Glen McGuire
Everything posted by Glen McGuire
  1. Indeed, Ian. That's been my problem all along! I'm the guy in the 3rd Indiana Jones movie that picked the wrong Holy Grail to drink from.
  2. Catching up on all the research posts above. Fascinating. This is going to be another very entertaining build.
  3. Thank you to everyone for the lively discussion and the creative solutions for solving the whirlpool problem. You have given me a number of good ideas to try out. In the mean time it's back to work on the Flying Dutchman. Next up is the ship's armament. I built the ship with ports for 7 cannons on the gun deck and 6 cannonades on the spar deck. In the movie, there's a few close-up shots of the cannons emerging from the gun deck ports. In some shots, there are triple-barreled cannons. I thought those looked very cool so decided to make all my gun deck cannons with triple barrels. For my cannon barrels, I use 22 gauge (.67mm diameter) veterinary needles. They are hollow, so if anyone looks close enough they they look more like a cannon barrel than a solid rod which is what I used to use. I cut the needles into pieces 4mm long, then CA glued them into a mini pyramid 3 at a time. For the spar deck cannonades, I made carriages out of .75mm thick basswood, grooved a small cradle into the top surface, and CA glued the barrels in place. Crude, but it works at this scale. Here she is with the triple-barreled cannons glued in place and the cannonades dry-fit. Next up - the masts. I'm doing 3-piece masts for the fore and main with a 2-piece for the mizzen. For these, I take a bamboo rod, cut it up, thin it, and taper the tip. As usual, I use a version of John Fox III's hidden hinge method at the base. Here's the ship in its current state with the masts and bowsprit dry-fit. The junction on the mizzen between the main mast and top mast is too high, but necessary for the crow's nest to clear the stern when it is laid down.
  4. When I first started research on this project, I googled "how to make a whirlpool with epoxy resin" and that video showed up at the top of the list. I perused the entire Minibricks website and was left in awe. They take epoxy resin art to a level that I've never seen before nor thought was possible. That particular video is what I'd like mine to look like (in my dreams, anyway), but doing it inside a bottle makes it a whole 'nother thing!
  5. Yes, much bigger. The diameter will be about 2 1/4" at the top edge of the whirlpool where the ships face each other (red line below). Depth will be around 3/4", maybe a bit more. Hence the problem with getting a funnel that large, or even pieces of a funnel that large, out of a bottle neck that is 3/4" wide. That's why I think I will have to construct the whirlpool inside the bottle, but I'm going to experiment with the funnel idea.
  6. Thanks, Mike. I think the Vallejo product you used is similar to the Woodland Scenics Water Waves that I've used. The idea has some promise, but scooping so much into the bottle cleanly will be a challenge.
  7. Are you trying to get blocked from this build log too, Ian?? 😃 Now remember, I am not an engineer. So I don't have a box full of DC motors and rheostats lying around in my garage like I'm sure you do! I also think we have different definitions of the word "simple", but I do appreciate your creativity!
  8. The funnel is an interesting idea. Getting the funnel out, as Roel said, would be the hard part. I'll do some experimenting on that.
  9. That would make me a cheater, cheater, pumpkin eater!! 😲😲😲 I'm sure it would also violate something in the SIB builder's Pirate Codex and I know what happens in the Pirates of the Caribbean movies if anyone does that!
  10. Dang, Roel! I was hoping you had an answer for me! A fairly easy solution would be to use clay. I've seen a lot of SIBs that use clay for water in the bottle. But I like using epoxy resin or something similar that has transparency because it looks so much more like real water. One idea I've got is using Woodland Scenics Water Waves product. I've used it in the past to add texture to a layer of epoxy resin and it works very well. Another idea is clear silicone. I need something that I can swirl around but will hold it's shape while it dries. I'm going to experiment with some things. Glad you are following along!
  11. Welcome aboard, OC! I need to check out your Black Pearl before I dive into mine.
  12. As much as I like the Tennessee, I vote for the Lula to complete this unique project.
  13. The biggest challenge for me was making those dang 8 battens that go around the middle of most of the yards. Trying to make each set of 8 exactly the right width to fit evenly around spars of varying diameters cost me some brain cells. But to my surprise, they all ended up fitting pretty well in the end.
  14. I spent the weekend doing yard work. But I wasn't pushing the lawn mower in our 100 degree heat like I should have been. Instead, I was hunched over the drill lathe making all the yards and yardarms for Connie. That consists of 15 yards, 16 yard arms, a gaff and a spanker boom. Here's everything laid out on the mast/yard plan after the tapering process which was followed by adding the center battens, the parrel cleats, and the yardarm cleats. Next, I carved out the jaws for the spanker boom and gaff. Here's the completed spanker boom and gaff. Here's a closeup of the main yard. And here's the whole 9 yards (haha 🙄). I think that's a fair amount of progress for a little over a week, so I'm going to give Connie a short rest and head back over to the Flying Dutchman/Black Pearl SIB.
  15. I can't top that compliment, so I will repeat it! This project is bloody ripper! Such a cool build to follow and every aspect of the work was exceptional. Congratulations, Keith!!
  16. Talk about a cheap date! 😃 Cheap entertainment or not, you did a really nice job on this, Bryan. The final result turned out great in all respects. Well done!
  17. Thanks for posting about the model shop, Carson. I'm sure that visiting it with your dad is a very fond memory for you. The link on the history of the shop has a couple of great quotes: "Freitag credits women employees with keeping the store neat." Ain't that the truth!! One look at the workspaces that most of us here on MSW keep will confirm that 100%! "We try to make more friends than we make money" That's got to be the best quote I've ever seen on how to run a successful local business.
  18. Welcome aboard, Nick! I hope that you will create a build log for this epic adventure so we can follow along.
  19. Your work with the pastels is very convincing, Keith. And yes, a little goes a looong way as I have learned!
  20. Thanks, Tim. The netting on the aft railing of the fighting tops was already completed by Carson's father. I didn't really look at it too closely until your note. It's a lot finer mesh than the netting that he used under the bowsprit and, interestingly enough, it is metallic and not woven like a window screen. I did some rummaging around inside another box of goodies that Carson had given me and found the source of this netting - Scale Scenics - which makes things for model railroads. I had not seen this product before but I'm thinking it might be of use for some of my SIB work. However, I bet I can't get it for anywhere near $2.95 now! Now, back to the bobstay issue. Keith, I do think your idea was brilliant, but I did not have the right paint or maybe the right painting skills (I'm definitely no "Paintin' Manning" like in the new commercial!). I tried your idea out on a test piece of thread but I kept getting blobs. So back to the double rope plan. Which, in looking at some other Connie build logs, seems to be a popular method of rigging the bobstays. I was able to add a line, as hoped, without too much difficulty. Then I seized it up and down with knots as others have done. I like how it looks now. So thank you, @Ian_Grant! You made me do some extra work, but I believe it was well worth it!
  21. We made it through all that incredible piping layout/installation and now you are worried about boring us with details? 😃 You should know by now that we crave endless details! Such a fascinating project. Keep up the brilliant work, Roel!
  22. OK, who invited this guy to the build log?? 😠 Just kidding! It's interesting that you pointed out the bobstay lines, Ian. I could not figure out exactly what the instructions were telling me with those. They say, "Bobstays - 3"-8" ". The number is supposed to indicate the actual rope diameter and they provide a table to convert it to thread diameter at scale. I thought they were giving me a choice of using 3" rope or 8" rope. My box of kit goodies has a lot more 3" rope than it does 8" so I chose the 3". And, yes, the 3" is the same as the martingale rope. Looking again at other build logs now, I can see clearly that you are right. All the bobstay ropes I see are thicker than the martingale rope. I still don't know why the instructions are written the way they are, but the question is what to do about it. Of course, the easiest fix is just deleting your comment and blocking you from the log 😃. But I don't know how to do that. So on to plan B where I think I found a good solution. In reviewing @usedtosail's excellent build log for his Constitution, he doubled the lines for the bobstays. I'm pretty sure I can do that and leave my current bobstays in place without too much difficulty. All joking aside, I really do appreciate your eagle eye on catching something like that. I hope that you and others will not hesitate to give advice and point out things I've missed. That's one of the great benefits of doing a build log here on MSW!
