Everything posted by AnobiumPunctatum
A really long youney comes to an end. It was a great pleasure to follow your log over the last years.
- 257 replies
- pegasus
- Swan-class
I did the same with the Alert from Shipyard. The model is also wider than given in the historic plans. I would adopt the hatches and the deck furnitures but not the width of the model. I. think in the small scale it's only visible if you measure your model.
- 12 replies
- Le Coureur
- Shipyard
@Waldemar I couldn't give any input to such a discussion, but really interested to read such a thread and read about your opinions. I followed a lot of your drawing works and like it very much.
- 2,699 replies
- heller
- soleil royal
(and 9 more)
It's not only the problem which David mentioned. It's also a simple problem working with wood (and also other materials). If you cut and grind your wooden parts 100% exactly to the line, your model keel will be 0.4 to 0.5 mm longer than planned (depends if you have 5 or 6 parts). The glue needs also some space. My experience say that you have to think on 0.1mm for every joint. If you add some thin paper for the caulking you need at minimum 0.15 to 0.2mm for the joint. Especially at the keel this gives your model some extra length. With manually cutted parts you can't avoid this.
I will follow your log with great interest. I have visited the boat a few times in Schloss Gottorf in Schleswig. It‘s a really interesting vessel. In your scale you can build the model with all the fine details
