Everything posted by AnobiumPunctatum
Welcome back, Remco. I missed your updates in the last years.
- 1,215 replies
- sloop
- kingfisher
Congratulation for finishing this beautiful frigate.
- 399 replies
- winchelsea
- Syren Ship Model Company
I am not sure, but the first deck you need is the lower deck (orlop). More important is the gundeck which is midships fully visible. For the keel you can use the keel drawing. There are some detail drawings which should help to cut out the parts. Have a look to the different build logs in the forum. I think they are really helpful, to find your way in the project.
If you print the parts of the model check on your program that the scale of the printout is 100% and not fitted to sid or something similiar. You can check the scale of each print out with the ruler shown on every PDF. It is given the length of 10 feet in the scale 1/48. In metric scale it's exact 63.5mm. Don't worry about your thoughts. It's the beginning of a really long journey. For me the MSW project was also the start in scratch building. If you have not much experience I can recommend the cross section as a really good entry point. It hase the same scale as the full hull build but is much less complicated.
1/48 is a real nice scale. If you have the space at home for the finished model I would go with this scale.The original drawings in the RMG are in this scale. I am a bit surprised. As far as I know the PDF's of the drawings are in 1/48 prepared. You should also have access to the POF drawings. They are a really good add on for a POB build and in 1/48. If you need to scale a PDF you can simply change the scale by printing. The cross section was many years ago my first wooden try.
Really nice progress, Henry. It's allways a pleasure to follow your updates.
- 257 replies
- pegasus
- Swan-class
