Capt. Kelso
Everything posted by Capt. Kelso
  1. Check EBay, Vintage Watchmakers/Machinists tools, I found a good Starrett. I have found some handy little tools in this category.
  2. In addition to Elmers wood filler, I use Bondo Glazing and Spot Putty to fill "small" gaps and imperfections. Have used it for many years on wood and metal fittings. Its relatively inexpensive, comes in a small tube, dries fast, easy to sand. However, not stainable.
  3. From my experience anything I have painted with enamel or lacquer white paint has "discolored" or faded over time. I was looking at one of my builds completed in 1992, kept in a glass case and noticed how the white paint has faded. I typically apply (airbrush) a coat of flat Dullcote finish to my entire build, hard to tell if that is the cause.
  4. I have airbrushed with Model Masters Acrylics using a thinner mixture I found on "CYBERMODEL", Distilled water, isopropyl alcohol, flow improver and flow retarder. Used the thinner with Vallejo, AK, Model Shipways paints as well. Just water did not work very well, clogged quickly. Tech Tip: Make Your Own Acrylic Thinner Have only airbrushed acrylics on small items/areas using this thinner. No problems to note. Actually, did not know Model Masters had an airbrush thinner!
  5. For a first build, very impressive! Just a suggestion, as you progress, consider removing the laser burn and sand flat surfaces flush. Good luck.
  6. Good start. There are several good tutorials available which will be helpful, especially on beveling the bow. Here's a link you may find helpful. MS2260-Syren-Instructions-Chapter-05.pdf
  7. Looks good! You may want to consider removing the laser burn from the parts to be painted prior to gluing. Laser burn can be difficult to paint over.
  8. PqLear. You raise an interesting question regarding the traditional finish style of wooden ship models. I have rarely seen a weathered wooden ship model, in a museum, competition, or otherwise. Personally, I never felt there was a standard, weathered vs non-weathered. Didn't think much about. In my opinion it was simply a matter of the builder's preference, scale, "imagination" and skill level. Depending upon the type of vessel, I like the application of weathering. It adds a dimension of reality; it offers a nice change and challenge to a normal build. Also, I don't feel weathering hides detail but oftentimes can enhance it with washes and highlights. But the weathering needs to be done proportionately. I have seen models with the copper hull weathered but nothing above the water line! My photos are intended simply to offer a perspective on differing degrees of weathering I apply. A subtle application to the tryworks enhances a basically dull structure whereas the 1/24 scale Dory is given more depth. As the saying goes, "one size doesn't fit all", "different strokes for different folks".
  9. Agree with rwiederrich easier to install off the model. I learned the hard way, more difficult with the mast installed, especially on a smaller scale like my Harriet Lane.
  10. Looks like the old Bluejacket Kit I built several years ago. I have built a couple of boats and used "The Dory Model Book" by Harold Payson for reference. There are different versions of the Dory, Clam, Banks, etc.., which did not have a standard color scheme. So, if you are building a working Dory or recreational version your choice of paint color is open. Consider the color scheme of the Midwest Sea Bright Dory Lifeboat (I built that as well), sometimes a combination of bright colors with white makes the model stand out.
  11. No matter which method you use (trial and error) I find doing ratlines is a "mind set". It's a slow tedious time-consuming process!
  12. I built this kit, a little frustrating but it was a good learning tool. Gained some valuable experience that I could apply to planking other builds.
  13. Similar to you I decided to take a break from another build. In my case I relocated which meant setting up a new work area and all the hassles involved in moving. When I got settled, I found I lost momentum with my Kate Cory build and decided to work on something "simpler" to get back in the game. I decided on an older Model Shipways Harriet Lane solid hull, 1/144 scale kit. I'm often wondering what I was thinking. Can't comment on the 1/96 scale kit but with regards to the cannon fit, it is very important to make sure the bulwarks are the correct height from the deck to accommodate the cannons before adding the decking and rail. Sounds basic but I decided to put a couple of cannons in place to ensure they fit correctly before gluing the decking. Mine did not fit properly and I had to decide to remove more of the wood hull/deck or build up the bulwark. I decided to lower the deck.
  14. Any recommendations for a source of name plates. I like to add a name plate to the display base, Name of Ship, year built, etc. I used to order from a local stationary store which is now out of business, can't find much on the internet.
