Egilman
Everything posted by Egilman
  1. National ensigns at sea fly from the mainmast.... while in port they fly from the sternpost.... The mast that sticks up from the forward superstructure is the foremast and the one from the stern structure is the mainmast.... (doesn't matter the actual size or height of the mast itself) Rules of the sea hundreds of years old.... The names of the masts come from ship building custom, the foremast is always the first mast, the mainmast is usually the second mast on a warship with two or three masts...... The rigging is fairly simple, a flag halyard rises from a stanchion or anchor spot, up to the flag yard or jib boom thru a fairlead/pully and down to the stanchion again...
  2. Lesson learned brother, in the future, Canopy glue, (white PVA) makes a good substitute for CA, especially for panels with large surface area.... Like CA, it doesn't attack the plastic....
  3. Your modeling a mid to late war FM-1, there may be chipping but you wouldn't see most of it, maintenance on these birds was almost constant since they had complete facilities readily available, capable of almost completely rebuilding one of these... Like the ships they served on, they were constantly being painted and cleaned up.... Army birds serving in forward areas didn't have the maintenance facilities in the forward areas that the navy shipboard aircraft had.... If your going to put it on a carrier deck base, the aircraft should be mostly clean..... minor very small chipping, almost no oil stains, and very little exhaust staining..... You want to see the difference in what I mean, research marine squadrons that served on carriers compared to those that served ashore..... Navy maintenance facilities and practices were legendary..... One more note, Pappy Boyington once received some replacement corsairs from the navy, hand me downs from a carrier squadron, he thought someone had screwed up and sent him brand new corsairs, but each aircraft had over 1,000 hours and 200 arrested landings on it.... Navy aircraft were very well maintained aboard ship....
  4. Actually, this is what it corrected to, I used a heat gun very judiciously with weights to relieve some of the stress..... It's about half of what it was.... If I go much farther I'm afraid of cracking the upper hull in the middle.... Right now it pulls down good and leaves a nice smooth, mostly even seam along the waterline.... once I paint the boot topping and put it in the seaway it will hide any residuals... There isn't enough room underneath to add any structure unless it's metal, I think I'll be better off welding it together and letting the plastic take the shape it wants to as long as no twist develops... The seaway it's going to be sitting in has an 8-10' swell that should cover any residuals..... Thanks for the suggestions.....
  5. Another small update my friends... I've found that my upper hull has an issue.... it's bowed... It shows up with the main deck laying on the upper hull.... That gap between the main deck at the foc'sl break and the hull.... So I guess I'll have to mount the upper to the lower hull, this will pull out most of the bow... (and disguise what remains) Probably the best way forward in the long run for adding the furniture and superstructures.... It also means I'm probably committed to doing a seascape at this point, a rolling seaway would be the best display option..... If you can't fix it, hide it..... (and reminds us that even as good a kit this is none of them are perfect, they all have their issues) EG
  6. I sincerely hope this was an attempt at humor.... Remember those few people I mention that are capable of matching his abilities? Your one of them....
  7. WE aim to please Brother, glad it helped..... It's what we'er here for....
  8. Yep, the old C-4 single band tranny...... Rebuilt a lot of them along with 283's with Powerslides....... Some tough little motors those were...
  9. I know where there is one of those sitting on a shelf right now.... Not for sale of course..... Owner has plans for it.... (but that's what he's been saying now for 30 years)
  10. As far as the grade and sizing of blocks, remember, an old country church wouldn't have the level of expertise in stone masonry that the big cities would have, a simple stone cutter in the city would be a project manager or master builder in the country..... When the church would order a monastery for a hamlet out in the boonies, they would send a stone cutter on a mission to get it built, it's how a stone cutter got promoted to stone setter/builder in the guild..... The stones may look rough, but that is the way it was and lends an authenticity to the construction.... your solution to the different sized stones resembles many such fixes I've seen when I was studying medieval arch... The work was difficult and hard and they wouldn't tear down a half built stone wall to fix that kind of error..... They would adapt to the error and continue the build.... I think your doing fine, good work.... (understanding that there is a learning process going on as well) EG
  11. It is absolutely refreshing to see one as adept as you in properly weathering aircraft.... there are a number of them in this forum, and I for one (of many I'm sure) that would just love to see an in-progress build... That being said, anything you proffer would be appreciated as we not only appreciate the finished object, we appreciate the work and skills it take to do it.... Some of us actually try to replicate such given our feeble skills using examples like yours as inspiration.... Please share more..... EG
  12. I used to have one like that as well, until covid hit and she disappeared, USPS hasn't come to the door since..... (they don't even get out of the truck if they can avoid it) Me too, and FedEx at least still comes to the door, none of them ring anymore and I'm beginning to wonder about FedEx..... What I really hate, is Amazon using the USPS on Sundays.... The Mail people really hate it as well, according to the ones I've talked with, they don't get paid extra for working sundays delivering packages..... Anyway, deliver us some 427 goodness brother, and we can at least know we have been delivered something worth the wait....
  13. Agreed, it's just getting too risky to leave it to the post office's good graces..... they are just simply getting way to lax and the costs of the goods is getting way to high for that type of laxity....
  14. Ok another short update.... Decaling the decks..... Not for the faint hearted, and I don't know if your even going to be able to see them on the finished model.... Those greyish strips on the deck surface are supposed to represent the anti-skid stripping the crew put down.... (they were pretty much the "Peel n Stick" variety so the yard personnel had more important things to do) In real life they are black but they just disappear in the deck blue surface.... once down, all you can see is the decal film..... I guess I'll have to see what they do when flatcoated.... They are taking more time than I thought they would, it's not like putting decals on a car or airplane, The decals are nice though, no trimming needed, they have no film edge.... Might not see them at all, anyways, I KNOW they are there... {chuckle} EG
  15. Your lucky, the only one that comes to my door now is FedEx, the rest just drop them over the fence onto the grass.... (in a plastic bag if it's raining) At this point I insist on tracking with my shippers and I dedicate an open tab in the browser while each are in transit.. I also signed up for delivery notification where they e-mail me what's coming in the mail, so far it has only gone haywire just once, and that was for my GMM etch... That's when I went to the PO and told the PM it was a 50.00 envelope, and a claim would be forthcoming if they lost it... She assured me it would be in the box the next day.... it was... Is it a wonder that Amazon decided to create it's own delivery service?
  16. Interesting on the PE, I usually paint mine first, but there are so many ways to do it go with what you know.... Beautiful PE work btw..... The Flap looks good..... I figured it was going to be a sculpting job given it's shape....
  17. I use all three methods, the first two don't have everything available although they do have good general coverage of most stuff. another option is to become a member of many modeling sites and ask the membership if they have any suggestions.... I've found a number of out of production gems that way.... Researching aftermarket products is almost like doing historical research simply cause there is now so much out there....
  18. I've had this happen to me several times over the last year, so far I've been lucky, but that was after a discussion face to face with the Post master here in a customer full lobby about them doing this with my packages... The typical excuse is the substitute carrier but I haven't had my regular carrier for some time now.... and then it is always covids fault, heck everything is covids fault..... I guess the next time I go down there and have a temper tantrum over crappy mail service do you think I would get away blaming it on Covid? {chuckle} I didn't think so.... The mail service has become a real joke over the last year or so.... UPS and FED-EX aren't much better....
  19. Not so much looking for trouble, but ready for it if it comes..... And my opinion is you've nailed it...... Well done my friend....
  20. That's not really a bow wave my friend, A bow wave would swamp a small boat encountering one, that's a bow ripple, exactly as it should be.... Something you will never see unless the light hits it just the right way... You post a bow on pic that is absolutely perfect.... You don't need any white water to show action..... If you create a sea state with 5'-20' swells THEN you will have white water, particularly if your running under some power, if you create a ship traveling at 27-30 kts you will have white water and a rooster tail with a huge wake... (and yes battleships could and did put up rooster tails) You have a beautiful depiction of a ship on cruise, easy water and smooth sailing...... But the water is live, the ship is live, together they depict a classic understated power..... Exactly what a classic british battleship should state... You have managed to capture something that few modelers can.... and many try.... I wouldn't change a thing.... It's stunningly beautiful....
  21. Very Very nice... but just one note, stain doesn't stick to metal, so they were painted 20B Deck Blue... But once the stain on the wood fades a bit, it's next to impossible to tell them apart....
