HardeeHarHar
Everything posted by HardeeHarHar
  1. I have to wear my magnifying headset to make sure the rivets get set correctly. The heads on the small ones are 0.7mm. I use bees wax lip balm on the end of a probe to grab them and maneuver them to the rivet hole. The little rivets love to fall off in transit, and then they bounce or roll....somewhere, I know not where. The big ones are 1.2 mm "whoppers" as compared to the microscopic 0.7 mm ones. I've set about 50 big ones, and around 40 small ones, and there are still more to go. I just finished assembling and mounting the rudder. The small little metal pieces used as hinges for the rudder and the "flaming pipes" are horrid to work with. I'm not sure I am going to pull the flaming pipes off that well, but I am going to try my best. Then I have to make corkscrews out of wire to serve as the ballast release mechanisms on the front and back. Maybe I should just go buy some corkscrews?!?!?
  2. So many rivets!!!! So little time.... and my eyes hurt. Those little rivets are painful.
  3. That all looks fantastic! I really like the look of the patched and weathered sail!!! Nice work, absolutely great!!!!!!
  4. I recently bought a bottle of the Loctite® Super Glue Extra Time Control. I'd never seen it before. I ordered it on-line from Amazon to check it out. It is almost too slow, but so far, I like it for gluing things that need a little time to get in the intended configuration. As a bonus, it has a "reduced risk of finger bonding" 😃
  5. I originally considered making it a decanter for port. It doesn't have enough capacity for beer 😃
  6. My wife was on the side of bling too!!! It can take bathtub depths, which is about the depth of Roanoke Sound!!! Watch out bathers!!!
  7. Holy ship in a bottle, that looks great! Lucky niece!!!!
  8. Brian the Riveter: 1) Enlarge hole 2) Cut heads of rivers 3). Glue em 4). Blacken them or not?
  9. I'd be making a ship in a Mickey's Wide Mouth Bottle I believe! 😃
  10. Kev, I’m glad you are here to help me out and clarify my gibberish! Doh! Here (see pic) are the teeny posts with the holes I drilled in them using a dremel…all the posts were then painted black. 😬 I broke another hand drill bit in the rail installing them today. Argh!!!! I also hand drilled holes in all the channels (2 per channel, 8 channels) and then glued pins in the holes to be used to secure them firmly to the hull. I have also put all the deadeyes in their chain plates. These metal parts were also painted black. You then stretch them open, put the deadeye in, and squeeze‘em shut on it (see pic 2, with a 3mm deadeye stained dark).
  11. Welcome on board Paul!
  12. Haha hahaha! You guys are such good colleagues!!! Thanks very much for making me smile and letting me know you’ve been there done that!! FYI- I take my contact lenses out to see better, but there isn’t much I can do about the shaking hands (I try to use liquid refreshments, with little success). In my latest struggles, I definitely had a moment of relief when I got the broken drill bits cleared, and then I could act like Joe Cool when the panic subsided. Today, was another challenge for shaking hands and drill bits. Drilling tiny holes through tiny brass parts with a Dremel!!! I’ll post pictures later (they are wet with black paint at the moment). I’m stunned I was able to go 4 in a row with no “oh shooot” moments. I also prepped and stained the channels and painted the chainplates, drilled out all the required deadeye holes a wee bit bigger, and stained them too. There is a lot still remaining to do before I start making the masts, yards, gaffs, etc!!!
  13. This is a hard hobby that requires a lot of patience and self control. These are characteristics I am lacking. I recently moved on to the cheeks and headrails of the build, and it was not easy. Small parts, CA glue, and shaky old man hands are a bad mix. I went so far as to craft the headrail by hand as the kit supplied part wasn't going to work very well with the configuration and space my build had provided. When all was said and done, the part I made wasn't that different from the part supplied in the kit (which was not the way I had intended, sigh). Looking back, I believe @Timmo had the right approach, and next build (if I get that far) I am going to work a little more on my techniques using a blade, lamination, etc. Another thing I should note when it comes to "why does this have to be so hard"...is one should be careful when one is drilling pilot holes using itsy bitsy drill bits. In drilling pilot hawserholes for the Hawsers, my itsy bitsy drill bit broke while imbedded in the wood. This meant using a slightly less itsy bitsy drill bit to try to drill through/around/over it. Of course, it broke in the side of the ship as well. Being stubborn, i started shoving my new broaches and bigger drill bits in the "hole-that was filled with metal" and a miracle occurred, and a hole was made in the right spot, and of the right size. I got the job done, more or less. It needs a lot of touch up/clean up, and maybe some wipe on poly would help?!? The quality of these pictures taken with my iPhone leave a lot to be desired too =(
  14. Hey Andrew, pray tell us how you went about doing your rat lines. Having never done one, and about to do many, I could use all the help I can get!!!
  15. That seems like it was an excellent solution to getting the angle correct. Looks like I need more tools too. 😃
  16. Thanks Ron, I'm doing my best to not screw up a good kit (too much) 😃 Thanks Kev, If the truth be told, the tiller in the picture is #2. Numero uno suffered an undocumented structural failure during manufacture. I manufactured the first one out of walnut, starting with some square stock. I used a sanding wheel on my dremel to remove material in a hurry, then switched to files and sand paper, and got it down to the 1 mm taper as specified, when "IT BROKE". I glued it back together but it was visually apparent. My depression deepened. After my despair was alleviated with repeated beverage intake, I then switched to basswood, which is probably not a great substitute. I would have gone for using boxwood, but I didn't have thick enough stock and I didn't want to make a laminate to use. So I had basswood, and I thought I would see if that would work. Man, basswood is soft! So removing the majority of the material was relatively easy, and it shaped nicely too. I didn't push the diameter reduction as much with the second attempt. When I had the shape of the tiller finished, I took a piece of 3mm walnut stock and fashioned the round cap for the tiller. I drilled a wee-hole in the round cap, then increased it's diameter with increasing drill bit diameter, until I could delicately SHOVE the tiller into the cap. I then painted the tiller matte black and the cap red, and glued it into the rudder. I slid the rudder housing down the tiller and glued it into place, and called it a done deal. By the way, I am using this Loctite Extra Time Control CA lately, and I don't hate it. I have used it to clue the hinges to the quarterdeck panels doors, and to glue the hinges to the gun port lids, and it allows some fiddling before it sets, which is required often. I miss seeing updates from you Kev, so if you need a new throw-out bearing, I will find you one and send it to you! Oh, and if I put figurines on board my Granado, I think we would find that my tiller cap is about the size of a human head....so my Granado won't have any figurines on board/nobody's hands are going to slide off that tiller 😃
  17. Well ahoy and happy New Year Andrew, it sure is good to see your hard work paying off on the Nisha again. Your life ring is much appreciated by the crew I bet. In all fairness though, I think you need a little one for the dog too ;-). I am excited to see how this all comes together, as it is definitely going to tell a story (a fish tale) with all the modeling extra's you have added to the build.
  18. Slowly, but progress is being made. Catheads in place and home-made tiller installed. Will add the rest of the bow chaser gun port lids later, just one installed to ensure it doesn’t get fouled….
  19. @Mozartman YAY, puhlease do start a build log for others to reference!!! It will be both helpful and inspirational for those who follow along (me :-). @ir3 YAY, I’m happy you are still pursuing this model, and glad to hear CafModel is supportive of your efforts!!!
  20. Crazy good Ron. Just pretty much perfect in every aspect, including the photos.
  21. Hey Tom, It would be great to have a build log for the split hull version. Any way you could make that happen (before I start the kit ;-)? It would be a huge help for those of us who want to build the kit but don't have the experience or knowledge to do it on our own. Best regards, and season's greetings to you and yours! BT
