Everything posted by Dr PR
I just finished a 12 hour print with the Phrozen Fast Black. The results were awful! This is the same file printed with Anycubic Basic Grey: This is right off the printer, after washing and curing. I haven't painted the part or tried to smooth the surfaces. I used a 0.03 mm vertical step/slice height and the Chitubox Advanced settings for antialiasing and image blur. The Anycubic exposure time was 2 seconds and the Phrozen Fast Black exposure time was 2.5 seconds. The big difference was the Lift speed and Retract speed. For the Anycubic resin they are Lift Speed = 240 mm/minute and Retract Speed = 360 mm/minute. For the Phrozen Fast Black they were 60 and 150 mm/minute (the values recommended by Phrozen for their printers). These slow Lift and Retract speeds more than doubled the print time. Here is another comparison: The saluting guns are about half an inch long. The Basic Grey resin produced details (nuts and bolts and the breech lever) as good as the Fast Black, but without all the "jaggies". Printing with thinner vertical step sizes will produce smoother surfaces. I have used 0.01 mm with some Basic Grey prints with excellent results. But Phrozen recommends a minimum of 2.5 mm for slice thickness. And if I used 0.01 mm slices it would take three times as long - 36 hours - as with 0.03 mm steps, and that is over six times as long as with the Basic Grey! There may be a way to get smooth prints with the Fast Black resin. A longer exposure time might allow the anti-aliasing features to fill in the grooves in the jaggies. One fellow said he uses 4 second exposures. But even if you can get smooth surfaces with Phrozen Fast Black it may take many times longer to get equal results with Anycubic Basic Grey. Needless to say, I am not impressed with the results with Phrozen Fast Black! I may try a few more experiments, but for now I am not planning to use this resin for modeling.
Looks like we are working on the same Mantua kit, except I have the 1980s "Goleta Typica di Baltimora" version. I am kit bashing it into a "typical" US revenue cutter of about 1815, although I am learning that there is very little information about what was "typical" for a revenue cutter! My worst typhoon experience was a cruise from Yokosuka to Vietnam in July 1971. We went through five typhoons and a tropical storm in three weeks! There were typhoons everywhere in WESTPAC! We didn't do anything in Vietnam and after three weeks of taking a pounding dodging storms we had to return to Yoko for repairs. Our O3 bridge deck was 40 feet above the load water line and I have seen green water crashing down from above as we dove into >40 foot waves! I can't imagine being out in that in an 80 foot schooner!!
Kevin, Thanks for the tip. Maybe I'll try an elegoo resin after I have experimented with what I have. A real problem is trying to figure out the settings to use for new resins. I have the Anycubic Basic Grey settings down pat for the Photon Mono printer. Now I am experimenting with the Phrozen Fast Black, and the settings they recommend for their printers are MUCH slower that what I used for Basic Grey (it is taking four times as long to print the same objects). But the Phrozen test object came out almost perfect using the settings recommended for one of the Phrozen printers. Many of the details I am printing are very small and extremely fragile with the Basic Grey. The Fast Black resin was recommended by three very experienced users on The Ship Model Forum because it is slightly flexible when cured and much more rugged than the crystalline Basic Grey. Fast Black is also water soluble and can be rinsed without using alcohol.
Brewerpaul, Many people make eyebolts by looping wire over a pin or rod of the correct diameter for the bolt opening, and then twist the ends of the wire around each other to close a tight loop around the rod. There are a couple of threads on the Forum (if you can find them) showing how to make a simple tool for the job. This produces a "screw thread" in the wire that gives glue something to grip. It requires a larger diameter hole than a single strand of wire, but that is a benefit if you are drilling them by hand - fewer broken bits. And it is easier to get glue into the larger hole. I think epoxy is far and away the best glue for this application - especially the thin clear two-part epoxy "paint" that flying model airplane builders use to seal the wood around the engine to prevent fuel from soaking into the wood. Thin epoxy will grip the rough inside surface of the hole in the wood, and it will harden around the "screw" producing a very strong bond.
Your New "cautionary tale" posterchild here!
Dr PR replied to Valkyrja68's topic in New member Introductions
Valkyrija, Looks to me as if your first ship model is doing just what it should do! No one makes a perfect ship model on the first try, but hopefully they learn why it is not perfect and do a better job the next time. And we learn new methods and materials as we go, making us better modelers. Don't get you hopes too high. I have been building wooden ship models for at least 60 years, and I am still no where near perfection! But I am learning! -
George, I can see no fault in your plan, and because of the great variety in schooner rigs I suspect that some ship, somewhere, at some time, actually worked that way! Your thoughts about how to deal with the clew and tack on a reefed gaff sail are interesting. I don't recall reading anything about how this was done. Why there would be reef points on a sail that could not be reefed is certainly a mystery. I wonder if they were only used when the sail was taken down - to bundle the sail for storage? Or is it possible that the sail was reefed to the gaff boom, like ordinary square sails were reefed to the yards? John Leather's "The Gaff Rig Handbook" is a good read about the history and development of the fore-and-aft rig. But the book is an abominable reference! The index lists vessel names and people's names. But there is no way to find any specific information about features of different rigs - except to reread the entire book!
Rudder painted white?
Dr PR replied to Dave_E's topic in Painting, finishing and weathering products and techniques
As I understand it, the "white paint" for hull bottoms was actually a yellowish off-white mixture of white lead, tallow, and a few other things like sulfur that made a foul gunk nothing would want to live on. However, I know of no reference that says just how "off-white" it was. -
Ron, I am using an Anycubic Photon mono and have been using the Anycubic Basic Grey resin. The resin does stink! I had to move the printer from my office to the laundry room. However, I don't think there is a health hazard from the vapors. It just smells bad. I keep the cover on the printer while there is resin in the vat. I can also run the clothes dryer on a cool air dry cycle to pull air from the room and blow it outside. The alcohol for the wash also has a strong odor. If he odor really bothers you the enclosure with a fan to circulate air in from the outside should do the trick. In theory the fan should pull air in from the outside to pressurize the enclosure, with a vent duct leading back outside. Instructions for some resins say to avoid ignition sources, so unless you have a fan approved for operation in an explosive atmosphere it would be best to have it in the intake side rather than the exhaust side. But that makes the construction of the enclosure more complicated. It would need to be air tight. Most of my printing has been done in the low 60sF (~15C). At higher temperatures the chemical reactions will go faster so I might have to reduce exposure times when it gets hot this summer. I recently bought the water washable Anycubic Eco UV and the Phrozen Fast Black resins. Although they are touted as low odor, the Fast Black has an objectionable smell. I haven't tried the Eco UV resin yet.
I occasionally see posts where modelers have created cannons or anchor chains with 3D printing. The tiny bar-link anchor chains are a special problem because paints often act as glues to fuse the links together. A modeler (Hank) posted a useful tip of The Ship Model Forum for blackening anchor chain. I have experimented with this a bit and here is what I have learned. This is the TransTint water/alcohol soluble black dye. It is about US$24 for 2 ounces (59 ml). For staining porous material the instructions say to dilute the dye 1:32 in water. I tried this with different staining times, and also used the dye undiluted. Here are the results on a 1:96 scale US light cruiser bar link chain with links that are 3.9 mm x 2.3 mm x 0.66 mm "wire" diameter (the rod the chain is made from is called a "wire"): The top chain in the photo is an early experiment with an excessive exposure time that caused the links to fuse - so it made a good test subject. But it shows the original color of the Anycubic Basic Grey resin. The second example was stained for one hour in the 1:32 diluted dye and dried overnight. The third from the top was stained overnight (>8 hours) in the 1:32 diluted dye. The bottom example is a section of freely articulating bar link chain that was stained for one hour and dried on a paper towel in air overnight. The middle two examples aren't much, if any, different. So the staining time doesn't make much difference. These chains are too light. The bottom chain is satsifactorily black. Some of the links were lightly fused after dying, but a gentle twist of the chains set them free. I noticed that some of the black dye rubbed off on my fingers when I was handling the chain. I folded a damp (with water) paper towel around it and a LOT of pigment washed off. After it was dried it looked like this: It was still very black and none of the pigment rubbed off with handling. I dyed a bunch more chains and after drying held them under a slow stream of warm water. A short (one second) plume of dye washed off and then the water was clear. The dried chains are very black and completely flexible. So I think the best procedure is to dunk the chain (cannons) in undiluted dye for an hour or so (maybe shorter) and air dry for several hours. Then wash it for a few seconds in water and let it air dry.
George, Sorry, I did use the terms reef, brail, and furl interchangeably to mean reducing sail area. It is interesting that Berbice apparently did have the fore gaff rigged with standing rigging and the main gaff rigged with running peak and throat halliards. Marquardt shows a similar standing fore gaff rig in the drawing of a Swedish yacht on page 35 and a Swedish privateer on page 38. These sails also have reef bands. These drawings were based upon Chapman's drawings from the 1760s. The drawings of the Halifax (1768) on page 68 and Conquest (1794) on page 86 also seem to show the gaff rigged with standing rigging. However, many of his drawings show typical running peak and throat halliards on the fore gaff booms on many ships of the same period. The Berbice's fore gaff sail does have two brails, so I suspect that the sail was hauled up with the brails to reduce sail area quickly - something important for quick maneuvering. But the drawings do show reef points/bands on the gaff sails, and your question about how you would reef the sail if the gaff could not be lowered is appropriate. I wonder if these "reef points" were just used to "furl" the sail against the fore mast, similar to what you can see in some of the photos I posted? The clew of the loose-footed sail could be hauled up to the mast easily. Marquardt shows this type of "furling" in a drawing of a Dutch schooner (1841) on page 112. So it isn't a new practice. Also, the main gaff sail is attached to the mast with hoops and the gaff does have peak and throat halliards for lowering, so it could be reefed in a normal way. But the fore gaff sail is laced to the mast with what appears to be a simple spiral lacing, indicating that it was not raised and lowered as often as the main gaff sail. I think the loose footed gaff sail was common in the 1700s and early to mid 1800s. But by the late 1800s and early 1900s the main gaff sail laced to the boom was very common on US east coat fishing schooners and racing yachts. I have no idea when this practice first came into use.
Harold Underhill's "Masting and Rigging the Clipper Ship and Ocean Carrier" (Brown, Son and Fergusin, Ltd., Galsgow, Scotland, 1946 to 1972) was mentioned above. It is the absolute best reference I have found for sailing ship rigging. The 11 page index has about 1500 entries - every term he uses is indexed. It is heavily illustrated and he shows how everything was rigged! Perhaps the only shortcoming is that is is for vessels of the late 1800s, making it less useful for people modelling earlier periods. But it sounds perfect for what you are looking for. He talks about British sailing vessels of all sorts, not just clippers. By the late 1800s most ships were rigged in about the same way - the most efficient way. I have been studying rigging for some time now, and when you do not have an authentic rigging plan for a ship you are left with guesswork. But there are a few general "rules" that were followed, because they worked. First, most lines that led in to blocks on the mast or mast heads ran down to the deck at the foot of the mast. This was especially true of lines coming from lower points on the mast. Sometimes lines from the higher points were led down to the bulwarks. Second, lines from lower points were belayed forward of lines from higher points. Keeping these "rules" in mind, rigging was also positioned for the least chafing between lines and sails. Usually it is apparent how the lines lead down to the deck so they don't cross or foul each other. And when ships were rigged they started with the lower masts, spars and sails and worked upwards. So the upper rigging was worked around the already positioned lower lines. Where they were belayed is another story! Fife rails, knightheads, pin rails, cleats and several other things were used. Just about anything you can tie a rope around. And sometimes lines were led through eyes on other lines, and even belayed to cleats tied to shrouds! If there were any "rules" for belaying points I haven't found them! I think individual Captains or mates just had their ways of doing things. When a line led down to the deck it might have been belayed directly, or it might lead to a tackle of some sort. Lines that had to pull a load. like haliards that hauled up spars, or sheets that pulled against the force of the wind, often had tackles. But others likes like clews and brails that only lifted parts of sails that were being reefed just belayed directly to a pin or cleat. Often clews and brails for a sail were belayed to the same pin.
George, I have come across references to fore-and-aft rigs with fixed gaffs. I think these were more commonly the large many-masted schooners that were built at the end of the 1800s and early 1900s. For smaller vessels it was common to have peak and throat halliards to raise and lower the gaffs. Where the gaff sail was reefed to the boom the gaff was lowered to bring the reef points down enough to fasten them around the boom. The fully reefed sail had the gaff lying on top of the boom with the sail in between. This photo of the Belle Poule shows this arrangement on the fore and main masts where the sails were laced to a boom. A common method of reefing a loose-footed gaff sail (not laced to the boom) was to use brails attached to one or more points on the leech (free or aft side) of the sail. These hauled up the clew and foot (bottom) of the sail toward the jaws of the gaff. This photo of Le Recouvrance illustrates this perfectly. The same method of reefing the fore sail is used on the Pride of Baltimore II. The same method can be used on the main gaff sail, as shown on the brig Niagara: If the gaff sail is laced to the boom (and the gaff) the gaff is lowered to reef the sail. But if the foot of the sail is loose and only the clew is attached to the end of the boom, brails are used to haul the sail up to reduce sail area and reef the sail. This has a great advantage in that only one or two crew are needed to take the wind out of the sail. It is a lot faster and easier than lowering the gaff. And just about everything about the Baltimore clippers or topsail schooners was designed to be fast! Keep in mind that there is only one hard fast rule for sails and rigging on sailing vessels: there is no rule! If it can be done it probably has been done, and ship's crews often experimented with different configurations. So unless you are working from authentic period sail and rigging plans showing how a particular vessel was rigged at any time, it is just guesswork how it was actually rigged. And there were very few rigging plans because everyone just knew how to do it!
My metal ruler was wrong.
Dr PR replied to modeller_masa's topic in Modeling tools and Workshop Equipment
This reminds me of when I was a Freshman in college. My room mate was an engineering student, because his father was an engineer (drove a locomotive). I has a cheap dime store plastic ruler, and another more substantial ruler given to me by a friend. The heavier ruler had an inch scale and another in picas (my friend's father was a printer). I noticed that if I lined up the two rulers with the zero marks even there was a difference of about 1/32 inch between the 12 inch marks. I asked my room mate to see his ruler - another cheap plastic one - and it gave an entirely different reading! My room mate insisted that his was the correct one. When I asked how he could know he said it was because his "engineer" father had given it to him. He wasn't the sharpest tool in the box and flunked out after one semester. This experience created a doubt about measurements that is still with me today. In the scientific and engineering work I have done I have always known that EVERY measuring device has some error. And this applies to every measurement of length, volume, weight, concentration and so on. The idea of a perfectly accurate measurement is fantasy. The trick is to know how much error, or how accurate the measuring device is, and take that error into account. Even in CAD programs, where measurements may be given to 15 decimal places or more, there is always a tiny round-off error because computers do not have an infinite number of bits in each memory location. And calculation programs like Excel that can calculate to 30 decimal places are plagued by round-off errors in calculations that cause tiny errors that add up over time. I have several ordinary rulers and yard sticks, seven architect and engineering scales, and three calipers. No two give the exact same measurements, although the more accurate pieces disagree much less than 1%. And of course they change dimensions with temperature changes, so each device doesn't always give the same measurement. And then there is the WAY you make a measurement that can generate additional errors. But that's another complicated topic on its own. -
I use a somewhat out of date CAD program that produces poor quality STL files, and many of the things I build are made of zero thickness surface meshes and planes. Lots of leaks! I import the STLs into Microsoft's 3D builder and click the "repair" box and presto - leak free solids! There is one caveat. 3D Builder doesn't like closed circles around openings - it fills them in with a plane, blocking the holes. The solution is to be sure all holes are surrounded by two objects (solids, surfaces, etc.). Then the solid that is generated will have the proper hole in it. I suspect this is only a problem with my CAD program generating incorrect STL files. When I use the Chitubox "Hole Punch" feature to make a hole into hollow interiors there is not false closure over the hole, and I haven't heard anyone else complaining about the plugged openings. **** If you are experiencing leaky STL surfaces I highly recommend 3D Builder. But it is only available for Windows 10-11. CAUTION: Be sure to select the proper measurement units in the top bar in Builder. STL files do not contain any measurement unit information. Builder may default to the wrong units - it scaled my millimeter unit parts to centimeters, and everything was 10x the correct size until I realized what was happening. Also, I HIGHLY recommend using the Chitubox "Hollow" feature. I was designing objects in my CAD program with manually created interior hollow spaces, trying to achieve a uniform wall thickness. It was a lot of work! Than I just redesigned a part that wasn't printing well with only the exterior surfaces. I used the "Hollow" feature to generate parts with 2mm thick walls, and the program added the interior lattice supports needed for correct printing. Then I "punch" holes in surfaces that would normally be hidden (bottom, etc.) to let resin drain from the interior. The results were a lot better!
Valeriy, I am saddened and angered at what is happening to your country. I hope you, your family and friends are safe and come through this unharmed.
Fellows on The Ship Model Forum have been experimenting with printing large flat surfaces without any supports - just flat on the print platform. This produces very flat thin pieces like decks. The initial long exposures for the base layers will create a small wider bead around the part on the print platform, but this is easily filed/scraped/sanded away. Because the contact surface on the plate is so large you don't need many long exposed base layers. Some have made successful prints without them.
Jan, Howard Chapelle actually describes this in "The History of the American Sailing Navy" (W. W. Norton & Company Inc., New York,1949) on page319. "... the pivot bolt was placed on top of an upright post, or column ... The height of the pivot post ... was decided by the height required to permit the gun to fire over the bulwarks." On vessels with high bulwarks the guns had to me mounted very high. He says "This mount was not particularly strong, and for some years it was confined to the use of pivoted carronades. ... This type of pivot mount became popular in all armed schooners, even merchant vessels, and particularly in slavers." Casey, You are welcome. But I must add a word of caution: You are very close to falling down the rabbit hole!
Pat, Nice railings. I have been thinking about how to make railings for the OK City model for about 12 years. They have extremely small diameter sections. I have been planning the purchase of a small high tolerance milling machine just to drill 0.008" holes through 0.013" brass wire to make the stanchions. Even with a very good mill I foresee a lot of broken bits and scrap pieces. There are between 450 and 500 stanchions that will have to be prepared! **** I ran the chain prints again, using a 0.04 mm step size and 3 second exposure (as opposed to the earlier 0.02 mm step and 2 second exposure). Half as many exposures but 50% longer exposure time. The design diameter of the chain "wire" was 0.66 mm. The horizontal links came out 0.75 mm to 0.84 mm thick, 14% to 27% oversized. The vertical links were 0.63 mm to 0.66 mm, or 95% under size to 100%. Most of the links were free or slightly fused, but when I gently twisted the chain around the long axis almost all of them separated. So this was near the limit for getting a flexible chain. However, I printed three chains and one did not print completely. I think the 2 second exposure was better because it have thinner vertical layers - even though I was printing layers twice as thick as before, so only half the number of exposures. I can see no visible difference in the surfaces of the 0.02 mm vertical step and 0.04 mm step parts, so 0.04 mm is adequate. Actually, these things are so small that if there was a difference it wouldn't be noticeable. There really wasn't much difference in the thickness of the vertical links between the two runs, so the longer exposure time made no difference there. But it certainly did make the horizontal link thickness greater even though there were only half the number of exposures. And that was causing the links to fuse. So it looks like the optimal settings for these tiny parts 1s about 0.04 mm step size and 2 second exposures with the Anycubic Basic Grey Resin - which they call "Colored UV Resin" on their web site - on the Photon Mono printer.
Casey, Welcome! I looked up the EMMA/Sidmouth kit. It is a Baltimore clipper, or topsail schooner. The gun on the centerline is a pivot carronade. Carronades were large bore short barrel guns that had a short range but threw a large shot (or a lot of shrapnel, grape shot, etc.). They could do a lot of damage at short range. But their main advantage is that the short barrel made them a lot lighter than a long cannon, and topside weight is always a problem in ships, especially small vessels like schooners. I am building a very similar Baltimore clipper and have been researching these vessels for several years. Here are some links for topsail schooners: https://modelshipworld.com/topic/19611-albatros-by-dr-pr-mantua-scale-148-revenue-cutter-kitbash-about-1815/?do=findComment&comment=598658 https://modelshipworld.com/topic/25679-topsail-schooner-sail-plans-and-rigging/?do=findComment&comment=750865 https://modelshipworld.com/topic/30234-topsail-schooner-belaying-plan/?do=findComment&comment=862302 https://modelshipworld.com/topic/27410-small-ship-anchor-handling/?do=findComment&comment=787942 https://modelshipworld.com/topic/29060-schooner-heads-1700s-through-1800s/?do=findComment&comment=829120 My prime reference for Baltimore clippers is Howard Chapelle's "The Baltimore Clipper," Edward W. Sweetman Company, New York, 1968. Lennarth Petersson's "Rigging Period Fore-and Aft Craft" (Naval Institute Press, Annapolis, Maryland, 2015 is a nice reference for rigging topsail schooners. Chapelle's "History of the American Sailing Navy" (W. W. Norton & Company, New York, 1949) page 319 discusses pivot carronades on schooners. They were quite popular about the time of the War of 1812. Chapelle's "History of American Sailing Ships" (Bonanza Books, New York, 1985) tells a lot about the development of Baltimore clippers and topsail schooners in general. Chapelle's "The search for Speed Under Sail" (W. W. Norton & Company, New York & London, 1967) goes into the historical detail of the development of the fast schooner. Karl Heinz Marquardt's "The Global Schooner" is one of the best references for schooners. It is the "Lees" reference for schooners. James Lees' "The Masting and Rigging of English Ships of War" is generally considered one of the nest reference for sailing ship rigging, but it does not mention schooners. If you want to learn about nautical terminology and rigging ships here are some references: Falconer's "Universal Dictionary of the Marine," 1769 is a good dictionary of nautical terms. It is available online on Google Books and some other places. Steel's and Biddlecombe's "The Art of Rigging" has a dictionary of masting and rigging terms. They are available online here: https://thenrg.org/resource/articles Biddlecombe "The Art of rigging" (1925, Echo Point Books & Media LLC, Brattlleboro, Vermont) is also available in print. Darcy Lever's "Young Sea Officer's Sheet Anchor" (Algrove Publishing Limited, 2000) has a very good description of masting and rigging terms with excellent illustrations. And if you really get into schooners and want to know more there is Chapelle's "The American Fishing Schooners" (W. W.Norton & Company, New York and London,1 973). By now you should be guessing Howard Chapelle did a lot of research on schooners of all types. So there is everything you wanted to know about schooners and a lot more!
The "wire" in the CAD model anchor chain is 0.6615 mm diameter and a circular cross section. The printed parts are oval in cross section, 0.62 to 0.65 mm on the vertical and 0.71 to 0.74 mm on the horizontal. So I am getting about a 2% to 10% reduction in the width on the film, but an additional 10% to 12 % thickness on the vertical. I expected the parts to be a bit too thick on the vertical dimension. From past experience I knew that the very thin parts are translucent so additional resin gets cured on the upper surfaces of very thin slices. But I can't explain why the parts were thin on the horizontal dimension. I would expect resin to be cured over the entire pixel width but this apparently is not happening. Increasing the exposure time probably would increase the horizontal width, but it might also cure more resin in the vertical dimension. Increasing the step size would reduce the total exposure time, and perhaps reduce the vertical thickness. I am happy with the results I got - no one (except me) is going to be taking a micrometer to the chain on the model. But I might try printing them again with a different step size and exposure time. With a model diameter of 0.66 mm the 0.02mm step size gave 33 slices and exposures. A 0.03 mm step size would give 22 slices, 0.04 mm would give 16 and 0.05 mm would give 13 slices. So I might try the 0.04 mm step size to halve the number of exposures and try to reduce the vertical diameter, but use an exposure time of 3 seconds to expand the horizontal width a bit. **** The reason I want to control the printing better to get a circular cross section is that there are many yards/meters of life rails on the model. They real parts were made of pipe 1.25", 1" and 0.75" diameter. At 1:96 this comes out to 0.013", 0.010 and 0.008", or 0.33 mm, 0.25 mm and 0.20 mm. This is less than half the chain link "wire" diameter. I have successfully printed 0.20 mm diameter pieces, but they are extremely fragile. I really don't want the parts to come out any smaller, but 10% oversize would be OK. But I want them reasonably close to cylindrical. I have been reading up on some of the flexible resins. I would think these would be less susceptible to the accidental bumps that happen while assembling models. But several sites say they are not suitable for thin walls, and the minimum thickness should be 1 mm, or 125 times the thickness of the smallest pipes! Furthermore, because they are flexible they may not separate from the plastic film evenly and become bent while printing. This is also probably true for regular resins, so lots of supports will be needed!
Pat, Your DUKW "duck" drive train brings back memories. I grew up in Hot Springs, Arkansas. It is a tourist trap - it had about 270 hotels and motels (individual businesses, not rooms) when I was a kid in the 1960s. The town is surrounded by lakes on two sides (actually it has grown around the lakes these days). There was a company with a fleet of "ducks" to take tourists on rides around the lakes. I never rode on one. But I worked for an auto parts house in high school and college driving a delivery truck. The DUKWs had a bunch of universal joints in the drive train (I don't remember the actual count but I can see eight in your model), and they wore out fairly quickly. And of course there were the engines and lots of other parts. I made a delivery or two every week to the "duck barn." Hauling the engine blocks back and forth for rebuilding in our machine shop was the most difficult part. I think they are still using some of those things that are older than I am!
Kevin, So far I have used only the Anycubic Basic Grey resin. I would like to try other resins so please post your results as you try new types. From posts other people have made on the Ship Model Forum (lots of scratch built modern vessels) I know there are some resins that are flexible when cured, and do not break as easily as the harder more crystalline resins. These are useful for very thin things like life rails that get bumped often while building the model . I have yards of railings on the Okie Boat model and have been wondering how I can make them to scale. The thought of making thousands of solder joints too assemble the railing out of 0.008 and 0.010 inch diameter wire is not appealing! I do not think railings that thin printed with the Anycubic Basic Gray will stand up to any accidental bumps. It is pretty brittle when cured. Pat, I wonder if the white crud on the chains is the result of over curing? Some resins (including Anycubic Basic Grey) turn white and crusty if overexposed - I speak from experience! Since the chain is small and very thin I used only a two minute exposure, then turned it over, and gave it another two minutes. And I was afraid four minutes might be too long. I am using a 20 Watt 405 nm light with twelve UV LEDs and a small light powered turntable. They are enclosed in a box lined with crumpled aluminum foil to create surround lighting. For large parts I use 5-10 minute exposures. I was surprised to see that very little material from the supports was left on the chain. There was some, often because I didn't get a clean cut when freeing the chain from the supports. I spent an hour or so examining every link (on three chains) and cutting/scraping the tiny bits of residue. There really wasn't much to remove. Actually, I have been using Chitubox's "medium" supports but I do think I reduced the contact diameter to the smallest size for this job. Another fellow (on the Ship Model Forum) who printed a small chain like this said he just pulled it off the supports and it came away like a zipper opening. I wasn't that brave, but most of the links came free of the supports just as I was handling the thing while clipping some of the supports. I was able to remove the chain from the supports with just some sharp pointed tweezers. Just a slight twist on a link caused it to separate from the supports, and that usually freed the neighboring links too! The first (failed) print had two supports under the vertical links and four (two each side) on the horizontal links. This left lots of residue at the points the supports contacted the links. But after separating the fused chain from the supports I decided that I really needed half that number for the second attempt, and it worked fine.
Here is another example of playing with the printing parameters to get the job to come out right. I decided to try to print the anchor chain for the OK City. I have never been able to find stud link chain the right dimensions for the 1:96 model. The links are pretty small - 3.95 mm x 2.4 mm (0.155 x 0.094 inches) with a "wire" diameter of 0.66 mm (0.026 inches). In Navy terms the round bar that the links are made of is called "wire." The wire for the 1:1 links was 2.5 inch diameter. These are images of the supports that I added manually in Chitubox (the automatic support add function placed too many and they were somewhat haphazardly positioned). The first attempt used 0.01 mm vertical step size, 3 second exposures and the Chitubox Settings/Advanced anti-aliasing feature was enabled. The print was a failure - all the links were fused together. I figured there might be several causes. The 3 second exposure was curing more resin around the parts. Using 0.01 mm step size meant more exposures. And the anti-aliasing function might be blurring the image a bit and causing some exposure in the space between the links. Next I used 0.02 mm vertical steps to halve the number of exposures, and 2 second exposures (the minimum exposure time recommended by Anycubic for the Basic Grey resin and the Photon Mono printer). I also disable anti-aliasing. Success! The top "chain" has fused links. The lower chain has every link separate as they should be. Here is a close-up of the chains. The upper chain links are smoother because of the larger number of steps and possibly because of the anti-aliasing. You can see the cured resin in the gaps between the links. You can clearly see the open gaps between the links in the bottom chain They might be a bit rougher than the top chain, but they are definitely good enough! Now I have to figure out how to paint them (black) without gluing the links together. A really nice thing about being able to print the chains is that I can include the anchor shackle and a swivel link, and use the correct number of links between them to get the right configuration for the ship.
PRINT FAILURE PART 2 The launcher arms turned out to be my nemesis! The arms are printed in two parts, right and left. They slip into openings in the launcher body and fit together in the middle using the same "lock and key" arrangement in the launcher body and base ring. Stops molded into the interior of the launcher body and grooves in the launcher arms limit the angle of rotation of the arms from horizontal to plus 55 degrees just like the real thing. The left photo shows some successful parts. Very tiny details were printed correctly. The photo on the right shows some of the 14 print failures during the learning process. I finally got two usable prints of each arm - a not too spectacular 22% success rate! I first tried printing them horizontally. After a lot of failures and suggestions from more experienced people, I tried printing them vertically. No joy! Here is an example of the support arrangement for the vertical prints. They were total miserable failures! So what was the problem? Not enough supports, of course. The problem is that Chitubox and I were putting a lot of supports along the very bottom of the part, But because the arm is shaped like two truncated cones attached at their base, the cross section are increases with each slice. And that means the forces involved increase. So what is needed is more supports for each printed slice. A LOT more. But there is a way to reduce the slice contact area. Chitubox has a hollowing feature that works very nicely. And it also can add internal supports so the top of the hollowed object also has plenty of support. This is an image from Chitubox showing a cross section through the hollowed launcher arm. The slice surface area is the darkest blue layer. You can see the internal "X" braces the program adds. This solved most of the problems. I also used Chitubox's "Hole Punch" tool to add drain holes to allow resin to escape from the interior cavity and avoid suction caused as the part rises from the plastic film. The original parts were solid and as the print progressed the s;ice surface area increased and increased until the supports failed. But with the hollow parts the surface area was much smaller and the supports held. But this wasn't the end of my problems! This is an example of one of the failures. The interior part of the arms is supposed to be cylindrical and you can see how the ends of these arms "collapsed." But it wasn't a collapse - the failed surfaces were attached to the supports. If the supports failed why didn't the succeeding layers remain stuck to the film? After the job was finished there was nothing on the film! Mystery #1. This is my guess how this happened. First, as the separating forces increased with each pass, the supports broke, leaving the printed part unsupported on the ends. When the print platform rose to print a new layer the separating force between the plastic film and the printed surfaces pulled the thin flexible print layer down, adding a curve to the surface. When the print stage descended this downward curved part contacted the plastic film and prevented more resin from filling the gap. So the parts still attached to the supports printed the correct thickness, and the part on the end was too thin. At each subsequent pass the existing curved printed part served as the support for a bit more of each slice, extending the curved part. Weird! The solution was to add a lot more supports under the end and inside the "keyhole" to be sure there were enough supports as the print proceeded. But that wasn't the end of the problems! The ends of the launcher rails are supposed to be squared off like the photo at the left. But many of the failures were as shown on the right. Both parts were hollow, and they had the same number of supports! What gives? This was actually a simple fix once I understood the problem. On the part at the left there is a support right at the bottom front end of the rail. This supported the print so it didn't warp. The right hand part also had a support near the front bottom of the rail, but not right at the front. So the rail flexed as it was printing - exactly like the failure in the cylindrical parts of the arms. I added a support at the end of the rail and it printed correctly. And then there was this problem: Same problem. An overhanging part failed to print in one case but not in the other. Looking at the supports tells the story. In this case it was not Chitubox's fault. The picture on the right shows the correct default support provided by the program. But I moved the support on the left because it left a bit of the tip of the support on the flange of the overhanging part. Duh! But again, there was nothing left on the plastic film after the print. So the successive print layers remained attached to the printed part but just flexed with the separating forces. After the support connected to the part the rest of the part printed correctly. This funny thing on the back of the launcher arm was the "Emergency Igniter." If the TALOS booster failed to ignite when we pulled the trigger we had a real problem! The 4000 pounds of class B explosive in the booster accelerated the 7500 pound booster/missile from zero to Mach 2.2 in 5 seconds, at a distance of 8 miles! It made fuel dragsters look like kiddie toys. The flame from the booster was 75-80 feet long. It was a real blowtorch, and we definitely didn't want that in a magazine containing 200,000 pounds of high explosives!! The solution was the Emergency Igniter arm. The cylindrical can at the end held a black powder charge. The assembly could be rotated back and down, and the arm extended to shove the powder charge into the booster nozzle. Then we pressed a button igniting the black powder and that ignited the booster. End of problem (unless the igniter failed to light). And the end (I hope) of my printing problems is the awareness that EVERY part must have a support, especially at the ends, and the total supports must be capable of withstanding the separation forces as the part frees from the plastic film.
PRINT FAILURES OK, take a deep breath! This is complicated. As I said at first, I had a lot of beginner's luck just using default values for the printer and resin. But that didn't last. I finally met my nemesis! This is the TALOS missile launcher on the USS Oklahoma City CLG-5. My CAD model is on the left and the 3D print is on the right. I had a LOT of print failures with this thing before I learned a few important tricks. I still haven't ironed out all the problems, but here is food for thought. On the left is the base ring and trunnion support (launcher body), showing the "lock and key" arrangement to allow the launcher to rotate on the base without falling off. Both pieces are cylindrical and hollow, with thick walls. On the right is a picture of the default support arrangement that Chitubox created. Notice the very large number of supports under the trunnion support and the small number under the base ring (using the same slicer settings). The trunnion support prints every time with no problems. The base ring failed to print every time! The reason for the failure is VERY important! The printer works by lowering the print platform so there is a very thin gap between the platform and the previously printed layers and the thin UV transparent plastic film at the bottom of the resin tank, right above the LCD display. The gap between these objects is the vertical step size, generally between 0.01 mm and 0.05 mm. Liquid resin in this gap is exposed to UV light to harden the resin and create another "slice" layer on the printed part. Then the print platform is raised to allow more resin to flow in, and then lowered to set another vertical step gap for the next exposure. When the resin is exposed it hardens and sticks to both the part being printed on the print platform and the plastic film at the bottom of the resin vat. Then when the platform rises a tug of war ensues between the print platform and the plastic film. Something has to give, and it is supposed to be the bond between the printed part and the film. The first few layers that are printed are exposed much longer than the rest of the part. This creates a strong bond between the printed layers and the print platform. In addition, the bases of the supports are much larger than the supports themselves, increasing the contact area between the printed part and the platform. The contact area of the support bases must be greater than the largest slice section area if the platform and printed part are to win the tug of war. So be sure to use fairly large bases for each support. In the picture above I have used "cubic" (actually square) bases 15 mm x 15 mm. This size is assignable in Chitubox. It is always the weakest part that gives. And in some cases it is the connections between the supports and the printed part. Each support can take only so much stress, and if that is exceeded it breaks. In the case above, there were a lot of supports under the launcher body, and they were enough to take all the stress of pulling the printed layer from the plastic film. But there were not enough supports under the base ring, so when the platform lifted the force of pulling the printed layer away from the plastic film was too great and all of the supports broke. When this happens, after the print is done you find the base of the supports stuck to the print platform and a part-shaped blob stuck to the plastic film. After I manually added about 4x more supports in Chitubox I finally got a correctly printed part! The moral of the story is that you have to have enough supports to take the strain. But of course, there is more. The force necessary to separate the printed layer from the plastic film is directly proportional to the surface area in contact with the film. And the number of supports needed to take the strain is equal to the total force divided by the amount of force force needed to break one support. So if the total force was 100, and each support will break with a force of 2, then the number of supports needed is 100/2 = 50. The larger the surface area, the larger the number of supports needed. In the case above the launcher body walls were thicker than the base ring, meaning that the forces would be greater, so Chitubox added a lot of supports. But for some reason the program guessed the necessary number of supports for the base ring too low, and they weren't strong enough to take the total force. You can't always trust the software (more about this later)! However, there is no way to predict the actual forces involved with the information supplied with the resins, and we don't want the complications, expense and time of setting up and running a laboratory experiment to determine these things. But I think it is a safe bet that you can just divide the surface area of the largest print slice by the cross section area of the supports and get a good idea. Chitubox allows you to set the contact diameter where the tip of the support contacts the printed part. Contact area = diameter x pi (3.14159). And you should be able to determine the cross section surface area of the printed part in your CAD program. So divide the slice surface area by the support contact area to get the minimum number of supports needed. But even I am not anal enough to want to do that, so I just start with Chitubox's default supports and if it looks like there aren't enough I add more. If the print is a success I guessed right, and if not I start over and add even more supports. This is called a learning curve! But that s just the start of this problem. I did manage to print the base ring and launcher body to my satisfaction. But the launcher arms were another thing!
