mikegr
Members-
Everything posted by mikegr
So I did a lot of research before starting the base. As always I will try a new method. What is very essential in a water layout is the texture.I have long time quited the random pattern created by foil sheet and create mine. Today an artist paper will be used with wavy rough surface which still need some modification. So I cut the paper and glued it on a 2cm Styrofoam piece. Next, I gave it a couple of thick primer coats with brush to smoothen it up a bit. The result was mediocre so process was repeated with heavy gel instead of acrylic. This also gave me the chance of reshaping the surface in some areas by creating waves in the same direction of the preformed ones. Then i took a few hours off to research about bow waves. My target is a higher speed ship on a light - moderate weather. Curling a semi dried piece of gel glue I managed to get a desired shape. Next phase was an initial layer of dark blue acrylic and take a photo while its still wet to appear a temporary glossy effect
Cap San Diego by mikegr - 1/160
mikegr replied to mikegr's topic in - Build logs for subjects built 1901 - Present Day
Next was to replace the swimming pool. I printed the walls, glued them together. Wood fillet chopped ,varnished and put on. Next step was the davits. The base was 3d printed but the upper part was a bit hard to draw so it was scratch built from 1mm styrene. Then 2.5mm reels added. -
I'm working at the funnels. Its a highlight spot of this ship. I printed a couple of pairs and I had to do some scratch work to correct some mistakes After lot of sanding I get a desired outcome -
Work on cranes started. I printed the parts. Then assembled together and paint. Put crane frame supports using 1mm chopped plastic rod. After the fitment I scratch built a crane holder and glue it on port side on deck. It was difficult because my scratch built skills have been deteriorated since I spent most time on 3d design than making my parts by hands -
Thanks for the comment. I did avoid early painting to avoid any accident as I am quite messy Too much trouble for little progress. I added some shelters on bridge deck. Started with scratch building then decided for a more delicate job so I just printed them. Still measurements were incorrect, so multiple couples were tried to get the final fitment. On the top I used sandpaper 280bgrit pieces to simulate the material show on first pic. Before installation, a pair of compass were fitted one of each side of the bridge -
Thank you Actually a year ago I was no related to 3d design either. And 3 years ago I was wondering how people could make ship models without a kit, just only from plans -
While working on the masts suddenly realized that I was totally out of scale. I reprinted two of them with some modifications on top and other an one inch extension to the 3rd one. Then i moved to test fitting. And a last pic with the funnels on -
I installed PE, mostly nets and few others. Rigging time. A combination on melted sprue and elastic thread for longer pieces. The way I handle sprue fibers is with the tip of a file sometimes bit wet for extra grip. I do not use sharp tweezers as it can bent the pieces. At the end of the file a needle is attached were I use to deep into PVA or CA glue if I want a quick dry. After rigging work is almost done, time to deal with air crew. Note that this is my first extra modified kit with addition of resin self design parts so some fittings problems occurred. Buy I need to move on.
Thanks for the comments. It is the small scale actually that helps me to make these as in 1/350 or higher, more detail would be needed which I cannot design at the moment. Back to the building, I sanded the PE parts and sprayed them with epoxy primer. Crane was assembled but a mast was needed as well. So I scratch built one copying the Pontos model.
Working with printed and PE parts together gave a better appearance but it proved time consuming while results could be better, the tiny PR parts are quite hard to handle. So I started experiments by printing my own Bofor guns. Here is a test print along with a pair or Phalanx which I think are too small for 1/700 I need to recheck
Books to learn Fusion 360
mikegr replied to allanyed's topic in CAD and 3D Modelling/Drafting Plans with Software
I have started using this tutorial. Its also updated, 2023 -
Back to work after some absense. After installation of 5" and AA guns it was time to paint the hull. Unfortunately the paint used for the funnel didn't perform well with the airbrush and such a large surface would take me several hours to paint it. So I bought a spray can knowing that matching the color would be impossible. Only option would be using weathering techniques to match the colors, using a brush for hull painting wasn't an option. I then applied several shades of blue with dry brushing from dark blue to whitish gray. Then did some chipping mostly on waterline and bow. Finally used mat varnish and oil wash on guns and platforms, as well as bit of rust. Bridge and funnel were also lightly dry brushed with same colors to reduce the difference with the hull. To a comparison here is a job of Master Katseas with his Tamiya Saratoga. You can see the great job done on panel lines
Kαλως ηλθες!
its just an example any epoxy product for the car industry will do just find. Make sure its 1K (one ingredient) as a 2 part can, after mix probably won't last long
- 330 replies
Epoxy primers or etch primers for car industry may work good as well. https://carsystembg.com/en/cs-etch-primer-spray-478
- 330 replies
Thanks for the encouraging comments. Hamburg has a very nice nautical museum which I hope I visit one day. Now back to the project, while preparing the superstructure for final fitment I made the winches: main body and another piece were designed and printed plus a plastic rod and a pin. I used copper wire primed and painted black. then i put the winch cylinder on the main body and secured the whole system with a pin which i chopped the extra length and glued the last part. so got a fully functional system minus the motor which i can adjust the length of the wire during the rigging phase, i only need to add more black paint to fill the gaps on the white reel. -
I am working on the pulleys. The number required is great, Not sure about wooden ships but here more than 50 needed from what i see on the plan There are also double and triple pulleys that will be used. I am using photos of my archive as a guide to position them and differ remarkably from my plans. Rigging will be more challenging that it seemed initially. Most possibly won't be 100 accurate but thats ok. Meantime I decided to install the anchor machinery and drill the anchor holes all the way to the ship sides while working to improve paint details on deck -
Work slowed down because of other project but now I'm back on track. I decided to make the masts. Wasn't sure how, finally the design and 3d printing was chosen instead of scratch building. After many hours of design I got the first result, two successful prints while one collapsed partially. Using my skills I manage to repair it and save another 6 hour printing season. -
I quickly ran out of PE parts for the guns and a new order has been done but my work will delay some weeks. Therefore I proceed with the 5" inch guns and some 20mm ones from my parts stash. The latter is a two piece part and took me some time to assembly together and install on deck Thinking of what to do next I designed my own Bofors single guns. They came in two batches, the second was impoved and including shoulder rests. It looked better than plastic ones already installed so it will be my standard for next projects. Lesson learned.
for example the rivets on funnel and turrets while add detail to the model i think they are way overscale
