Everything posted by HardeeHarHar
Welcome aboard MattD, I'll be counting on you for your support and honest feedback. Andrew, I'd be much less productive without your encouragement and assistance in my building. You set the bar high in your builds and your forum participation. I have no fear, I know where you live, and I have access to the GuildFather's build log! What could possibly go wrong!!!! In all honesty, Chris sure does know how to make a great kit, and I am super happy to be following in the footsteps of such awesome previous builders. With everyones support, I can most likely finish this thing in less than 10 years!!! 😃.
And so it begins. Having arrived back to an empty dry dock in Durham, NC, it was time to fill the vacuum and put the shop to work. I will do some research and try to add some helpful or informative content to this topic as time permits. I will say that the kit arrived in a timely fashion, in perfect shape, well packaged and prepared for the builder. It is a big box, and the parts all look to be of high quality. The manual is spectacular in detail, and the pieces fit together with amazing precision. Here is a sneak peak of my progress.
Making progress on the masts, yards, etc. I have learned a lot, and have hacked a few items (e.g., the main yard) to the point where a redo might be appropriate. It might not be so obvious when they are painted black. It is slow going, lots of other tasks to address, etc. However, all the channels and deadeyes/chainplates are pinned to the hull and ready to be nailed down, and the main mast top has gotten its finishing coats of wipe-on and is looking pretty good. Slow and steady as she goes.
That is a super nice clean job on a beautiful ship. Great work!
- 143 replies
Nicccccceeeee work there Roberto!
- 56 replies
- Sea of Galilee Boat
- SE Miller
Ahoy mate, welcome on board.
I hear you loud and clear Glenn, and I greatly appreciate your input on this matter. The space, or seat, below the deck is what was created per the instructions in the kit, and I don't think that is much at all (it may be slanted to some degree, but it has no diameter in dimensions as I recall). However, the holes in the deck and the deck reinforcements are much smaller than the diameter of the main and mizzen for some reason. This means I will need to carefully enlarge these holes with a dremel or something, which is a terrifying proposition as I can see shards of decking flying off. I was hoping someone who had made the Granado would remember this issue and offer some sage advice, as I was clearly considering reducing the diameter to fit the hole because it wouldn't be obvious or observable if done in a sufficiently sneaky fashion. Any additional thoughts and advice and encouragement will be greatly appreciated.
It seems like I have been working too much, and have been unable to make a lot of progress on my Granado. However, I have made a little progress, and I like to post any progress I make to keep up even a teeny bit of the momentum. While it is not part of the instructions, I decided to plank the main mast top to give it a little contrast. It needs a coat or three of wipe-on, but I think it looks pretty good with the maple planks similar to the deck, and it slips right on the main mast nice and snug like it should. I am curious if people tend to make the hole for the masts in the deck as big as the mast is in diameter, or is there some advantage of reducing the diameter at the point where it goes into and below deck (like what is done on the bowsprit)? Opinions and thoughts please?!?
I thought I would add a note for everyone who might be considering the purchase of a mini-lathe like the one made by Proxxon (DB-250). It is a great little lathe, and makes working on the masts and yards a real pleasure. I typically use sand paper, but occasionally I break out a cutting tool as well. My digital caliper is used frequently, and I feel like I am learning new skills while I am having fun at the same time. Having said all of these positive comments, I should note that I have had a few "surprises" occur due to operator error. These instances of "operator error" have not resulted in any egregious injury or loss of tissue or biological fluids, but they have served to remind me to think carefully before turning it on or doing something stupid, and serves to reinforce my decision that I don't need a table or scroll saw at this time =). In the photo below, on the left is the lower section of the main mast, which starts at 8 mm round for a while, then tapers from 8 to 7 mm round, then ends with a 7 mm square end. On the right is the bow sprit, which starts at 8 mm round for a while, then tapers to 5 mm round, then will have a 5 mm square and a 3 mm square end. I have been working hard, which has made my available time for shipbuilding rather limited, but I am making some progress and enjoying it, even with the occasional "surprise".
As usual, I need help: I see the treenails (group of 4?) I believe, but not the bolts you refer to 😞. Ah, I get it now, and yes those treenails are barely visible. Nice work indeed!
- 302 replies
- Diana
- Caldercraft
Glenn! I agree about the IBEX, it’s real smooooth! With regard to the sweep port lids, I would stick them on as you have, but I like the look of them too much to hide them. I’m going to keep mulling it over and make a decision soon. Your Granado is an awesome model, and I am hoping to emulate your work and the work of so many other talented builds. Here is a picture of the bowsprit in progress, the rain chased me indoors…
Thanks Amigo, I was pleased when I was able to get it out of the shipping crate and clean it up. It had some 18th century dust and dirt in it! Makes it “Authentic”. I’ve been doing a lot of writing lately, which is very time consuming and frustrating occasionally. I’ll start my Sphinx log soon, and will be delighted to have you there for help and encouragement. I’ll do my best to make it worth your while! Having you and the others on board is one of the best things about the forum, everyone is awesome! the Proxxon has been here, I just hadn’t had the time to spin her up….I made a ton of sawdust yesterday, but I am going slow while I learn what I am doing. I did use the through hole for the bowsprit, and it is working like a charm as I taper it down from 8 to 5 mm. I’ve starting “stashing” all sorts of stuff in my cabinet dood! 😉 KEV! Thanks for the continued kind words and support and interest. My wife found the drafting table and the desk for my computer, and I found the cabinet at Industrial Artifacts. They have a lot of nice stuff and the prices are negotiable!!! That cabinet is in really good shape considering it’s age, and can hold a LOT of stash and stuff. The finger plane is an IBEX flat soled plane that makes working on masts and yards a pleasure (making octagonal sections in particular). My source for information that is shipworthy, @hollowneck, (aka GuildDiddy, GuildVater, ObeeRonKanobee, MasterRonCommander, etc) turned me on to IBEX and provides me with all my knowledge base. He is full of it! 😜. And you are quite right about the box set, it would be quite dangerous if they weren’t “contained”. I am listening to the series on Audible, and am in the middle of book 9 I think, Treason’s Harbor. I’m addicted! Big shout out to everyone for stopping by and being so kind. This community is incredible.
That sounds like my kind of Sammie!!! I love spinach, and kale too. I REALLY love spicy foods, and a good jalapeño sausage sandwich sounds like something I could really enjoy. With a tankard of a frothy golden nectar I’d be in heaven!! I just finished eating some lemon blueberry buttermilk pancakes so I can hardly move…. Have to take the doggies for a walk, run to the grocery store, then hopefully I will have some time to work on my masts and yards on the lathe. It is working well, so far so good. I’ll answer your questions on my build log (re: finger plane), since some others might want to know. How you been doing my friend?!? You staying happy and healthy? All is well here in NC. Nice weather, interrupted by the occasional downpour. No complaints though.
- 68 replies
- Morel
- Master Korabel
Work has been interrupting my woodwork! However, my IBEX finger plane has begun its work on the main mast and bowsprit. My new lathe comes out today and will be set up in the garage with a shop-vac to try and control the sawdust. I’ve also begun the Sphinx, and will be starting a build log ASAP. And….I scored an antique cabinet for storage of tools and equipment in my “office”.
Long term Durham resident with increasing time spent at our place on Roanoke Island.
Welcome aboard Papa, Looking forward to watching your build. We might be neighbors, as I am in NC as well. Cheers! Brian
Welcome on board, and good luck with the RC job. It looks like FUN and a CHALLENGE, which will be interesting for all of us. Please make a build log and keep us all up to date on your voyage!
Andrew, glad that you found the forum and welcome aboard. Hopefully you will find the crew and contents increasingly helpful and enjoyable over time. Thanks for sharing the history of your interest in model ships, and I am looking forward to seeing pictures of your Albatross. Please do consider starting a build log to document your work!
Gday Alex, glad to have another OZie on board! Sydney is a beautiful place.
A very wise man (Ron @hollowneck) once taught me that if you throw all the receipts away, this hobby is not expensive at all!
- 206 replies
- Vanguard Models
- Brixham trawler
