AnobiumPunctatum
Posts posted by AnobiumPunctatum
  1. Quote
    Question: Is it wise to shape the cutwater at this point (and set it aside for a really long time)?
    By my first try's I glued the Knee of the Head directly to the stem. But in the meantime I think it is much better to do this after building the complete farming of the hull. What you should prepare now is a hole in the stem and the knee that makes it easier to adjust and center the parts later.
  2. It's not only the problem which David mentioned. It's also a simple problem working with wood (and also other materials). If you cut and grind your wooden parts 100% exactly to the line, your model keel will be 0.4 to 0.5 mm longer than planned (depends if you have 5 or 6 parts). The glue needs also some space. My experience say that you have to think on 0.1mm for every joint. If you add some thin paper for the caulking you need at minimum 0.15 to 0.2mm for the joint.
    Especially at the keel this gives your model some extra length.
    With manually cutted parts you can't avoid this.
  3. Hi Chuck,
    I love your designs and have different of your kit at home. One of your designs I am missing is Speedwell. It's good to know, that it is possible to find the kit later also on the market.
    It's good to know, that you plan to make further designs and have different projects you want to do.
