Bill97
Everything posted by Bill97
  1. Thanks Henry. It was your suggestion that had not thought of.
  2. Henry I did the Bobstay following Anderson’s guide on page 91, Fig 78, French Bobstay about 1700. As we have said it may or may be accurate but it is right on the edge. I brought the fall of the stay down to an eyebolt and blocks I attached to stem. This does provide a bit more tension on the spritsail stay but you still need to reach a happy medium on the tension a slight bend in the forestay.
  3. Henry the bobstay idea is interesting. I am reading the pages in Anderson’s book about the bobstay. There is a possibility that the Soleli Royal incorporated one in its rigging. If not authentic it is very close to a time period when it would have been. If adding it will help to counter the upward pull on the forestay I am going to include one. Before I installed my bowsprit I reinforced it with a wood dial rod so it does not currently have much flex. I guess a simple test will be to apply downward pressure on the bowsprit which should then tighten the forestay. From there I will see if it tightens the spritsail stay. If it does I will add a bobstay. If not I will wait to see what you do 😊. Bill
  4. So Henry you say just leave it alone as is and move on? I liked your idea of filing out the edge of the block. Will probably use that idea anywhere I don’t have tension on the block to eliminate the parabola shape. Will do some research on the bobstay to see if that might help as well.
  5. Finished the port side lower foremast ratlines and set up my process to do the starboard side. Also continued fiddling with the spritsail topmast backstay. Henry I used your idea of slightly rounding the sharp edge of the hole where it enters groove on the block to eliminate some of the parabola shape of the lines. I have also rerigged the backstay with 3 different weight thread. I am still getting a slight bit of parabola shape if I don’t snug the backstay so much that they forestay starts to bend. Have one more weight and type of black line to try tomorrow. Is a slight somewhat noticeable bend in the forestay as you see in the photo acceptable, or do I keep experimenting? Black sewing thread does OK but it is way to thin.
  6. Great idea Henry. Weight (diameter) of the thread looks OK? I used a .4mm and it is currently coated with bees wax which I will rub in.
  7. Ok I think I got it. Blocks on forestay positions above the blocks on the bowsprit. Blocks evenly spaced. It is difficult to get the backstay taught enough to remove any slack in the lower zig zag portion without bowing the forestay. I think I got it pretty close. Going to wait until I get a thumbs or recommendations from you guys before I add a touch of glue to the tied knots.
  8. Thanks Marc. If I zoom in I can get a good idea from the photo.
  9. Thanks Henry. 👍 It would be blocks e4 and e2 on the bowsprit you are referring? So e42 would be above e2 and e44 would be above e4?
  10. Thanks Henry. Hopefully with your’s and Ian’s help I can get this. As you mentioned the instructions show the upper leg of the spritsail topmast backstay just below blocks e42 and e43. Does it matter where on the forestay that upper leg is tied to begin its route? And then of course I would tie e42 and e43 right above that on the forestay. I guess what I am trying to determine is if there is an optimum angle of the rope leading from the spritsail topmast to block e38? That would then determine where in space blocks e39-e41 would on a horizontal line through the spritsail topmast. Should this line be horizontal or angle down toward the forestay, or does it really matter? Hopefully following Ian’s recommendation I can get a good representation. Henry if you would not mind I would very much appreciate a little further clarification of the second part of your second paragraph. The sentence that starts: The blocks at the forestay should be .... . I got a feeling this is something I need to know an understand. Not sure if it pertains to the spritsail topmast backstay or the braces you refer to. I also have have not found a use for h2 and h3. Will wait to attach them until we have an answer. Oh oh and yes very creative naming of the mast tackles. I see they connect to a eyebolt using a hook on the tackle. What were these mast tackles used for? I assume cargo lifting like the tackle pendants? Always learning from you guys Bill
  11. Thanks Ian. As always you are the best my friend. Will look to those references. These are a few different versions I found on line.
  12. I am searching for a good picture of this rigging done on a model to see the right spacing and block positions of the ropes and blocks. It is difficult to tell how it is supposed to be by the instructions drawing. Looked for help in Anderson’s book but found no luck. Several different versions on-line. Not sure how it should be. Any help would be appreciated.
  13. Thanks my friends. Don’t know if any new builders looking in are curious of a methodology for tying the ratlines and, very importantly, keeping the shrouds from bowing off their natural line from deadeye to mast top. This is my method I have used for years that I find works well for me. I am sure other experienced builders have their tried and proven method. This is what works for me. First I determine my line spacing based on the ship scale. I have read that the ratlines were spaced anywhere from 14 to 16 inches apart, and some instances maybe more. I settled on going with a distance of close to 15”. When I convert that to the 1/100 scale the Soleli Royal is, I get a measurement close to 5mm. Selecting a distance that matches a standard mark on my ruler instead of a fraction makes laying out my card stock a bit easier. 5mm points is simply easier than trying to determine a 4.3mm measurement consecutively as an example. So in this case I laid out my card stock with as many lines spaced 5mm apart to fill the card. I then place the card behind the shrouds and mark the top and bottom of the fore and aft most shroud. I then remove the stock and draw lines between the points. This now forms the natural line for the length of the first and last shroud. Returning the card back behind the shrouds I use clips to lock it in place with the drawn line directly behind the first and last shrouds. I then use push pins at every fifth line to lock the outer shrouds in place so when I start tying the ratlines the outer shrouds will not be pulled out of their natural lay. I then go ahead and tie and glue the ratlines at these positions. Once the glue drys I start filling the space between the already glued ratlines. This also serves to reduce the monotony of tying by providing little goals of finishing a section. When I am finished I remove the pins, make any small adjustments to keep the ratlines straight with the line behind it followed by a thorough application of diluted white glue to each tie. Then I remove the card stock. Later after the glue has dried I trim the excess off the ends of the tied ratlines. I hope this helps any builder that has decided to tie their own ratlines. I learned it from a builder on MSW and paying it forward.
  14. Not to much to report. Just finished the ratlines on the port side of the main lower shrouds. Now to move to the foremast ratlines and some of the select rigging pieces like the ones highlighted in yellow (whatever they are called).
  15. Three hundred fifteen half-hitch knots on one set of shrouds, but who’s counting? 😊
  16. Fore and mainstay completed in accordance with Anderson’s book. This rigging if the mainstay does seem to make better sense than Heller’s instruction. Also finished the ratlines on the starboard main lower shrouds.
  17. Should have included this photo as well showing the collar going up through the rail.
  18. Marc I am glad to hear that about your dad. Mainstay collar complete. Double cable where it went around the bowsprit. Then up through the center most opening in the bulkhead beakhead rail, then to the aft side of the foremast where I added a 3 sheave block that will fix to a similar block on the fall end of the mainstay.
  19. Thanks Marc. The last picture (3rd) is very helpful showing the mainstay collar. Going to work on that today. I know I am going to take both sides of the collar under the rail of the beakhead bulkhead. Trying to decide if I will take both through the center opening between the balusters or one to the port side and one to the starboard side of those two center balusters. The diameter of the foremast base causes the collar to bow out just slightly and touch against the inside of the two center balusters. If I go to the next opening port and starboard they touch the outside of the baluster. To my eye going through the inside just looks more refined maybe. I know in action this collar would not move and rub the balusters so I guess it would not really matter. On a much more important topic, how is your dad doing. Glad you are enjoying your vacation. Keep your son shooting hoops. Maybe someday he might be a Cardinal 😀
  20. KarenM I am building the Heller Soleli Royal. I am working on the fore and Mainstay. I like the way you extended the length of the mainstay collar to go around the bowsprit over the beakhead bulkhead (under the rail) and aft of the foremast. I see in your pictures you have a heart on the end of the mainstay. I cannot tell in the photos, do you also have a heart attached to collar? I am wondering if that is how you set the mainstay up to the collar? I am using large 3 sheave blocks instead of hearts.
  21. Gregory the only reason I say that, usually I want to wait as long as possible so I am more easily able to access the interior during rigging, is because the Soleli Royal instructions show a large number of blocks tied to the shrouds at particular ratline positions. So I am assuming before I can I can do the rigging that uses those blocks I will need to add the ratlines so I know where to tie the block.
  22. About 60 percent of the ratlines on the starboard side of the main lower shrouds tied. A little adjustments before applying a touch of glue at the knots. Now with Henry’s advice I can rig the mainstay correctly, and then back to tying ratlines.
  23. Wow Henry there is some good stuff here to unpack. I think I understand. Are you explaining like Anderson shows in this example?
