Posts posted by sir francis haddock
- consitution, ScottRC and EJ_L
- 3
In the instructions the windows are painted on, I didn’t think that looked so good. So I decide to cut out the windows and put plastic to glaze them instead, thinking this would look better.
The windows will be covered by a wooden frame so it did not need to be so neat.
Next was the rudder. This was a bit of a challenge, getting the cut down pins into the metal strips took some time due them flying out of the tweezers. I lost so many of these.
- EJ_L, Haliburton, consitution and 1 other
- 4
- ScottRC, kier, Landlubber Mike and 2 others
- 5
- Haliburton and EJ_L
- 2
- Haliburton and ScottRC
- 2
- EJ_L, consitution, catopower and 1 other
- 4
1 hour ago, TOM G said:
you tube can steer you wrong on a lot of things, your on course for being your first build. and you are enjoying it......... i think you will be building another. mind you these ship kits take a long time to build, and you have to educate yourself as you go along. you may reach a point where you feel exhausted but don't give up the ship....... take some time off, and you will bounce back. now about planking go here http://modelshipworldforum.com/ship-model-framing-and-planking-articles.php www.syrenshipmodelcompany.com/resources/ChapterchapFour.pdf it took me a while to wrap my head around all this, 🙄 this is the right way to do the planking process. TOM G cleveland, ohio u.s.a.
Thanks Tom, the planking instructions seem a bit abstract at 1st. It wasn't until I was actually doing it that it then made sense, after the mistakes .
53 minutes ago, Haliburton said:
I can’t tell from the picture - did you plank the bow reinforcement or is that the sanded ply? It looks like planking and if so those bends look tricky. Scott
The bow reinforcement is just sanded ply.
The planking all done, edges tidy, some gaps. Nothing to big that filler cannot fix. Am amazed it all came together and looks like a hull. The instructions and video say to leave the pins in but I thought it would be easier to sand if I took them out.
6 pieces of plywood for the bow reinforcements and lots of sanding. Was braver this time and used a heaver sand paper that really saved a lot of time. I also discovered that sanding filler is something best done outside.
- 2
- druxey, Haliburton and EJ_L
- 3
- EJ_L and Haliburton
- 2
Next is the planking. This and the rigging is what I expect will be the most challenging parts. The information I found was to start at the top work my way down, then go from the bottom up and meet in the middle, pinning and gluing as I go.
The stern planking was so easy, short planks with no bends. But trimming the ends with a hobby knife and nothing to rest against is something I think will happen a few times with this project.
Sanding the reinforcements took some time to get flush with the false keel. Then the sides to be bent, stained and attached (on the YouTube video it’s called the armour). I live in southern Ireland and there are not many model shops around. Most of the tools I’m using have to be ordered online so I ordered an electric plank bender and small tool kit that had a pin pusher, which were used for the 1st time on the armour. They were easy to use and no problems yet.
- clearway, EJ_L and Haliburton
- 3
- 2
Contact glue is not the easiest thing to use... But it worked after some trial and setbacks. The deck was easy to clean up, pencil the lines and sand. The mirror (board at the back of the deck, not sure of the names?) I noticed has a slight curve around the deck. So I flexed it to see if it would bend, thinking I might have to soak it. It snapped. After I glued it back and stained it I had a big white line of non-stained glue. Will deal with later.
- tarbrush, Seventynet, Elijah and 8 others
- 11
Hello, this is my 1st build. I had only ever made airfix kits in the past (a long time ago) and they always went wrong, with the wings dropping off and the like. I found the Terror kit and thought this would be a good start. I could practise and discover if (1) I could do this, (2) enjoy doing this and get the equipment I need as I am going along. So everything is new to me and I am sure there will be lots of mistakes. But I hope lots of fun.
The skeleton went together easily. The instructions are more pictures showing the order to make it with very little actual instruction. Without the YouTube guide I would be totally lost.
- Elijah, Waitoa, Haliburton and 3 others
- 6
HMS Terror by sir francis haddock - FINISHED - OcCre - scale 1:65
The next part on the instructions is the belay posts. This was where the 1 to 1 deck plan fell apart a bit. I followed the plan with placing them, then watching the YouTube guide and the pictures in the instructions saw that the foremost post needed to be much further forward.
