Everything posted by Papa
Good idea using Model railroad window sets. I used some in my City of Pekin canal barge.
- 238 replies
- Robert E Lee
- steamboat
- (and 3 more)
Thanks for posting the whale boat photos. They are very helpful.
- 294 replies
- charles w morgan
- model shipways
1 step forward 5 steps backwards😫. this is what happens when one fails to make careful measurements. Had to rip out the guts and start over. The stern is more or less correct. Some more detail needs to be added. Would the whale boats have been hung on the davits with the tiller and rudder in place?
- 294 replies
- charles w morgan
- model shipways
I did get some Aleen’s tacky glue. I like it.
- 25 replies
- United States
- JSC
The hull skins at the stern have wedges cut out (kind of like darts in sewing) to shape the stern to the frames. On my first attempt I tried to glue the skins on and close the wedges with the tabs at the same time. Bad idea! And the stern was grossly misshaped. This time I glued the tabs and shaped the stern first. The stern is much better now, at least off the ship. It was still a ridiculously complicated job to get the skin attached smoothly. The port side is in, but not as smooth as i’d like. Not looking forward to the starboard side. 8 more hands would make it easier. Maybe with a few dozen more paper ships i might get the hang of it.
- 25 replies
- United States
- JSC
- 294 replies
- charles w morgan
- model shipways
It isn’t obvious from the picture, but I misinterpreted how this aft cabin was laid out; the little doors look weird. I discovered the error when the next deck level went on with the ladders. I got it correct on this second attempt to build the United States
- 25 replies
- United States
- JSC
I would hazard a guess that you are the only person on this site with a Herztsprung-Russell poster on the wall! I figured you had to be an astronomer, but i see from the profile you are an historian and amateur astronomer. Good luck on the Swampscott dory build. I grew up in Saugus, MA, right next door to Swampscott! Ron Gove, (Papa to my grand daughter)
- 42 replies
- BlueJacket Shipcrafters
- Swampscott Dory
I never heard of “craft paste”. Is it like spackling paste?
- 127 replies
- Bowdoin
- Arctic Exploration
(and 3 more)
If i may add another hint learned through trial and error. Don’t try to glue too many tabs at once. They just will not stay in place and everything gets out of whack. For example, on the frames i would add a bit of glue and firmly attach one of the 3 tabs to the “false keel”. Once that set, i’d glue the second. Etc. Likewise, in gluing the long waterline piece i glued one frame at at time, and one side at a time. It was slow work but everything stayed aligned. After about 3 frames i decided to add the reinforcement stripwood. One tab, one strip, one side. Then the next. It took a while😀 but i am pleased with the result.
- 25 replies
- United States
- JSC
- 25 replies
- United States
- JSC
Do you find this little hobby desk useful? It looks cramped to me.
- 5 replies
- Portable
- Particleboard
- 25 replies
- United States
- JSC
I’ve looked at that. It seems a bit cramped. I’ll have to check some reviews.
- 294 replies
- charles w morgan
- model shipways
Today i received my new copy of the United States liner card model from Poland. 1. Photo shows how to properly join the beam sections, using tabs #6. I missed this the first time. 2. Note the triangular section in the middle if the frame, 13. In my first build, I didn’t realize there were 3 tabs in there needed to attach the frame to the center beam until i had cut the center out of about half the frames. I had to jury rig new tabs. 😳. I learned my lesson and am doing it correctly this time. 3. i also learned that i need to write the part number on each part when cut out. Doesn’t take my 78 year old brain long to forget what part is which.
- 25 replies
- United States
- JSC
I am genuinely curious 🧐
This comment makes we wonder how many of our fellow ship modelers are in the sciences or engineering. I have a PhD degree in mathematics.
Almost 2 months and i am still working on the whale boats. It is like have 7 individual sold hull kits
- 294 replies
- charles w morgan
- model shipways
You should start your own business as a model ship sailmaker
- 127 replies
- Bowdoin
(and 3 more)
