Posts posted by CPDDET
Finally got back to building the turnbuckles. Life gets in the way this time of year with spring yard work and camping trips.
I really wanted the turnbuckles to be open on both sides, as a real one would be. The challenge was to open one side and then rotate the brass tube as close to 180 degrees as possible to open the opposite side.
I began by drilling a 1/32 hole in one end of a 1/16th brass tube, about 3 inches long. I used the tried and true “block method” to get it centered on the tube.
Then drilled a 1/32 hole in a piece of brass scrap and used an old 1/32 drill bit for an alignment pin. Tacked down the rest of the tube with CA to hold it firmly in place.
Put that in the mill and, using an end mill, cut down to open one side.
After a soak in acetone, I flipped the tube over and opened the other side. Then used my rotary tool with a cut off disk to separate the individual pieces.
I fashioned the simulated “bolts” from 22 gauge wire.
Now I have to clean up all the pieces, and the previously made shackles and get the either blackened or painted black before assembling.
- GrandpaPhil, Prowler901, Nirvana and 1 other
4
Wow! You're a busy boy. 😊
Agreed! She came out very nice. Has a weathered look.
I think Constructo is no longer in business. Web site is no longer available.
I agree, Ebay might be your best bet.
- Keith Black and thibaultron
2
See the link I posted to birchbaysider build log of this boat. Perhaps he still has the plans?
- mtaylor and Keith Black
2
Great find, Kieth!
- Keith Black and mtaylor
1
1
Jim, don't know where you're located but, if your going to bash a kit, it would be great if you could find a current model and get lots of pictures.
2
abordage.com sells built models for well over 1k. Wonder if they would sell the plans and for how much?
Sure is a beautiful boat!
2
2
Don't know where to start with that one. If a kit doesn't exist you may have to do some heavy research to find out the make and model. Then see if plans can be obtained.
- Baker, mtaylor and Keith Black
3
Took me forever but finally have the shackles mostly done for the bowsprit rigging.
Started off wrapping a thin brass strip around a 1/16 brass rod. Then drilled a hole in each one for the pin. The rest of the shaping was done with files.
Still have to clean these up and blacken them. The pin (a small brass bolt being used) will be trimmed after being installed.
- bobandlucy, Retired guy, GrandpaPhil and 4 others
5
2
White glue, like Elmer's will dry clear. Yellow glue, like Titebond will not.
CA glue is handy but a bit messy to use unless you are careful with it.
Don't bother with the thin, long spouts for your CA. Just squirt some on a scrap piece of wood or into a medicine cup and use a toothpick to apply.
- Peanut6, mtaylor, Keith Black and 1 other
4
If you do bring some stock of basswood. Be sure you have a steel ruler and small square. Thin basswood can easily be cut with an xacto blade. A razor saw and miter box might not be necessary. The money better spent on a set of files. Don't forget various grades of sandpaper.
2
Good tip that mistakes can always be fixed. It's only wood and replacement parts can be fashioned from stock sheets of basswood. And wood filler can be a savior as well.
Before you purchase basswood sheets, check the thickness of the stock that come with kit so you know what to buy.
Also check out YouTube for your dory build.
Keep us all posted on you decisions and progress.
2
Lots of good advice and information in these posts. But don't get confused or bewildered. Stay on course. Make out lists for needed tools, supplies and reference material. Try not to get overwhelmed. Being organized, calm and patient will serve you well.
- mtaylor, Peanut6 and Keith Black
3
While the shipwrights series does come with the "necessary" tools, you might want to consider a few others in case you need to make a scratch part. That may include, but not limited to a steel rule, small square, razor saw and set of files.
Your inability to acquire things while on fire watch puts you in kind of a pickle. Take your time in building a complete list and asking others on this forum for their input.
Once you have chosen a model, let us know which one it will be. That will be a big help on giving you advice on tools and supplies.
- allanyed, mtaylor and Keith Black
3
Newbie on Deck
in New member Introductions
Welcome! Always great to have new members!
