Posts posted by AnobiumPunctatum
They are looking much better than as your 3d model.
- Canute, thibaultron, mtaylor and 2 others
- 5
Reallohn nice collection of ships equipment
- mtaylor, FriedClams, Keith Black and 1 other
- 4
This week I got a "little" parcel with really nice milled boxwood from hobymill.eu. Vahur put also some extra sheets and wood samples to my order.
The timber has real nice color and was excellent packed. Also the contact and information of Vahur was great.
Hobbymill gets from me ⭐⭐⭐⭐⭐ of five possible. Highly recommended
- Niklas, Rustyj, Edwardkenway and 6 others
- 9
Thank's very much. Let's answer your questions:
2 hours ago, druxey said:Nice start! Will you be milling templates for every frame?
In the moment, this is my plan but I don't know if I will change this with more experience in frame building. The advantage of the method are the different levels, which make the build much easier.
1 hour ago, allanyed said:Are you gluing up the frames while in the jig, and if you are, any problems arising with the frame being glued into the jig and having problems getting it out?
By the testframe I did not have any problems, to get the frame out. I don't need much glue during the build. You can also use a colophane foil or a thin layer of clear varnish to avoid problems.
QuoteAre you using a CNC mill?
Yes, I got one last year. The idea is a first result of my learning curve. I have a lot of other ideas, but for these I have to learn 3D construction. All my drawings are in the moment in 2D and for Triton I will not change this.
The last two years I needed my workshop as homeoffice. I started building Cheerful at the dining table, but this was also not a good idea. Now I am back in my office which gives me the possibility to use my workshop as shipyard again.
To practice I build a test frame from an old piece of wood.
Instead of a paper base, I milled a template from plywood, which already takes into account the different thicknesses of the futtocks.
On this template, the futtocks were first glued together and then the chocks were added.
Finally a photo of the finished test-frame.
Now I can start with the serial production.
Congrats for finishing this wonderful model.
- Keith Black, mtaylor and Louie da fly
- 3
Really nice model.
- usedtosail and mtaylor
- 2
Quote
I agree. Much though I enjoy carving them, it would be nice to have the option of just buying them ready-made. Unfortunately, nobody seems to make mediaeval civilians - at least not in 1:48 scale.
In 1/48 I don't know an manufacturer of mediaeval figures. In 1/72 you can find lot of figures by Valdemar Miniatures. I planned to use them by a small cog diorama.
Really wonderful progress. Such figures in scale 1/48 would be a dream.
- mtaylor, Keith Black and Louie da fly
- 2
- 1
It's a pleasure to follow your log.
- Keith Black and Louie da fly
- 1
- 1
Quote
I'm all but certain the mast was not recovered from the Bremen cog, or from the Ijsselcog. It seems to be one of the first things to go.
You're right. For the Bremer cog you can use one of the replica's for teh mast design. In my opinion the Kieler cog is the best.
Do you know, that there is a wonderful book over the excavation with beautyful drawings of the IJssel cog?
"De opgraving en lichting van de 15e- eeuwse IJsselkogge" onder redactie van W.B.Waldus.
- mtaylor and Keith Black
- 2
I know the work which is in the reconstruction and drawing. Last month I did the frame design of my Triton a second time to become more satisfied with the results.
- mtaylor, druxey, Jorge Diaz O and 1 other
- 4
Kris,
it is a qustion of the result you like to have, the scale and your skills. There is in my opinion nobody than you who can answer these questions. I know from my own experience hoe dfficult and sometimes really frustrating it is to find this out.
If you like to buy some tools buy only good quality tools and check if the mones is an good investement.
Take an small project like the MSW capstan project to practice. If you than think, that you need more experience take another small project.
If you think it's enough start with your dream model. But be sure that you make in the beginning every part two of three times until the result satisfies you.
Rattlesnake 1782 by Gregory - Scale 1:48 - Plans from ModelShipways & NMM
Hi Gregory,
I read through your log this morning. I am little bit curious about your scale conversion.
1/48 is 133.33% bigger than 1/64. So you are not building the model in scale 1/48, if my calculation is right. It is not a big issue but you have to think on it, if you use information from the NMM drawing. You have to shrink the measurements.
I will follow your log.
