CPDDET
Posts posted by CPDDET
  1. I agree with the Model Shipways, Shipwrights series route. You might be able to finish the first 2 in the series seeing that you will have ample time on your hands.
    Buy the kits well ahead of time and acquire the necessary supplies like glues, de-bonders  and such.
    You might want to hit the hobby shop and pick up some basswood sheets of different thicknesses to have on hand in case you ruin something and have to replace it with a scratch built part.
  2. 1 hour ago, Nirvana said:
    Been working behind the scenes as both spreaders are almost done.
    I used the old regular solder I had but the outcome is not to my satisfaction.
    Tomorrow there is a small package from Amazon containing Solder-It, which I will try out.
    But here is the current solder of "bolt" on irongate.
    I've been using Solder-it and have been pleased with the results. I just squirt a small amount out on a piece of scrap and use a solder pic or toothpick to place a tiny amount where needed. Then just a touch of the soldering iron and done.
  3. Paid $17 for this light on Amazon.
    It has a very strong magnetic base, but didnt come with a base plate. I picked up some 1.5 inch metal washers at the local Ace Hardware and glued one on on each side of the mill using Gorilla glue. This way I can switch sides or even purchase another light for cross lighting.
    Easy to reach on/off switch and plenty bright enough for my purpose.
    The 12 inch neck is perfect for a mill, saw, drill press, lathe etc.. But not long enough to use on the build table. A longer neck would be preferable for that.
  4. I currently have a similar light on my work top but rarely if ever use the magnifier. Actually I need something much smaller and flexible for the mill.
    Currently researching magnetic LED lights with flexible goose neck. Sometimes called sewing machine lights.
    https://www.amazon.com/gp/product/B07J4ZKGF4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    I might even get 3 of these. I could then move them to different areas when needed (saw, mill, lathe) and also use them on the work bench for cross lighting. I would just use double stick tape for some large metal washers to mount them.
  5. Started off making the battens for the jib stops. Had some scrap cherry so decided to use that.
    Then, after consulting with my usual mentors, made the bands and eyes. My plan shows the eyes slanting toward the ship so I cut the eye pieces at an angle to achieve this and drilled holes in them.
    This was the set up I used to solder the eyes to the bands. I found that using silver bearing solder paste worked great. It has a low flow temp, 450 degrees, and has flux mixed right in. I was able to place very small amounts where needed using a soldering pick. The brand I used was “Solder-It” but solder paste is much cheaper if purchased at a jewelers supply, like Rio Grande. The weights I used to hold the hemostats in place are just BB’s in small ziplock bags. I got 4 pounds of BB’s for 10 bucks on Amazon.
    Mounted the band on a drill bit shaft. Then mounted the drill bit on a hand vice and the hand vice on a bench vice. This gave me a sturdy mount to file the eyes into a rounded shape.
    Test fit before final cleaning and blackening
  6. 3 hours ago, Ed Ku20 said:
    Dave, awesome job on the bowsprit!  It looks great.  However, you've given me a case of tool envy!!  Gonna have to think about investing in a milling machine for my next build.
    Yes, it's nice to have such a tool. But it's a huge learning curve for me. Having no experience at all with a mill, or lathe for that matter, has hampered my ability to use it to it's full advantage. These tools are great but having the knowledge on how to use them is the real key. No magic pill here.
