Everything posted by Mirabell61
	Hi Jeff. the length is 4,524 ft or 1380 mm..., together with an appropriate glass casing that will be quite some space on the shelf or sideboard afterwards Nils
- 2,625 replies
- kaiser wilhelm der grosse
 - passenger steamer
	thank you very much Piet, have now painted the long railing and mounted the aft cabin (removeable per screws)..... Nils
- 2,625 replies
 - passenger steamer
	Hello Hans, I liked your introduction to yourself and to this build. You had a nice start and all is well under way. The scale 1:50 will give quite a large ship, in my mind I can see a sideboard with a model in wall-filling formate. wish you much fun with this wonderful scratch build..... will the model be under full rigged sail ? Nils
	Wellcome to the build Jeff, thanks for looking in and for your kind compliment, I`m very pleased you like it. From the recent interest to this build by fellow modelers I presume there may been some encouraging ideas since keellaying. On the other hand I so much appreciate incoming comments and suggestions from others.... I work with hand scetches, trial pieces and technical solutions because all is scratch built and the coming build sequences often have to be altered and thought through more than once..... Cheers Nils
- 2,625 replies
 - passenger steamer
	thanks Bill, normaly I would solder the T- joints, but in this scale no soldering, although that would look very good with the flattend end. Due to the manyfold bend in the one piece rail parts, following the wall contours in this small scale I decided to glue the holding parts to the walls (stick through and glue from behind) and then lay the pre-bended rail into the loops from above and then close them as good as possible. Your fine idea has been saved for any next build to come.... Nils
- 2,625 replies
 - passenger steamer
	congrats Danny, this is a beautiful performed model section, love to the details in every part of it, a delight to look at... Nils
- 268 replies
	Bill, I tried your excellent idea straight away,,, it looks much better than with full diam. wire, unfortunately I do`nt have macro focus but I think it shows on the encl. pic... Thanks again The next improvement will be to choose thinner wire for those loop-ends, plus flattening... Nils stanchion wrap loop flattend......
- 2,625 replies
 - passenger steamer
	Thank you very much David, Nils
- 2,625 replies
 - passenger steamer
	Hi Bill, understand your comment, you`re right, never thought about flattening the wrapping portions, a great idea, thanks for that input there !, I`ll give it a trial (make a testpiece). Nils
- 2,625 replies
 - passenger steamer
	Thanks for looking in again B.E: and for your nice compliment,, Nils Hi Don, thanks for your nice compliment... Nils
- 2,625 replies
 - passenger steamer
	Hi Bob, I aimed to do the wall 19 mm high, but from some sanding to suit the curvature if fell down to 18 - 18,5 mm For the next deckhousings I`ll start with 20 mm, so that I come out min with 19 mm. I trust that less hight will not be sufficient when the next deck (boatdeck) goes on. Second criteria is the available hight for (chemical etched scale 1:144) the stairs / ladders with 27 length mm with stair at angle..... Nils
- 2,625 replies
 - passenger steamer
	Hi Ken, a beautiful ship, and so well built, love that model Nils
- 481 replies
- rattlesnake
 - model shipways
	many thanks Gerhard and Patrick, I`m quite pleased with the result so far., when doing the main deck housings I expect the learning curve to set in with more routine in this..... Nils
- 2,625 replies
 - passenger steamer
	Update.... this is how the deckhousings (promenade deck cabin walls shall basicly look like...... Nils the handrails are 0,5 mm wire in the foreground my fingers ( for scale comparism). The figurine is 1:160 railway scale N, it should be 1: 144
- 2,625 replies
 - passenger steamer
	Thank you very much Gerhard, Nils
- 2,625 replies
 - passenger steamer
	thank you very much Patrick and Piet, and all the "likes" for looking in.... many thanks for your appreciations Nils
- 2,625 replies
 - passenger steamer
	Update only a small update today...... priming, painting doors and cabin walls, making stanchions for handrails.... This relatively small aft cabin is a test for making the extensive promenade deck cabins in the same way Nils the holes for tht handrails are brought in already raw doors with window frames and knob handles, need 5, one is spare as sample for later on... the pins, surplus material from the knobs will be clipped off flush with the rear doorside first paint coat, needs some touch up stanchion holders for the handrails, the loops will be closed when the rail is in position test sample piece for handrail making
- 2,625 replies
 - passenger steamer
	Many thanks Albert, today I tried a sample of structuring the aft cabin walls, double story windows only dry fitted...., doors and handrails not made yet... The riveting is slightly overscaled, but I wanted it to be this way and visible also for the viewer`s eye in 1 m distance Nils
- 2,625 replies
 - passenger steamer
	Hi Greg, thank you very much for your nice compliment, much appreciated... Nils
- 2,625 replies
 - passenger steamer
	Hi Steve, yep, that`s right, intension is to make it look like the scetch in my post # 1202, and painted white, that shall match the main deckhousings of this deck later on. Nils
- 2,625 replies
 - passenger steamer
				Schreiber 1/200 scale Titanic railings and ventilators
Mirabell61 replied to Edubarca's topic in Card and Paper Models
Hi Edubarca, here`s a German source`s web shop from Hamburg (excellent quality), it might help....for 1:200 railings http://www.shop.modelltechnik-hamburg.de/epages/ModelltechnikHamburg.sf/de_DE/?ObjectPath=/Shops/ModelltechnikHamburg/Categories/Modellschiffbauteile/Reling__Gelaender/Reling_1200 Nils -
	thank you very much Bob, the rough fitting of the aft deckhousing is done, I`ll leave it removeable (two screws holding down), until it is ready for attaching of details, deck, docking bridge and railings for final mounting.... Nils the 5,5 mm thick piece of ply inforcement will give secure hold for the vent-shaft borings
- 2,625 replies
 - passenger steamer
