Posts posted by T_Warris
- AntonyUK, GrandpaPhil, Magellan1520 and 1 other
- 4
Hi,
Lots accomplished since my last post! Hull completed and most of the trim added...
Final sanding complete.
A quick coat of antique oil really makes the black walnut planking look great!
Fitting this around the stern was a bit of a challenge, but got it after a few tries.
Most of the hull trim added and rubbed down with antique oil.
I made up some laser cut frames to go around the gunports, looks a bit better then just the planking and hides a few bad cuts.
Starting to come together! Placed the cannons on the deck to get a feel for what it will look like.
The second layer of planking is complete! Went a lot quicker than I had expected, done in about 4 evenings, perhaps 8 hours in total. The ironing technique speeds things up quite a bit, basically iron on planks....
I quite enjoyed the zen like process of planking. I suspect there are some inaccuracies in how I did it, that will improve on the next model.
The final little strip of plank pressed in place. Still have not sanded it down yet, will take it into my shop to do that. It was dusty enough last time doing the first layer of planks in the house!
Pile-o-cannon await!
On to the next phase of the build!
- Old Collingwood, Heronguy, AntonyUK and 1 other
- 4
Good point about the cradle. I quickly made that one up on the laser. Hard to see in the images, but the inside edges of the cradle are covered with foam.
Heating the wood while planking works extremely well, while pressing the plank in place with the small iron it completely cures the glue. 5 seconds is the same as 24 hours with a clamp. Can't be removed. I've been using this technique for other wood models for years with great results. Sort of like iron on planks...
I finished assembling all the cannons. Haven't decided yet if I will add the rigging to the cannons or not.
With the first layer of planking complete, I have started on the second layer. I decided to replace the wood in the kit with some .5mm walnut. I prefer the rich look of walnut and since this model really isn't based on any real ship I figured I have the leeway to do what I want with it.Cutting Black Walnut Stripwood video on YouTube
The link above will show how the walnut stripwood was cut. (I can't see any way to embed a YouTube video into a post here...)
After starting the first strip of planking I noticed that somehow I got the keel glued on VERY crooked. No idea how that happened, I checked it a bunch of different ways when gluing it on. I used Epoxy to glue it in place, and I suspect it moved while it was curing. I debated leaving it and hoping it wouldn't be that noticeable, but in the end I caved and decided to crack it off and make a new one.
I made the new keel from some .190" Black Walnut board I prepared and laser cut it. Had to grind down a few spots to get it to fit correctly. The second time around I got it straight!
Much better. Had I left it it would have certainly made me nuts....
Made good progress on the second layer of planking over the weekend. I suspect I'll get it finished up this week.
Curious if anyone else uses a hot iron to cure wood glue quickly? The first ship I built several years ago was done at a time when I was flying R/C planes. Having a small iron used to shrink wing coating I used it to quickly cure wood glue. With this build I bought another iron for the same purpose. It only takes a few seconds of heat to cure the glue. Once it cools it is very securely bonded. Works great and also will help press the wood down and into shape.
Nice freshly ironed flat planks!
- AntonyUK, BenD, Tim Curtis and 4 others
- 7
Sanded and shaped the hull last evening. Spent the night sneezing! That was a dusty job. Next time, I'll do this job outside.
I removed all the nails, that made sanding much easier. Filled all the nail holes with wood filler and will sand that down next.
Really happy with the final shape of the hull. There were some very noticeable bulges in the shape of the hull that I corrected while planking. The final sanding took care of the rest. The flow of the ship looks great!
OcCre came through with the English instructions! I honestly didn't think they had an English version and that I'd be on my own. Watching some build videos on YouTube I noticed in some of the shots that others seemed to have English documents, so I contacted OcCre on the weekend. Overnight they emailed a PDF with the English version. Got my respect!
The kit included some cast windows and doors. To me they look crude and would likely still look crude even after painting, so I decided to made some new ones.
I scanned the castings and recreated them in Coreldraw so they could be laser cut.
Cut from some .8mm and .4mm ply, once built up they look much better! I'll add some frosted glass to them when installed. Haven't decided whether I'll paint the frames or leave them wood.
To break up the monotony of planking I have been piecing together the 16 cannons in the kit.
Coloured with Pan Pastels. Like the looks of this. What I didn't like that much are the solid brass turned wheels included with the kit. I prefer the look of wood wheels, so back to the laser!
Drew these up in Coreldraw and cut from 2mm and 1.5mm ply. The blue lines are lightly etched to simulate the rivets. Once in place on the cannons I think they look pretty good.
Thumb for scale.
Next step is the second layer of planking. It's been a while since I have done this and am doing a lot of research on the best way forward.
No, no store front, online only.
Of course the best day to come would be Friday 13th! If you can get through the 150,000 motorcycles in town that day...
- geoff, mtaylor and thibaultron
- 3
On to the build!
When I started the kit I told myself I wouldn't get too distracted in improving or replacing items in the kit. Having access to laser cutters is very tempting when building models, but as it is also my day job to design and produce stuff on them I thought I would try to not do that all night too. The reason I decided to buy a kit and not scratchbuild was so I didn't have to spend a lot of time back in front of the computer drawing stuff for the laser. Of course that didn't last.
I wasn't too impressed with the wood used for the deck planking. Also, to my eye they looked huge, scaling out to about 16"-18" wide. I decided to make some laser cut planks, taking advantage of the laser to add the nail holes and cut them to length.
Cut out a pile of them from Basswood, .022" thick. In hindsight, I made them too narrow, a scale 6" wide. But they still look pretty good in place.
Gluing in place to the deck. Edges blackened with Pan Pastels. Pan Pastels work pretty good for this, although a bit messy. Wasn't too concerned as I'd be sanding it all down anyway.
I've always wanted an excuse to buy one of these little planes! It has not disappointed so far in the build, endlessly useful! Used this to smooth out the deck instead of sanding, left a much smoother surface.
Found the colour of basswood a bit too white for a deck, so I stained it with a mixture of Leather Dye and rubbing alcohol (I used this stain extensively on my railroad models). Once dry I added a few coats of a semi-gloss finish. Was pretty happy with the results.
Planking done, stained and sealed I glued them all in place to the frame.
With that done, on to adding the first layer of planks to the hull....
Fairing completed. A bit of a design flaw in the kit are those pre cut gun ports on the plywood sides. Every build photo I could find online of this kit I can see they plywood cracked right above one of them. Sure enough, it happened to me too. I re-enforced them with some planking, which seemed to hold until the final planking was in place. Can be seen in the image above.
I made a bunch of sanding blocks of varying lengths and grits on the laser. These will come in handy when sanding the hull!
First couple in place!
Progressing through the first layer. Several evenings work so far!
Planking on this ship extends all the way to the top, over the laser cut plywood sides. Once the planks were added it provided enough strength to the area that cracked. Smoothed it out as well, barely noticeable. Really enjoying the lines of this model!
Breaking up the planking monotony with a few cannons...
Boaty McBoatface...
That's all for now. Will post another update soon!
Thanks for watching,
Tim
Dog tax
Hi All!
After a short break from building my last wood ship model (30 years) I decided it was time to take on a new project.
My previous build was The Bluenose II by ARTESANIA LATINA (below)
I bought the Bluenose kit in 1987 and built it over a couple years as a Christmas gift to my father. I had naively thought I would give it to him the year I bought it, but building took far longer than I had anticipated. Somehow this model managed to survive 30 years in a house with several cats. Only once did it hit the floor, breaking the bowsprit, which was almost impossible to repair (can be seen in the image above).
For my day job I own a company that produces a unique line of tools for model railroaders. Fast Tracks Hobbyworks Inc. so I'm not new to modeling, but probably an "advanced beginner" at best when it comes to ship building.
Last year we bought another business that produces scale stripwood, mostly for model railroaders. Over the last several months I have developed a real urge to build something with wood (probably all that sawdust I've been sucking in since we bought a sawmill...). I decided to dive into a ship model to satisfy that craving. Having a shop full of laser cutters and specialized tools to make stripwood will probably come in handy during the project.
Anyway, on with the build!
After hunting around a bit online I settled on this kit, The Corsair by OcCre. Mainly because it is a bit of a "freelance" design and it would provide a good trial run build before I move onto a more advanced model, whatever that will ultimately be. (providing I get through this one...). Also, I just liked the size and lines of this model. Figured it was a good place to start.
Bought this online from Amazon before I realized I could have bought it directly from OcCre on their site. I prefer to buy directly from the manufacturer if possible.
I am impressed with the kit so far (starting this build log after working on it for several weeks, so I will have to catch up a bit).
One thing I didn't realize is that the instructions in the kit I got are in Italian! Not speaking Italian this is a bit of a hurdle. The kit includes lots of pictures and drawings, so far I am getting by OK with those. But I am suspicious that I am missing some documents as the photo instructions seems to end abruptly when the rigging begins. Other than a 1/2 scale drawing for rigging, there is nothing. I've contacted OcCre to see if I can get English instructions and whether or not something is missing. (I've seen in others build videos that they received English instructions, so I know they exist). If anyone has these let me know!
-T.
- zappto and GrandpaPhil
- 2
Hi all,
After a lifetime of building model railroads, model planes, cars, bikes and everything else, I've jumped into model ships. More of a return, having built a grand total of 1 ship 30 years ago, a Bluenose II. I remember buying the kit at a hobby show in Toronto in November of '87 and telling the vendor I intended to build it and give it to my father for Christmas. He said "This year?". He was right, he didn't get his ship for three years...
Considering it's 25+ years old, it's stood up rather well, even survived a cat.
Currently in Port Dover, Ontario. I own and operate a company that makes specialty tools for model railroaders and have been doing so full time for 15 years now. Last year we purchased a company that makes scale stripwood, again for the model railroad hobby and working with all that wood got me really craving a project from wood. So in a moment of impulsiveness, last month I bought a ship kit, The Corsair from OcCre.
I'm a few weeks into it and really enjoying the challenge! To be honest I have not been challenged enough with model railroading as of late and was looking for something new to do. Also, as my day job for the last 15 years has been all trains all the time, I need something different to occupy my off time.
Here is a link to my current model railroad project if you are interested...
CNJ Bronx Terminal build on Facebook
When I started the ship build I promised myself I would resist trying to improve on the kit. That lasted about 10 minutes... Having several laser cutters and a complete scale stripwood sawmill at my disposal it wasn't long before I started replacing items in the kit.
I made some new deck planking, with pre-drilled holes on the laser to start with. Was pretty happy with how that turned out. Also replaced the few windows in the kit from cast metal to laser cut, which looks much better. Also made some wood wheels for the cannons, didn't really like the brass wheels included in the kit.
Pretty happy with how the planks turned out, although in hindsight I made them a bit too narrow.
Laser cut wood wheels for the cannons.
The first layer of the hull is planked and am looking forward to doing the final layer.
I'm learning a great deal from this group! Some very talented modelers and models here that I'm getting a lot of inspiration from! Looking forward to contributing in the future.
Cheers!
Tim Warris
I realize it's been some time since this thread was completed, but I am working on the same ship model now. I purchased it online, and the only instructions are in Italian and Spanish. Were English instructions included with your kit?
Working away at it from the drawings and photos well enough, but some documentation would be quite a help. Also, I'm a bit suspicious that some drawings are also missing. The only rigging instructions is a single small drawing. The instructions seem to just stop when the rigging steps begin. I've translated the documentation to English using Google Translate, but technical documents don't translate very well and the results are pretty much unusable.
Any feedback is much appreciated! PS - Thoroughly enjoyed going through your build, it will be quite helpful as I work through the same model!Cheers!
Tim Warris
Ontario, Canada
Corsair by T_Warris - OcCre - 1:80 - Heavily reworked kit
in - Kit build logs for subjects built from 1851 - 1900
It's been some time since an update. Over the last month or so I've returned to the project after a long break triggered by the death of my little dog and friend. After that I just didn't feel like working on the project without him sitting at my feet. But, now I'm back at the project and thought I'd post a progress update.
I bought a kit online (where escapes me at the moment) to replace the crude metal cast launch included in the kit. This proved to be a very challenging build! But worth the effort once done. It turned out quite well.
Like a lot of the casting in the kit I wasn't satisfied with their quality. Having a shop full of laser cutters available I reworked the windows on the stern of the ship with finer looking laser cut wood. Again, this was worth the effort as they look much better when installed in place.
Figuring out how to tie the various knots needed... Still lots to learn.
Saying goodbye to my friend.
I designed and built a motorized serving machine which seems to work well! Haven't used it a lot as yet, but anticipate getting lots of use of it shortly.
Foremast almost complete and ready to put in place. Deadeyes installed. I realized after that I had these inverted and have since fixed them...
