Everything posted by GGibson
This ad popped up on my FaceBook page. I normally delete ads faster than lightning, but this one caught my eye.. A micro reciprocating sander. Has anyone purchased this and happy? My Dremel works well for things like sanding char and other small sanding purposes, but sometimes I can't pass up a cool new tool... 🤷♀️🤣 DSPIAE Electric Reciprocating Sander – HobbyistHaven
GGibson replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
Congrats on completing this stage, Mustafa! Those beams are so sharp-looking. I am impressed with their consistency from fore to aft. Great detail! -
Well, after finishing my Bluenose, it's time to begin another build! And I am going to work on the Pavel Nikitin Santa Maria that I purchased earlier this year. Will work on this iconic ship, and then will build the Constitution. At least that is the plan... for now! While there are quite a few Santa Maria build logs here on MSW of differing scales and manufacturers, there really aren't any (yet) from the Pavel Nikitin group. There are a couple current logs on the Ships of Scale site that I will use for research and reference, as well as some YouTube videos of build logs. So, hopefully I will have plenty of references if I have questions. I mentioned back in January when I opened this build log as a "placeholder" for when I began the actual build that the box the materials come in was heavy! As I unpacked everything and began sorting, there are multiple packs of laser-cut sheets. The five (5) sheets of plans are huge! Got them hung up on the wall for now for reference. Began working on the keel, of course, as a first step. Each of the sheets are about 3.5mm thick and they are doubled up to form the full keel piece, so it makes for a nice, solid keel of a bit over 7mm in thickness. Always fun to bring out the clamps when gluing these big pieces! Then worked on the bottom piece of the keel (sorry, is there a formal name for this?) that will be exposed after the hull planking is completed. Again, two pieces glued together, with small square pegs inserted for additional strength and placement. Got to pull out the mini-clamps again, too! This Pavel Nikitin kit also came with a slipway to assist in the building process. Looks nice and I've seen other build logs using it, so I thought I would build it. Have to admit that it was challenging and frustrating. Was having difficulty sliding pieces into other pieces and getting things to fit well, so... I put it all back in the box and pulled out my "Keel Klamper" swivel vise. This should do just fine... Popped out all of the bulkheads from the laser-cut sheets and placed them on the keel to test-fit. All of them slid down into place pretty well, some are actually pretty loose. There are actually some kit-provided reinforcements that will connect between each bulkhead, so they should get better fits as we progress through the final placements of each bulkhead. Those will be shown in a future build log update. So, not a whole lot to start this build log, but wanted to get an initial "build" post on the record. As others have mentioned in their logs, this kit is definitely different than others I have worked on. It appears so much of the cutting and shaping has been done for us in this kit, as opposed to other kits that simply provide straight wood strips and you have to shape and cut them as needed. That analysis may change as I progress in this build. But, the Santa Maria should be an enjoyable build. Time now for some sanding and fairing! Appreciate the follows, likes, comments and criticisms, as always!
- 58 replies
- Santa Maria
- Ships of Pavel Nikitin
Thank you, Mustafa! Yes, I am already beginning the Santa Maria. I will hopefully see you on that build log! Appreciate your words of encouragement.
- 184 replies
- Bluenose
- Model Shipways
Thank you, Jim! Yes, was hoping I could get the flags to hang at rest better, but the Canadian Red Ensign looks good on the Bluenose!
- 184 replies
- Bluenose
- Model Shipways
Thank you, Eric! Appreciate your comment and your follow throughout this build.
- 184 replies
- Bluenose
- Model Shipways
Thank you, Bob! Appreciate the kind words, but there are certainly other Bluenose builds that have done much better. But... mine was a fun build, indeed. Before I get to the Constitution, which I am anticipating will take years to complete based on what others have done, I want to work on the Pavel Nikitin Santa Maria. It appears to be a much different type of build than what I've been used to, and I am thinking that it won't take quite as long as the Constitution, so... I have that one already on the table. No rest!
- 184 replies
- Bluenose
- Model Shipways
Welcome back, Mustafa! Antalya sounds magnificent! And I looked at some information online, beautiful beaches and scenery, lots of outdoors stuff to do, an aquarium, and some remarkable history. So glad you enjoyed your time with your children and grandchildren. I fully understand and appreciate those times with mine, as well. Makes us full again, doesn't it? OK, now... GET TO WORK!!! 🤣🤣🤣 Looking forward to seeing your next Constitution project. 👍 -
Thanks, John! You helped me SO much through this build process, words cannot express my appreciation, sir. You are appreciated!
- 184 replies
- Bluenose
- Model Shipways
Thank you, hamilton! Thank you, Jacques!
- 184 replies
- Bluenose
- Model Shipways
Funny how you don't see things necessarily with the naked eye, but after you post some zoomed pictures, you're like "How'd I miss that?!?" 🤷♂️ Did find that I missed placing a few rope hanks on belay pins on the foremast pin saddle and on the main mast fife rail, so added those. I am sure there are more misses, but I'm going to call this Bluenose finished. Started this Bluenose in November 2022 (well, technically, it began some 18 years ago, but that's a story I told in one of my first posts...), so it's been almost two years of solid shipmodeling. This is now my 4th completed model and no question it has been my most challenging and most enjoyable. Isn't that the way it's supposed to be? A million thanks to those who have followed along with me, to those that I have admired in their own build logs and have learned from during that time, those who continue to inspire me to do better. I have tried to do much less "settling for ok" with this Bluenose than in the prior three builds, but still have done some things that I have been disappointed in my results. But... I am learning and enjoying this retirement hobby too much to walk away. I am just committed to doing better with each new build. So... on to the next one! Again, thanks to all for your follows, likes, comments and criticisms. You are ALL appreciated. Here are a few final pictures.
- 184 replies
- Bluenose
- Model Shipways
Well, let's see if we can complete this Bluenose! What's left? Flags and rope hanks on the belay pins. FLAGS As almost everyone else who has built this Model Shipways' version of the Bluenose, they included the wrong Canadian flag in the kit. So, I found a good copy of the Canadian Red Ensign on the internet and worked on getting some good prints (both regular and inverted or mirrored) simply using the Paint program on my laptop. Still not sure if it is "historically accurate", but I wanted to have a 2nd flag on the foremast, along with the Canadian Red Ensign on the higher main mast. So, I chose the Nova Scotia Provincial flag for the foremast. I should also note that the Canadian Maple Leaf flag that was included in the kit measured approx. 82mm x 41mm. This size seemed a little too large as I held it up at the main mast. So, when designing the size for the Canadian Red Ensign, I decreased it a bit and printed it at 70mm x 35mm. I then made the Nova Scotia Provincial flag at a slightly smaller dimension of 62mm x 31mm. In reading on other MSW build logs about how others printed their flags on heat transfer paper, I recall that many of them were printed on inkjet printers. Although I have an inkjet printer, I also have a laser printer that has better quality print, so when I was preparing to do these flags a few months ago, I opted to purchase the laser printer heat transfer paper. Well, in my pure stupidity and loss of thought, when it came time to print these flags this week, I still thought I needed to print them on my inkjet printer. To make things even worse, I thought I would try printing these flags using the silkspan, as I thought they might hang better than using regular sail-type fabric. Well... ...it didn't turn out so well! Ha! The print wasn't adhering to the paper well and it got way too hot under the iron. Oops. Long story short (too late for that), I eventually realized that a) I needed to print to the laser transfer paper on a laser printer, and b) regular sail cloth was working much better than either of the silkspan thicknesses that I had. Once I successfully printed both flags on both sides of the cloth fabric, it was time to shape the flags. Since my Bluenose was completed without sails, I wanted the flags to appear as much "at rest" as I could get them. Using a series of dowels and clamps, I worked on shaping them, keeping them in these contraptions for days at a time. I would also spend a lot of time rolling them between my fingers to try and "soften up" the fibers in the fabric. (One note there - wear nitrile gloves to prevent any possible fingerprint smudges on your flags!) I also clipped some weight to the bottom fly end of the flags to help shape the flags. I should note also that, in one of my attempts to shape the Nova Scotia Provincial flag, I tried some spray starch on the flag which caused the colors to run, so I scratched that and didn't use starch anymore. This is how much I was able to curl/shape the flags. Using a 5/64" drill bit as a size guide, I wrapped 0.51mm wire around the sleeve grommets for the rope to pass through. After tying each flag to the mast tops, I was pretty pleased with how they looked. Whether it is accurate or not, I tied the Canadian Red Ensign flag halliard to the main mast's starboard sheer pole and the Nova Scotia Provincial flag halliard to the foremast's port sheer pole. ROPE HANKS There are many tutorials available (whether on individual build logs, separate topic discussions, or YouTube videos) on how folks have made their rope hanks to hang on belay pins. I made a little jig to create the ones I would hang on the Bluenose. If I were to do it over again, and I will do it on the "next ship", I would hang the loop over the edge like some others have shown. After saturating the rope loops with glue and drying, some of my loops also got a bit stiff and didn't bend and hang as perfectly as I wanted. But they look good to the casual observer, so I am moving on. I will do one more final walk-through on my Bluenose, but I think we are pretty close to finished. As always, appreciate the reads, likes, comments and criticisms. Thanks...
- 184 replies
- Bluenose
- Model Shipways
Thanks, Peter! Appreciate you following this build and thanks for the very kind words! I feel like I started out my build log with as... much... detail... as I could write, but as it got closer to the end, especially with the rigging, and without the sails detail, it was more of a "let's get this moving" attitude. I will hopefully get to my own Constitution build soon enough! <shrug> 🤷♀️🤣
- 184 replies
- Bluenose
- Model Shipways
Ahhhh, yes! I read "surface" and immediately jumped to "deck"... <doh> My bad! Your hull looks really good, Chris! Nice work! As for hulls, I'm a believer in painting those. And yeah, give it multiple coats with some sanding in between. Unless there are a few "divots", don't worry about smaller lines between planks. As I said earlier, this is your build. If you are happy with the hull, give it some paint!
First of all, Chris, this is your boat. Do with it how you wish! 👍 In your post, you mention painting, but then later you say "stain and poly". My 2 cents, but I hope you opt for staining with a topcoat of poly rather than actually painting with like an acrylic or something. With that said, if your planking is pretty flat, some light sanding in a few noticeable high spots would be fine (you don't want your lobster crew stubbing their toes on a deck plank!) and then stain and seal would be a good plan. Did I see where you had your own build log for your Lobster Smak? This was a fun ship for me. Best wishes! Carry on!
Thanks, Chris! Those comments, with your wealth of experience, means a lot to me. Much appreciated, sir!
- 184 replies
- Bluenose
- Model Shipways
Hey, Bob! Thanks for the kind words. The difficulties I had regarding making sails really, I don't believe, had anything to do specifically with the silkspan itself. It was just the general preparation of the sails in general. I absolutely agree that using silkspan is the way to go. I was just having trouble making clean, tight folded edges, keeping the sail sizes proportional to what they needed to be, etc. I also thought about furled sails using the silkspan, but was concerned they would just end up looking like rolled up tissue paper. I was probably destined to do this Bluenose without sails from the get-go. But I definitely think that, with proper knowledge and technique, the silkspan sails would be the way to go. FYI and FWIW, I got my supply of silkspan from Sig Manufacturing (sigmfg.com) and got two different sizes to test... the "00" light sheets and the "GM" medium sheets. Next time I want to make sails, I believe the "GM" medium sheet would be good for sails. The "00" light sheets were... pretty thin! Someone else may have also used their "SGM" heavy sheets, but I thought I read somewhere that the heavy sheets didn't work as well. <shrug> Again, Bob, appreciate the read and the nice comments. 👍
- 184 replies
- Bluenose
- Model Shipways
Thanks, John! I cannot give enough thanks to you for your guidance in being just enough ahead of me in your Bluenose build for me to be inspired and trudge forward. You've answered plenty of my queries. You are appreciated!
- 184 replies
- Bluenose
- Model Shipways
