havilland over fifty years ago, some of it stuck but I was untidy them too alan
- 42 replies
- Zulu
- Tribal class
Thank you very much Andrew, the PE set is not perfect but it does elevate the build, the basic Trumpeter kit would be a bit bland. alan
- 42 replies
- Zulu
- Tribal class
Thanks Ken. Eskimo seems to be very similar to Zulu will less Carley rafts but some it’s are setting new challenges anyway. alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Thank you OC. I like the ghost camouflage on Eskimo. alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Thank you Andrew. Hopefully posing the trio is not too far away. Today was mostly PE wrangling which seemed harder than usual. alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
This the last of the three Trumpeter Tribal Class destroyers, HMS Eskimo . Inside the box everything is exactly the same as HMS Zulu. I don’t like the box art paint scheme and it doesn’t seem correct for 1941 so I’m backing my RN WW2 camouflage book instead. Besides I really like the “ghost” scheme of Western Approaches Blue and White. The drawing also confirms the number and location of the ships boats and most of the armament. It does show Oerlikons on the bridge wings. I am not sure if they were really there or whether the artist used a generic Tribal to color the camouflage. hull has been primed, masked and painted with the AK acrylic RN colors. The WA blue seems a bit green in the photos but really is a very light blue in reality. The basic building blocks of the superstructure have been added and noi think this is where I start the PE details. Thanks for looking in. Alan
- 24 replies
- Eskimo
- Tribal class
(and 3 more)
Ships boats have been installed and the paint touched up on the details. Then weathering. I think it’s a bit too much but I was after a North Atlantic convoy escort look and went a bit further than usual. Looking at some photos it may actually be typical. I doubt anyone was hanging over the side in a bosuns chair with a paintbrush in mid Atlantic. Im calling this one finished and will now move onto the last of the three Tribals. Thanks for looking in, the likes and kind comments. alan
- 42 replies
- Zulu
- Tribal class
Mike, I’m a bit nervous about using ca glue for the tripod legs of the foremast. Soldering them gives a strong enough joint to allow a bit of tweaking if the spread needs adjustments before fitting. I think ca works well for the yardarms, @mikegr shows an effective looking way of using ca glue on masts. alan
- 42 replies
- Zulu
- Tribal class
Thank you very much OC. I forgot I hadn’t added the ships boats so that got done today. Weathering tomorrow I hope. alan
- 42 replies
- Zulu
- Tribal class
I haven’t tried any IJN ships so far but have a couple in the pile. I might have to get brave Alan
- 42 replies
- Zulu
- Tribal class
