LyleK1
Everything posted by LyleK1
  1. Just a quick update... I was gone for the long weekend. Managed to get about a quarter of the ribs in place: Spacing is accomplished using a couple pieces of the planking material... worked great except when I glued it in place with the rib! Fortunately, I was able to get it back out with no damage! I'll post again soon.
  2. Sanding mostly done... Interior is done and coated with CA to reinforce the seams. Sanded smooth and ready for ribs! I struggled with doing the CA coating but it made a nice hard shell. This model is amazingly light and feels fragile but this step certainly made it feel stronger. Sanding on the exterior is basically done... I'll do some touch up in places but overall, it is done: I starting making ribs... no BBQ sauce! I haven't used the old soldering iron plank bender in a while. Its radius is almost perfect for the bends needed. I soaked the planks for about 15 minutes and after a couple of missteps, I was able make the rest fairly easily. I've got about 25% of the required amount cut and bent. More in a few days. Hoping to get out on the boat for a few days... An update when I return after the holiday.
  3. so·lid·i·ty /səˈlidədē/ Learn to pronounce noun the quality or state of being firm or strong in structure. Well done, Chuck! Not a new word but used in proper context! I honestly didn't know but had to check! The steps to remove thwarts are many! But eventually, they will come out. The bow and stern get a small "deck", plus the are inner wales that will retain the shape.
  4. The “ribs” are the next step after some sanding. They run vertically along the entire length of the boat. Meticulous work but should look great. Interesting info, thanks!
  5. Although I haven't posted in a few days, work has continued! I finished the hull this afternoon! The below sequence shows the progress through to the 15th plank: As I mentioned in the previous post, the last 5-6 planks were by far, the most difficult and I, literally, had to do one at a time before moving on. The required bend/twists needed to shape the hull made it very difficult, more than I had imagined! I ended up breaking 6-8 planks to achieve a finished hull. That's even after soaking and heating and bending incrementally to get the right shape at the stern: Symmetrically, the hull shape looks great! I had to use a various amount of clamps, some not designed for model work but were necessary to push the planks into place. Tools were substituted for wedges as needed too: And finally, the 15th planks on each side had to be shaped carefully to fill the remaining gaps: I did some initial sanding while the boat was still on the strongback... I got to thinking, what if I sand it a little thin in places and it's accidently glued to the strongback!! I'm glad I stopped: I ended up having to cut several of the forms as I had indeed glued the planks to the forms in several spots! It wasn't difficult to remove, I just cut a few of the forms, a little wiggle and they popped right out. Once I was able to get my fingers inside, I used them to push the forms slightly and they popped loose too: If you look closely, you can see the remnants of a couple of the forms. Also, there is some denting on the interior of the planks from me being a little too rough getting the planks to shape properly. I used water on my fingertips and rubbed it into the dents and most of them came out easily. The worst ones at the stern will be covered and not visible. So here is the hull before extensive sanding! The bracing is just temporary to keep the boats shape. On to sanding!
  6. They used a technique called mortise and tenon to join the planks. This is the same boat. It had 12 different varieties of wood in the boats construction. It was speculated that some was by necessity due to a short supply of wood but also repairs performed during its lifetime were done with whatever was available. It would’ve been impractical to attempt to use short pieces for the build since it is built using a strongback. The book mentioned in my first post was written by the man the managed and performed the excavation. Studies of the boat continue to this day.
  7. I started at 10-15 minutes... and on the last plank it was closer to an hour. Additionally, I bent it a portion of the way using heat and then re-soaked it for another 20-30 minutes before making the final adjustments. As you can see, it is clamped in place with just the cut and sanding left. It should drop right into place now!
  8. Working on rounding the hull from side to the bottom: The bend required between the two clamps is a difficult one. I broke three planks before I finally got it! Some shaping and sanding to do before gluing it down: I hope to have the hull done by next weekend... maybe a bit optimistic! These planks are quite difficult to shape. It takes multiple steps and some soaking!
  9. I've never used Tung Oil! I prefer Linseed Oil... I would assume that an oil would best be used on areas that don't have any further work. I'm not sure how well glue would adhere to any of the oils. Typically, I varnish (or use polyurethane) the decks and fixtures. I try to wait until I'm done with gluing everything in place but that's not always possible. Glue will adhere to most varnishes but not as well as unfinished wood!
  10. The next several planks need to be carefully bent/twisted and sanded to meet the very sharp curve of the hull. As I mentioned above, this wood is much softer than what I'm working with on the Bounty (Walnut). It's very easy to shape. Especially, if you soak it a few minutes. I used my hands to make the bends and twists. Once the shape is close, I beveled the edge butting into the next plank by sanding. Also, I'd clamp the plank to the forms to let it completely dry while clamped in place. Here's a few pictures of the progress: It has taken a lot of clamps to hold the shape while the glue dries. Making the turn to bottom of the hull is quite sharp. Gonna try to get out on the big boat this weekend! So, I'll get back to this next week. BTW, I just finished reading the book mentioned in the first post of this log. If you're interested about the possible histories of this boat and the region in general, it's worth the read. I enjoyed it and gained a lot of insight on the history too.
  11. It really is the builders choice. I've done both. I certainly like the "new" look but I think that aging a model makes it look more realistic. However, it can be over done. Covering walnut or any other quality wood is a sin, IMHO! Especially, with the amount of work put into making it look great. I'm sure there will be others that agree and disagree.
  12. I've managed to get one side planked to the seventh row and the other side to the sixth. Pretty easy....... well, that changed with those two rows as the curve of the hull is in play now. I've had some difficulty with the planks wanting to pull away from the frame: I used a piece of scrap to pull the frame together and glued into place. It held for the two planks but popped loose when I was fiddling with the clamps! On to the next idea: I read on another build log that he tried soaking and clamping the plank to pre-shape it. I've done it many times with harder woods but I think I'll try it tomorrow. It might relieve some of the stress of making so many bends on a single plank!
  13. Gotcha! Interesting… I had not seen or read that in the book. Maybe I’m not far enough into it… over halfway but no mention of it. At any rate, as you’ve seen, the planks are a single run on the model.
  14. Are you thinking plank to plank seam? If so, they are quite tight right now but that changes after the next plank or two... I'll need to cut the bevel into about three rows of planks. Shouldn't be too tough.
  15. Welcome Mike from a Puyallup modeler. I would love to see more pictures of the W.T. Preston!
  16. I read that as well, but no, at this scale it hard to follow the exact method. The Mortise and tenon joints would be interesting to build in a bigger version. But not on this scale.
  17. The first two planks on each side are full sized planks (width). The first fits into the notches cut into each form. I had to modify the form closest to the stern to accept the plank at the right angle. The stern end needed to be sanded to the proper angle to meet the sternpost. Once achieved it was glued into place using a medium thick CA (I'm using that for all the plank ends, per the instructions). The remaining plank is fitted into the notches, cut at the bow and sanded slightly to match the bow piece. The first plank: The second plank was done the exact same way: I tried various clamps to get the fit as perfect as possible, using some to keep the "clinker" effect to a minimum and the others to hold the seams between planks nice and tight. Once everything is fitted, I used a thin CA to "weld" the joints between the planks being as careful as possible not to get any of the glue on the forms... not sure how successful I was and I'm sure I'll find out later! The next several planks are tapered and I received the kit with the tapering already done. The process to prepare a plank is as follows. I heated and bent the plank just to help ensure they don't break. Some light sanding and forming at both ends: And then gluing into place just like the first two planks. Clamps hold the planks against the forms and against each other. At the stern, the previously mentioned (and shown) post comes into play to keep the clamps from sliding off: And at the bow, I've modified a clamp by gluing sandpaper to the clamp surfaces to keep it from sliding off: It works really good! Clamps are installed: And thin CA to "weld the joints: I've completed five planks on each side, alternating as I go to keep thing from getting out of whack. Here is where I stopped for today: One or two more planks and I'll be to the curve in the hull and things will get a bit tougher but nothing like working with walnut as is being used on the Bounty in the background!! More in a few days.
  18. I've made some decent progress! The first steps were to build the strongback. Straightforward and pretty simple: The board came pre-marked with a centerline and locations for each of the forms. The post at the stern is not part of the boat but comes in real handy later I glued the marked form pieces together. Again, very easy and straightforward: The only real issues was making sure the pieces were flush at the base. I used regular wood glue for this portion of the job to ensure I had the ability to adjust the pieces, if needed. Next, I glued the forms down on the board per the instructions: I used the thick CA glue for this process. The center two forms were not perpendicular and I added a brace to fix that problem. The keel and stern post came pre-assembled. I still had to shorten the post a bout 1/4" and heat and bend the keel section near the stern as it was not curved correctly... an easy fix. Once satisfied I glued it down per the instructions: The sternpost is glued to the board and the scrap blocks are glued to the post and the board. When it is time to remove the boat from the strongback, I'll simply cut the post even with the blocks (per the instructions). I used a few nails to ensure the keel ran straight over the centerlines of the forms. And then added the bow section using the same method as the stern: So far, so good! Next I'll be laying the first planks.
  19. Looks good! I did the same thing… used this build as a tool to improve my skill level. Even so, it turned out good! I think yours will to!
  20. Weekend plans cancelled... bad weather! The kit did arrive today! It was packed fairly well in a USPS priority mail tube (triangular shaped): Everything is divided into taped together bunches... all marked with writing on a piece of tape: The CD has the instructions... 54 pages with lots of pictures and pretty concise directions. I've read them all the way to the rigging section and found it to be easy to follow with the exception of a couple places that will probably be clearer when I get to it! The first real noticeable thing is that the wood is all rough cut! It is a soft wood and will sand very easily... So, not a big deal for me. The wood is a light Mahogany and Boxwood. The strongback pieces are clearly marked and the positions of the forms are already marked on the base board: The envelopes have various pieces for the finish work... rope, fish net, oars, anchor, etc.: Tomorrow I'll do a proper inventory and get the strongback assembled. Hopefully a few planks too! I have a pretty decent supply of wood and will more than likely replace some pieces to embellish the model just a bit. I've never done this style of build and am looking forward to it... more in a day or two!
  21. Good news... The tracking number shows the kit will be delivered today... Bad news... I'm gone for most of the weekend! Hoping it will arrive before I leave. Knowing USPS, it's nearly a foregone conclusion that it won't!
  22. Well, I did some measuring and indeed the scale is off a bit but really it's not too bad. Not much you can do about a kit build but to go with it!
