Gender
Camas Washington
Interests
Scale modeling. Particularly RC scale aircraft and 18th century ships of sail
HMS ANSON 1781 by albert - 1/48 - 64 guns
AON reacted to a post in a topic:
HMS Bellerophon 1786 by AON – scale 1:64 – 74-gun 3rd Rate Man of War - Arrogant-Class
chris watton reacted to a post in a topic:
Alan, if the carving details continue to give you issues, I’d strongly advise switching to a better carving wood such as boxwood or some other hardwood with a fine solid grain. Bass wood/Lime wood/Linden is fairly fiberous and soft and has a difficulty holding fine smooth details at your scale. great progress btw and enjoying your journey.
Dowmer reacted to a post in a topic:
HMS Tiger 1747 by Siggi52 - 1:48 - 60 gun ship from NMM plans
La Créole 1827 by archjofo - Scale 1/48 - French corvette
paul ron reacted to a post in a topic:
In need of shipyard workers or boats crewmembers
albert reacted to a post in a topic:
Hubac's Historian reacted to a post in a topic:
Dowmer replied to albert's topic in - Build logs for subjects built 1751 - 1800
The incredible quality with speed and number of projects is truely amazing! A true framing master. -
HM Schooner Ballahoo by georgeband - Caldercraft - Haddock drawings
HMS Kingfisher 1770 by Remcohe - 1/48 - English 14-Gun Sloop - POF
Paul Le Wol reacted to a post in a topic:
Siggi52 reacted to a post in a topic:
Congrats Phil, it is a very handsome ship. Most of the mistakes you mentioned will only be noticed by you. And we ourselves are the most critical observer. I have always been tempted to make a revenue cutter representative of the one “on station” up in Port Townsend Washington in the 19th century. If I do, I will definitely be re-reading this thread. But first, I have a Sloop to finish that has been sitting on my shelf just like yours for the past 25years. Life gets in the way but I will finish it some day. Thanks again for the journey. Cheers. 🍻
Phil, my .02, if your ship was at sea, the boat was probably stowed inboard and only moved to the davits when nearing shore. If it is stowed on the davits and not being readied for use, then the oars would be lashed together in a bundle and secured inside the boat. Same for the rudder, stowed inside the boat to protect it from seas. If you were lowering the boat in an emergency you wouldn’t want to be searching for oars and rudder etc in a hurry. You would want them inside. To be honest, it probably had a canvas cover over it as well, so all that detail wouldn’t be seen. If you want to show the detail, then I would rig it as if they are getting ready to lower it away and use it for sea and anchor detail.
- 54 replies
- 18 ft cutter
- ships boat
I agree Phil, I know that many of the ships of discovery in the Pacific Northwest had cutters and small boats carvel built due to the points you brought up. They were much easier to repair when they were far from civilization at the edge of the world under very rough and arduous conditions. Craig brought up some very good info and it is certainly correct as a generalization. However, builder, and different nationalities tended to add differences over time.
- 54 replies
- 18 ft cutter
- ships boat
If you need ideas on how to do a flag that is light and drapes naturally, Chuck Passaro on this site does a nice tutorial on how he does his flags and they look very realistic. It might be in his Cheerful cutter build. I followed his method for the small flag on my longboat. Link is in my signature. It turned out pretty well.
Nice work Phil. You know the old saying, a scale model is never truly finished, you only stop adding details. The working gear (Anchors, foot ropes etc) is a good idea if you want to add that. I’d also suggest a flag and corresponding halliards too if you wish. btw, I know you are in Corvallis, did you ever make it over to the OSU ROTC building there? There is a ship model there.
I like Murphy’s Jest but I think giving it a name is appropriate. As long as you have with it a note as a representative 1800’s revenue cutter somewhere so when someone finds it in like 100 - 200 years from now they know. Lol.
Yes Phil, I second that. The sails look incredible. Appearance, color shape etc. definitely worth the fuss. Beautiful work.
Looking real nice Phil. It’s really coming together. You should be very proud. Question, shouldn’t the truss slings be served?
Johann, the source material you posted from Atlas du Génie Maritime shows the hole for the stay opposite where you have it. I thought perhaps that was an error since the hole close to the edge would be fragile and prone to breakage. However I thought perhaps the stay hole is actually on the far edge like you have it but the angle for the sheaves are opposite direction because the bowline lines cross and enter at a different angle? So the example from Atlas du Génie Maritime, the aft side is actually the other side. Thoughts?
