ERS Rich
Everything posted by ERS Rich
  1. Built the POB - link to album is below. My preference is bevel after the frame is built up. Use a batten (long plank) when filing the bevel to check your work. A file can span several bulkheads, gives good control. Good luck with it.
  2. Ahoy in the heartland! Welcome to model ship world. Good luck with your Beagle! -Rich
  3. Ahoy! Welcome to Model Ship World. Good luck and have fun with your projects. Always around to answer a question.
  4. Ahoy! Welcome to MSW. Always open to a question. Have a great day.
  5. Completing the Case - Displaying the Model Last steps are to cut the Lexan and assemble the case. Used a Festool track saw to dimension the Lexan. Assembled the case and moved her out of the shop into the family room. Thanks for following along and Happy New Year! -Rich
  6. Welcome to MSW! Good luck with you projects!
  7. Welcome to Model Ship World, fortunate to have visited Melbourne, with my wife, on a business trip. The people were great and we enjoyed the Great Ocean Road. Judy loved the fresh fruits and vegetables. Have fun with your ship model! Cheers, -Rich
  8. Good Morning, Recommend a Paasche Talon, available at Coast Air Brush and shellac. Good luck and happy new year!
  9. Thanks Yves, I’m a cabinet maker, once had a business, and am fortunate to have the equipment. Hand tools could be used to make the base and the base frame - with moulding from a hardware store. The frame groove could be made with a hand router. Check this out from Lie-Nielson Toolworks in Maine. But it is a little tedious. If you don’t have a tablesaw, possibly you could access one by taking a woodworking class. Or approach a local cabinetmaker/shop. Have a good holiday season.
  10. Case Frame The case frame members are made of 1/2” square Cherry with grooves cut with the table saw. Grooves are centered on the face of the member and 1/8” deep. The posts and top pane frame members have two grooves. The bottom members one. The bottom members have tenons cut to fit the groove. The Burns saw is setup to cut the tenons. Joints will be pin nailed. The post sits on the base top and is supported on two sides by the base moulding. The top panel has mitre corners, that will be glued and supported with metal corner braces. There is a cross piece across the middle. Here the frame is dry fitted. Next is cutting the Lexan panes. Happy Holidays!
  11. Base Frame Milled the frame components from 4/4 rough Cherry. Base moulding is 1 7/8” high, just under 1” thick. Routed a Roman Ogee edge on the router table. Mitre cuts were made on the table saw with an Incra fence. Glued up the frame, square makes sure of the alignment. Case frame will be made from 1/2” square stock. Here is the table saw setup to cut the stock from the rough. This picture shows cutting the 1/8” deep groove for the Lexan. Stacked up the case components against the base moulding, 1/2” square strip on bottom under 2 short blocks representing the base, and 1/2” square grooved strip on top representing the case frame above the base. Lucked out, stack is flush with top of base moulding. Under the base will be 4 blocks screwed to the moulding with holes to allow screws into the base. There are also 4 corner blocks. To remove the tool marks, sanded the frame with a random orbital sander - 220 grit. As before, finished the Base Frame with Howards Feed and Wax Oil and Conditioner, Beeswax and Orange Oil. Added felt pads to corner bottoms. Here’s the model in the frame.
  12. Hermione Lafayette - Artisania
    Built this frame many years ago.  Getting it going again.  Additional experience will help with the imprecise directions.  Some interesting prebuilt fittings and sewn sails. Have a matching set of figures.  A little toy like. Let’s see what happens.  No build log this time, updates will appear here.
  13. The files I like…..deep between the cutting bits so plastic doesn’t build up, yields a smooth finish….. Tamiya Files Enjoy
  14. It’s looking good, enjoying following along…. -Rich
  15. Hello and welcome to Model Ship World. Sounds like you are on the right track with a few projects under your belt.. Looking forward to seeing your San Juan…. Have fun in Sydney! Cheers, -Rich
  16. The Base Happy Hoidays! Decided on a Cherry Hardwood base with a light finish (essentially natural), to contrast with the green hull. To determine the base length and width, measured the length and width of the model and added 3” to both, base is 12” wide by 36” long. Had already a piece of Cherry milled lumber finished to 4/4 (1”), so cut it to the base dimensions. Rubbed down the piece with 0000 steel wool. As the base will be cased, it will not be touched, finished with Howard Feed and Wax, Beeswax and Orange Oil. Flooded the surface, let absorb 20 minutes, wipe down, and repeat. It’s also a quick way to finish wood. Drilled two 1/4” holes in the base 12” apart. Pedestals by Bluejacket with 3 1/2” #10 mounting screws. Drilled out the pedestal bore slightly to accommodate the screws. Stacked the base board on pieces of 2” x 6”, placed the model on blocks, with a couple of cradle blocks - so the beast doesn’t roll, the model is slightly higher than the pedestals. Installed the mounting screws from below the base, through the pedestals and into the pre drilled holes in the hull. Just before final tightening removed the blocks and rested the model on the pedestals. Here she is. I’ll take her out of the shop, while I build the case. Once the case is done the base will be dropped into it.
  17. Welcome to Model Ship World! Why not try working together and see how it goes? It could work out. Good luck with your projects snd happy holidays!
  18. Hello, Cannons not installed because they need finishing. The supplied backplates are installed. To do this, the gun port covers were installed, and a cannon was used to align the backplate before the adhesive set. Cheers!
  19. Greetings from Massachusetts, USA. Welcome to Model Ship World.
  20. Good Morning Sinon, Thanks for the kind words. Likewise, I’m humbled by the work of craftsman and artisans here on MSW. See that you are getting started. Think about several things, tools/ techniques, finishing, and the project. If you’ve never worked with wood, study how. Plenty of Youtube videos out there - see Tom Lauria’s channel. Gather the hand tools needed. It can be chisels, files, and small saws. Woodworking is measuring, marking, cutting to a line. Start with hand tools, later if you are into it, step up to power tools. Probably the most important skill for a woodworking beginner is being able to sharpen a chisel. Likewise study wood finishing - sealing then color. Consider shellac for sealing, it’s natural and dries quickly. And it’s very forgiving, it’s sandable. Start with paint brushes to apply paint, my suggestion is acrylics - and pay attention to thinning the paint, so it lays down nicely. Last is the kit. Start with a very inexpensive and easy kit. This is practice to develop the skills and techniques that work for you. Once you have your technique down, move up to a more difficult kit. The last thing you want to do is buy an expensive kit before you have developed your techniques. That’s a setup to fail. Start with an open boat. The idea is to move through all the steps and finish the project in a reasonable amount of time. Don’t worry necessary how it looks, it doesn’t need to be perfect. Keep a log, for yourself, write down what does and doesn’t work. This is the time to experiment and figure out what works for you. There is usually more than one way to get a result. One idea is to buy two of the same inexpensive kit to start and build them at the same time. Experiment and perfect a step on the first, then do it again on the second. Avoid perfectionism and finish the project and enjoy the satisfaction of getting it done. The open boat project lays the foundation of building a hull and paint. Next is projects with a single mast, then two masts - schooner rig, then square rig. Best of luck and happy holidays. -Rich
