Everything posted by niwotwill
Paints dry and now onto first wale. I used a 1/8" strip that i'd bent to fit the shape of the deck plan to determine if my construction matched up with the laser marks on the frames. With the battens on I looked at the line from all directions, felt it looked good and went to lunch and a swim. Came back in much refreshed and the battens didn't look as good as I first thought, so I took the pins out and moved the middle up until the run looked good from all angles. Checked the the batten to the laser marks and sure enough the marks on frames 6, 7, 8 & 9 were approximately 1/32" lower than my batten top. Question, question, and question where was the difference. I took 7 pieces of 1/8" strip and glued the together like the planking will be, using the jig of strips I started moving down the sides to see if the jig aligns with the top of the wale and the top of the bulwark. It aligned perfectly along the entire length of the batten, so!!!!!! I guess its correct. Went back and checked everything again with the same result. Being a retired engineer (I know an electrical one but still and engineer) as the saying goes "there comes a time to shoot the engineer and go to production". I put the wales on. Wale photos to follow Will
Painted the gunport and sweep ports with sanding sealer and then used 400 girt wet and dry to smooth the insides of the ports prior to painting. Spent a fair amount of time cleaning the surfaces to be painted by vacuuming and then wiping with new tack rags to get all the dust and debris off before painting. I'm painting with acrylic paint and am using Winsor & Newton Professional Acrylic on my models. For the red color I'll use vermillion straight from the tube and thinned very little. I really like the color with the contrast with golden oak stain and black trim, pops nicely but not too bright. I'm going to use english holly on the deck with a diluted golden oak stain to give a golden bleached look. Can't wait to see, but first things first.
Getting ready to start hull planking as described in chapter 5. First thing is to paint the gunport and sweep port frame linings vermillion red. Sanding them out to prepare for painting I remembered something I read somewhere "PHOTOGRAPHS SEE AND REVEAL EVERYTHING" so I took closeup photos of gunport and sweep ports and boy what a mess. I then spent the rest of the day filing out each port using small swiss cut files. Take a photo, file more, photo, file more until satisfied. After all completed I'll paint with sanding sealer and check again tomorrow. Thing to remember is PHOTOS REVEAL EVERYTHING. Will
Got stern gunports installed using the same 15/32" square tool used on the port and starboard gunports. Counter filler blocks installed without incident. Marked the bulwark fairing on the outside counter as described in the manual using a wood strip. Faired the counter to the bulkwarks and the counter frames, what was amazing was that I did this without breaking one of the frames. Man are they fragile.
Mick did you ever find info on the rigging you asked about? I’m finishing up a project and hope to start my Washington in a month or so. Will
- 504 replies
- washington
- galley
Mike i read your entire log and now I’m getting ready to start my galley. Still trying to decide on which wood type to use when picked I’ll then rip and mill to size. I think I’ll start my log when I order my timber. i love your work and have one question, oh maybe more but one for now. Did you use silver solder on the stove? Ok another question what silver did you use sheet, wire, or paste? your work is amazing and something to try for Will
- 504 replies
- washington
- galley
I’ll check this out tomorrow thanks
- 1,784 replies
- winchelsea
- Syren Ship Model Company
Chuck when I downloaded the drawings I see that they are 1/4" scale but I don't see a scale on the drawing that can be used to verify printing accuracy and such. This is very helpful to those who are scratch building the Winnie. Could you put a scale on the drawing for us to use? Will
- 1,784 replies
- winchelsea
Yesterday spent placing sweep ports and fairing the sides. I used the same method to get the sweep ports 1/8" square. Ripped a 1/8" strip from a 1/8" boxwood sheet and placed it across the breadth of the ship to align the sweep ports. Next step is on the section 4 of the plans. I still have to test staining and then stain the lower deck. It'll be a couple weeks before I post again as I'll be traveling. Will
More time spent rigging Oh due my finger ache so onto gunport sides. To place the sides I used the plans to mark the location and my jig to insure they'd be 15/32" wide. Fairing the outside and inside took almost a day of carful sanding. I do like this soft wood it's so easy to sand, but also so easy to go to far.
Been to long between posts, as said I'm rigging my Morgan, so I've completed the bulkhead reconstruction. I hate reconstruction almost as much a deconstruction. Spent a day putting the gunport sills in on the starboard side until I realized that I'd read the instructions incorrectly. I'd placed the 1/4" side in the vertical position and the 3/16" side in the horizontal position. Breakout the acetone and soak each glue joint another day spent doing deconstruction. Cleaned up the bulkheads from glue residue and then realized that I might not have enough 3/16 x 1/4 material so I measured and measured and read ahead to see where else I'd need the 3/16 x 1/4. I think I'll have enough. WHEW On to putting the sills in. No more problems. First time a learning lesson. Faired the sills to the bulkheads very carefully, no more broken bulkheads. On to the lintels with no issues. Faired the lintels to the bulkheads with no more breaks. The bulkheads are now quite strong.
OMG!!!!! Rich whatever happened. Do you need anything, any kind of help? Will
- 1,135 replies
- model shipways
- syren
I have a Proxxon MF 70 mill that and I'd like to find it a new home. It's less that a year old, slightly used and in perfect condition. It comes with all the original accessories, a machinist vice and 52 milling bits. The bits are double fluted in sizes 1.5mm, 2.0mm, 2.5mm and 3.0mm. I'll let the whole package go to a new home for $300.00 and shipping. Contact me by PM for addition information Thanks for looking and regards Will
Well with the filler blocks in place and faired along with the deck planking sanded. To get the lower deck planking sanded I made a stick our of boxwood 1/8" by 1/2" and glued sand paper to both sides this allowed me to sand flush up to the bulkheads. Still working on staining. Now its up to fairing the bulkheads outside and inside down to the sizes given in the manual. Oh yeh, only broke three of them. What pain this soft wood is. I thought that with the bulkheads being plywood they'd be stronger, but when sanding the length of the ship the bulkhead do wobble enough to break. So to fix them I felt that just glueing them in place again would not be sufficient so another method was developed. I took some boxwood and planed it down to .02" and glued it on both sides of the fractured bulkhead. I'll make up for the extra thickness by reducing the gunport sides where necessary. To keep the bulkheads in alignment I used the bent strip i used to check alignment seen in a previous post. This kept everything true. Also used another spacer so I could clamp the whole thing together. On to gunport sills Will
Hi all, thanks for the likes and comments. It's been a few days and now I faired the filler blocks to create a false deck. I followed the instructions and placed the below deck planking that will be visible through the companionway door. Sanded the deck planking and stained them with wipe on poly golden oak over the bare wood. Boy does the basswood soak up stain in the most blotchy way possible. No other way to describe it but UGLY, UGLY, and more UGLY. Of the reading of how other people has staining success with basswood. In the mean time I made a sanding stick by glueing sandpaper on both sides and started sanding off the UGLY's. All the while I kept singing to myself "a sanding I will go a sanding I will go". Making a sample of planking to test staining methods. Just a sample of my staining experience before sanding.
That's fast work Rich. It look great. Will
- 1,135 replies
- model shipways
- syren
Your rats nest is starting to make sense and the coiled ropes on the belaying pins are looking superb, very nice work. I have a small comment on the pump discharge pipes, it appears that they discharge onto the hatch cover and into the hold below. Might be me or photo but I thought I'd mention it. Will
- 367 replies
- model shipways
- niagara
Went to my local big box and bought some 3/4" by 1-1/2" poplar to use for filler blocks. I took 2 days to carefully measure and cut the blocks. The hard part was to make sure the block did not move the frame from true square to the BF. I had to sand them so the side that touches the BF was angled to maintain the deck camber. Doing this will make a strong false deck for the planking. The other thing was to make the blocks so a very slight friction would hold them in place while the glue set. Had to go get more poplar as this lent itself too many pieces being too short or the wrong angle for the camber. Even with camber angle I still had to fair the surface but not by very much. Next I'll plank the lower deck that will be visible through the companionway door.
Stay cool as you can I know what heat is, but we've been acclimated to living in the desert. it's going to be 43 degrees today. I read you first page and was so intrigued and that I went to the last page and now I'll go back and read the entire log. It looks great. You're doing a wonderful job. Will
- 550 replies
- confederacy
- model shipways
Well spent the day starting the bulkhead installation on the BF. After the glue had dried I started the filler blocks. Once the glue dries I plank the lower deck visible thru the companionway. Made a couple of ribbands out of plank stock from the kit, using Chucks method of dry bending, I guess I was in a hurry to see how the bulkheads faired. But anyway pretending the ribbands was a great idea I read somewhere in a log on the site.
