Retired guy
Everything posted by Retired guy
  1. Continuation of parts already made, which had parts needing to be made and painted, starting with the boom buffer. Made the two U-shape shackles from a piece of .010" brass using my turbo carver ground to shape then filed to finish shape then made ring next was to drill holes for .016" rod to go through. Painted boom buffer and installed onto model. Next up was to finish the catheads, needed to make small chain link then attach it to the chain as per drawing then put into slot in cathead. Last thing will add is the rope which goes on the end of chain as per drawing from The American Fishing Schooner, the information on this did not come on the drawings of the Bluenose, but I am sure they would have been the same. Finished the hawse scroll work then painted them yellow, will add to model later. Couple of pic's to show how they will look before painting. Thanks for all the comments and all the likes do apricate it. Until next time Regards Richard
  2. Glad to hear eye surgery was and astounding success Keith is there many recommendation on what/not to do? Regards Richard
  3. Hi Gary thanks very much for your nice comment, build is coming along slowly, probably should not have started the Victory 🤔 might have been finished. Putting all these small pieces I made together is making me think what jig would work to help me hold while I fit very small pins/bolts or nuts. Hope to see some of your brilliant workmanship in the near future. Regards Richard
  4. Just spent some time looking at you brilliant build Nils, I see you like the brass work as well 👍 Regards Richard
  5. Thanks very much Hamilton have made most things from scratch, use box wood for all the deck furniture, masts were made from cherry supplied wood is way to soft, scratch worked many things with brass, drawings are great to work with and the Bluenose is such a lovely fishing schooner, its been to fun to build. Regards Richard
  6. Hi Keith, regarding your question, the scroll on the bow around the hawse pipe will have the scroll I have made out of .018" brass wire, still have to paint them. The scroll on the name board I painted by hand was thinking of doing them out of brass, I think they tuned out ok. Regards Richard
  7. To continue on the update I spray painted the Jumbo boom crutch, Riding bitts, Engine box then hand painted the windlass chain/wood welps then proceeded to put it together with quadrants, quadrant links and Rocker, did make a rough little jig to hold parts while I installed shackles. Then using the 1/12 motorbike chain I had mention back when I machined the gears I file the chain down so it looked like the size it should be, after that I sprayed it black. Bought some 1/64 scale fishermen from Vanguard Models which are brilliant here's couple of pic's so that you can see how big these gears were. Next was to install the steering linkage to the rudder, the steering box still needs to be painted. last pic added the three circles between name on stern, still need to paint the cabin housing but did spray paint the Liverpool head and Dreadnaught head. Until next time. Regards Richard
  8. Thanks Dave we had our Thanks giving a while back, but you have a great thanks giving and hope you have a great weekend. Regards Richard
  9. This is going to be another very interesting build to follow along Keith, just looking at all the parts in the engine room , also hope you have a quick recovery on your eye surgery 👍 Regards Richard
  10. Been working on the Victory and kept looking over at the Bluenose and felt it was well due for an update, 1y 2m since last one 🤔 So thought I would start with getting the name and scroll work on a black board, used Clover House dry transfers, Railroad Roman Condensed Bold - yellow which I think was the closest to the drawing. Scroll work I hand painted, do think I should have left a bit more space between letters or letters could have been smaller. https://imagizer.imageshack.com/v2/640x480q70/924/ICnGMg.jpg https://imagizer.imageshack.com/v2/640x480q70/922/wMW0Z2.jpg https://imagizer.imageshack.com/v2/640x480q70/923/H2xbwt.jpg Now the stern name plate was white, did try dry transfers but failed miserably, so started to make a decal, used word to make this but had quite a few rejects. https://imagizer.imageshack.com/v2/640x480q70/923/sokCSb.jpg Tried Inkjet printing first, printing was fine used Experts Choice white decal film for inkjet, then followed the instructions to cover the decal with Microscale Liquid Decal film then let it dry for a couple of days. https://imagizer.imageshack.com/v2/640x480q70/924/1jPdRC.jpg Then went to put decal on the model once I left in water for 45 seconds the ink just peel off the decal leaving more of a white space, so kept trying and could not get it to work (this was the first time making decals) so went on you-tube and one guy was saying you should use a Laser printer, so went and bought a laser printer then had to get white decal film for laser printer. https://imagizer.imageshack.com/v2/640x480q70/924/9Z00Us.jpg So for me this worked yeah https://imagizer.imageshack.com/v2/640x480q70/924/8BQulk.jpg https://imagizer.imageshack.com/v2/640x480q70/924/B88lZV.jpg The three white rings to be done later. To be continued. Regards Richard
  11. Hi Wefalck, No did not file each link just removed about .007" each side by holding chain in a jig, it did make a difference. Regarding straps for deadeyes, these were made one by one first drill the holes using a jig I made, then I marked the shape with a pencil then used my Turbo Carver with a diamond bit I removed by eye free hand to my pencil mark, did not remove a small bit so that I could finish off final shape with file, again free hand. Best regards Richard
  12. Hi Wefaick Not sure how to link my build but if you go to page 10 and look down 3 or 4 wip you will find mine, do have to do an update. Regards Richard
  13. Hi Keith now have painted the chain but before I did I filed the chain down a bit and now it looks a lot better. Best regards Richard
  14. Hi Jan, do have this picture and got the chain to look a little like it now. Regards Richard
  15. Thanks a lot Bob and Nils I will update my blog once I paint it. Regards Richard
  16. Thanks Keith will paint the chain and give some weathering and will see if will appear smaller. Regards Richard
  17. Looking to see if anyone has a drawing, pictures, or better still drawing with dimensions of a Link Belt, which went between sprocket on Boom Crutch to counter shaft stand sprocket on Bluenose 1920 On my WIP here on MSW, back in May 2020 I machined the sprockets and then in post 205 I said I made sprockets to fit a 1/12 scale motor bike chain, well have mounted it now and I think it looks to big, so thinking do I build the Link Belt 🤔 Regards Richard
  18. One heck of a model Robert, brilliantly done 👍 Regards Richard
  19. Hi Craig now we have trucks with eight bolt holes 🤔 Regards Richard
  20. Good drawing Gary thanks for sharing, but look where the guns are, not in the middle of gun port? Regards Richard
  21. Hi Allan, From the A.R. Bugler book, the trucks 18" dia and 16" dia were made from two pieces of 3" thk cross-grained curly English Elm, turned on a lathe then bolted together with six iron clench bolts so that the grain ran right angle to the other. Regards Richard
  22. Very nice model Richard, that last picture is brilliant. Regards Richard
