Mirabell61
Everything posted by Mirabell61
  1. thank you Martin, I was soldering with my most powerful iron here, in order to get enough heat to the metal enabling and the solder flow. Was too anxious to use the gastorch so close to the painted parts.... Nils
  2. lovely work James, the wood, the parts, and the way of mounting, relects and provides the instant impression I had myself, of having a Billng kit before me. when I was building these many years ago. I remember very good straking lines over the outside bulkheads, and precise fit of parts. The pic of that hull, mounted with deck and bullwark fit speaks for itself... Nils
  3. many thanks to Steve, Grant, John, Patrick, Pete, Albert and all the "likes" Steve, thanks for your comment, glad the model is liked by yourself Grant, nice compliment, much appreciated John, Thanks for the compliment, I`ll try to remember enclosing an overall status view now and then Patrick, I`m very pleased it finds your approval Pete, your kind words and your compliments are much appreciated, I also liked the part of "....project workflow all laid out in the head....", because its realy so only without fine details, then I work with scetches...and looking up semi-material (profiles and so) I can use Albert, thanks for your compliment, I`m pleased you like it.... Nils
  4. Hi Matt, your Dutch pinnace is a beautiful model and a pleasure to see this being built on your shipyard. I love and admire your accurate and clean work, also beautiful photographing.... Nils
  5. Amalio, your positive model is so awsome to look at....... fantastic handcraft work, a lovely ship !!! nevertheless I have given up to straign my mind, what you are doing the outer mold for, of couse it fits like a second outer skin........, hopefuly you will provide the solution to that thrilling "riddle" of yours soon. I trust you have an mighty ace-card up your sleeve.... Nils
  6. Update.... the fastening of the deck-edgerail works fine, its also quite riged afterwards. The wooden deck will end about 2 mm away from the rail edge, so that partialy the railing on the aft boatsdeck portion finds a good hold, and same time its a good waterlead all around the deck Nils preparing for the soldering work the rail must be kept down on the spacer tubes and fixed there during soldering the overstanding stanchions will be clipped off, before the deck goes on now the most tricky part is done (aft boatsdeck edge-rail)
  7. Siggi, wunderbar !!!! it looks brilliant (both modsels) in that case with "sealevel" Congrats to to that achievement, you did a fantastic job... Nils
  8. Thank you Carl, much appreciated, I`ll keep in mind to ask Kees, when the time for boatsfabrication arrives..., relating to the challenge, I`m always open for innovative techniques, as far as I can do with my humble toolpark Nils
  9. Many thanks to Tony, Mark (Taylor), david, and Carl, and all the recent "Likes".... Tony, thanks for your words... If you search the web for a certain build plan you may not always find a plan in the quality as detailed as you know them from the kit plans, but for a scratch builder, one must be happy with whatever was found. Often there are books with printed lines- and frameplans, and if you have luck you can see the corresponding frame spaces.... Mark, thanks for your compliment, in the moment for example there are no plans how to fit on the upper boatsdeck, so its basicly working to what I think may workout, and doing trials... David, unfortunately I have no experience with hot air styrene forming over plugs, or vacuum forming, like member Kees did with his hulls (very interesting method) Carl, see enclosed pics... it is my aim to go for that way. Some months ago I found and purchased a clinkered open double ender lifeboat in scale 1:144 with fine structured and detailed hull and also exactly 60 mm long (Bingo ! ), this perhaps may be the one to be used for taking a mold. But there remains the challenge of using a self made model,,, The problem I have, is the missing experience with making tiny silicone molds for the resin cast. Probably have to learn by doing... Nils the figurines are scale 1:160 in an 1:144 boat the model comes without rudder and oars and is a beautiful little model of a heritage lifeboat 60 mm long to fit neatly in the spaces on the boats deck
  10. Thanks for looking in Carl, well, I trust I wo`nt have the patience to build 24 lifeboats in single production, and taking a mold from a hand made prototypes for the 3 types, as well as making resin casts from those is also quite some work.... Nils
  11. Hi Patrick, sorry, my mistake, you`re right, it should read 24 boats, whereby 6 of them are fold-out boats, tripple stapled, port and starboard the last in the long row Nils
  12. Update... before carrying on with the boat deck supports, here an an intermediate rough crosscheck about davits in relation and position of outer boat deck edge-rail. I made a dummy for the boats arrangement. The overstanding stanchions (hight) will be clipped off after they are soldered to the rail. The 24 boats will be clinker planked and 60 mm long. Will think about resin cast technique here. The boatsdeck will be 1 mm thick ply and planked deck, just like promenade deck... It looks OK so far ....., but still a long way to get there Nils
  13. Patrick, thanks for your lovely compliment and also your atmospheric impression. I am gathering some figurines (male / female) in periods clothing, now and then there is something to find at Ebay (scale 1:160) Nils
  14. Hi Rob, Thanks for your compliment... the portholes (I use "Aderendhülsen", as galvanic tin-coated copper sleeves), I purchase these super priceworthy from the following webshop https://www.reichelt.de/index.html?&ACTION=446&LA=0 (type the term Aderendhuelsen into the spacefield for the search) you can get them in different sizes. The "glassing" is made from bits of grass cutter transparent Nylon line for Lawn mowing.... Nils
  15. Boyd, I thank you very much for your nice compliment, and thanks so much to all expressing their "likes".... all much appreciated Update Startung with the stanchions for supporting the boatsdeck, starting in the area I meant in my post # 1258 with the dummy trial... Nils
  16. Hi Mick. lovely work on the hull`s framing... Nils
